Emby for Kodi (Beta)
Updating went without problems - lost my sets though?
Using openelec 5.0.8 and Mediabrowser Titan skin
I will update to 0.0.10 and see how that goes.
BTW - best thing since sliced bread!
xnappo
Did you turn it back on in settings?
SwanStream
However it may not work correctly on Windows clients.
I assume that if after the reset, if I get an "OK" it worked... though I am on windows. Is there a specific error that would indicate we need to delete the db manually?
im85288
Yes if it says ok then things have worked correctly, it seems to be a bit hit and miss on windows but works every time on OpenELEC and OS X
StealthDefender
Wohoo, great news guys! On weekend i transform my openelec from the old plugin to the new and hope it works also that great like on my win machine.
And by the way arctic zephir also rocks!!!! :)
Greetz Stealth
  • Like 1
Updated to 0.0.10
Yes, I checked that first. You are talking about the Settings>Videos>Group movies in sets
Right?!
If so, yes, it was still enabled after the update but all movies that were in sets are now mixed in with the rest of the movies.
I turned it off, then on again, rebooted...still no sets
All was working in very first beta you came out with... if no one else having this issue I can dump everything and start from scratch (although I prefer not to)
Edited by JDizzy
xnappo
Will let @@im85288 comment.  Sets were not a big part of our internal testing :)
im85288
Updated to 0.0.10
Right?!
No, go into the addon settings, under sync options, and turn it on there. Then give it about 15 minutes and it should be fine. The option is there due to some people preferring not to have their media showing as sets....but seeing that option you shown we may need to rethink that strategy and have it on by default. Edited by im85288
  • Like 1
Ok, checked the addon setting and it was, in fact, turned off.
And I was going to mentioned that on initial sync (with first beta), I saw it sync movie sets.
I did notice that starting with 0.0.9 it didn't automatically sync them.
Got to run but will check it in a while.
Thanks!
SwanStream
So after update to 0.0.10 should the whole "sha-zamm" discovery of TV/Movies happen all over again? I got the OK after install of the new version, but even after a restart there was no "updating/finding" of TV/Movies and everything was still there from befo.
im85288
Yes it needs a complete fresh install, if you follow the manual reset instructions I provided you can be sure it did actually delete everything..or switch to Openelec :)
Sadly the cpu hammering has actually gotten worse with this version, posted some findings in the other thread :(
SwanStream
I followed the instructions, did the reset, got the OK, it said it would now restart, but didn't. I tried to restart, it locked up, I had to kill the app. Next I deleted the database file, and the directory listed in the first post. started Kodi, it found the server, selected the user, it started to scan, and within a second or two got a emby script error message quickly in the corner then nothing. Tried a restart again, it locked up, I killed the app, rebooted the pc and started kodi where I get the script error message again. This process was repeatable so I removed the add-on, wiped it's data, installed and turned on debug, went through the same steps.
Here's the log. Last few lines clearly show an error. Let me know if I can provide any more info. In the meantime looks like I'm DOA....
kodi.log
nekromantik
Im running OpenELEC latest version and installed emby add on. Put in my server details and it did not give any errors.
However nothing shows up in the skin under movies or tv shows and when you choose add on browser and choose emby it keeps showing config. Cant even browse folders.
Nothing has changed on my Windows Emby server.
Kodi log says:
GetDirectory - Error getting plugin://plugin.video.emby/?content_type=video
Edited by nekromantik
@ It looks like the same error as I had. Please look into my thread for the possible solution.
  • Like 3
Just a suggestion, wouldn't it make sense to put the reset instructions in the first post too?
xnappo
Yes - same problem.  We will push a fix for this shortly, but easy to patch yourself.
xnappo
Kodi log says:
Did you maybe forget to change your skin out of 'MediaBrowser' mode?  This addon works very differently from the old one.
  • Like 1
nekromantik
 Thanks!
SwanStream
Thanks Tolotos! that fixed it. Damn umlaut! ;)
  • Like 1
im85288
Version 0.0.11 is released with the above mentioned fix.
Anyone who was not effected need not worry or do anything with this updated version.
@@im85288 Thank you!
It's near midnight here and I'm really need some sleep. I worked the last nights on my TVHeadend plugin for Emby.
I like to find 0.0.12 tomorrow morning fixing the CPU stuff ;-)
Good N8 Tolotos
  • Like 2
im85288
Awesome..can't wait to use your TVHeadend plugin for Emby, been waiting forever for that...if I can help in anyway just let me know :)
Thanks! Movie sets now working.
It would make sense to have sets sync by default. If you have none, it will just pass it by and I'm guessing, nothing harmed.
And, I'm guessing again, that if you have sets disabled through Kodi Setting>videos> that they will not show up even if they are synced......
I also noticed the 'flashing' seems to be gone as it updates after watching a movie.
Lastly, I was running 0.0.9 and when I did the reset to use 0.0.10, it asked if I wanted to delete database. When I answered Yes, I got a quick red colored script error in upper left corner of screen and Kodi seemed to lockup. I rebooted, it found the server and went through the login. After that, it synced all my data without problems. So it looks like I can pass on 0.0.11 fix for the moment.
Again, running Openelec 5.0.8
And THANKS again!
Edited by JDizzy
Did the other video sources disappear in this build? As in only Movies, TV Shows & Music Videos only show up now. Any other custom ones are gone. Can't seem to find them this time.
Syncing seems to work now for me. Makes a fire tv stick actually usable now. :-)
Guest
