babgvant 143 Posted February 11, 2016 Author Posted February 11, 2016 2/11/16 Edge -> madVR 0.90.8 Standard-> madVR 0.90.3
Heuer 76 Posted February 14, 2016 Posted February 14, 2016 I notice all the filters on my new ET installation have updated to the latest versions but madVR refuses to update beyond V0.87. I have tried deleting the .txt files in the COMObjects folder but to no avail. Is 0.87 the latest version officially supported by ET?
babgvant 143 Posted February 14, 2016 Author Posted February 14, 2016 That's odd. It should check every week and pull down the updated set (assuming they are newer). I'll have a look when I get a chance. You can always just overwrite the contents of the folder (i.e. madvr) with whatever version you want.
Heuer 76 Posted February 14, 2016 Posted February 14, 2016 Thanks. It is happening on both my HTPC and PC ET installs. I have now overwritten the folder with the latest madVR but it would be nice for auto update to keep everything in step.
babgvant 143 Posted February 14, 2016 Author Posted February 14, 2016 Totally agree. I'll have to figure out what the problem is. The whole point is to remove the need for users to self manage this sort of thing. BTW, I forgot to ask. Are you using the older player or the new one?
babgvant 143 Posted February 15, 2016 Author Posted February 15, 2016 2/15/16 Edge -> XySubFilter 3.1.0.746
babgvant 143 Posted February 15, 2016 Author Posted February 15, 2016 New Emby Theatre V1.0.41 I think this might be because the COMObjects are always first extracted from the exe itself and there was a lag b/w when the filters are updated here and when they get updated in the release. *.42 includes the latest madVR in standard. Please LMK if you can still reproduce.
babgvant 143 Posted February 16, 2016 Author Posted February 16, 2016 Standard -> XySubFilter 3.1.0.746
babgvant 143 Posted March 5, 2016 Author Posted March 5, 2016 3/5/16 Edge -> EVR+ 1.0.0.7 Standard -> EVR+ 1.0.0.7
babgvant 143 Posted July 2, 2016 Author Posted July 2, 2016 Edge -> madVR 0.90.21 Stable -> madVR 0.90.8
Guest asrequested Posted July 2, 2016 Posted July 2, 2016 I don't see a mention of a LAV update since 0.67. The present release is 0.68.1. I copied the latest version into the folder.
babgvant 143 Posted July 2, 2016 Author Posted July 2, 2016 Edge -> LAV Filters 0.68.1Standard -> LAV Filters 0.67.0
babgvant 143 Posted August 14, 2016 Author Posted August 14, 2016 Edge -> madVR v0.90.24Stable -> madVR 0.90.21 3
Sammy 791 Posted September 7, 2016 Posted September 7, 2016 STABLE! So how do I force this to happen?
babgvant 143 Posted September 7, 2016 Author Posted September 7, 2016 Flip from stable to edge, then back again should do it.
puithove 209 Posted December 24, 2016 Posted December 24, 2016 @@babgvant - you might want to consider bumping the madVR version for Edge. v0.91.4 seems to be going well (has been out for a while and had fixes since the first 91 release) The new NGU scaler is quite impressive. 1
SikSlayer 254 Posted December 24, 2016 Posted December 24, 2016 @@babgvant - you might want to consider bumping the madVR version for Edge. v0.91.4 seems to be going well (has been out for a while and had fixes since the first 91 release) The new NGU scaler is quite impressive. I agree. It's really a game changer, and has had enough bugfix releases.
babgvant 143 Posted January 21, 2017 Author Posted January 21, 2017 Stable -> LAV Filters 0.69 Stable -> madVR v0.90.24 Edge -> madVR v0.91.5 2
