AwesomeDuke 0 Posted March 29, 2015 Posted March 29, 2015 Hi, I am runng MB on FreeNAS and am having a few issues with the PlayOn Plug-in. I installed and paid for the PlayOn Plug-in and also paid for a Lifetime membership to MediaBrowser and have applied the Supporters Key, so I am not sure what I am am missing. When i try to access PlayOn via the Channels section I get an error: ConnectFailure Connection Refused. I have attached a screen shot of the error message. I am not sure where to to from here. Can anyone please point me in the right direction? Thanks Duke
Luke 42253 Posted March 29, 2015 Posted March 29, 2015 Please see http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/ do you have playon installed and functioning on it's own? have you tried to configure the playon plugin?
AwesomeDuke 0 Posted March 29, 2015 Author Posted March 29, 2015 Please see http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/ do you have playon installed and functioning on it's own? have you tried to configure the playon plugin? Hi Luke, Thanks for your reply. The version of MB is 3.0.5518.7 and the PlayOn plugin is version 1.0.0.8. I can post the logs if you tell me where I can find them in FreeNAS becuase the link you supplied above only shows where they're located in Windows and Mac. Thanks Duke
snazy2000 345 Posted March 29, 2015 Posted March 29, 2015 Go in to dashboard -> help -> logs should find latest there 1
AwesomeDuke 0 Posted March 29, 2015 Author Posted March 29, 2015 Go in to dashboard -> help -> logs should find latest there Thanks for that. Please find attached the latest log file. Thnaks again for looking into this... Duke Log.txt
snazy2000 345 Posted March 29, 2015 Posted March 29, 2015 Can you send back data from this link from a web browser http://192.168.8.231:54479/data/data.xml?x=223450000&flm=long
AwesomeDuke 0 Posted March 30, 2015 Author Posted March 30, 2015 Can you send back data from this link from a web browser http://192.168.8.231:54479/data/data.xml?x=223450000&flm=long No, I get a Firefox error message saying "Unable to Connect". Thanks Duke
snazy2000 345 Posted March 30, 2015 Posted March 30, 2015 There is your issue, its to do with your playon server are you sure the ip address is correct for your playon server? Also is your firewall allowing that traffic, can u try replacing the 192.168.8.231 with localhost and run it in the same server that your playon server isnlocates
AwesomeDuke 0 Posted March 31, 2015 Author Posted March 31, 2015 There is your issue, its to do with your playon server are you sure the ip address is correct for your playon server? Also is your firewall allowing that traffic, can u try replacing the 192.168.8.231 with localhost and run it in the same server that your playon server isnlocates That is definitely the IP address. I am not sure if you are familiar with the FreeNAS version, but it runs on FreeBSD, so there is no web browser that can check a localhost connection. I'll see if there is anything via the command line that can be tested. I just had confirmed that there is no firewall on the FreeNAS server. So that's not blocking PlayOn. Is there someone I can contact like the PlayOn developer to see if he has any ideas? Thanks...
AwesomeDuke 0 Posted April 1, 2015 Author Posted April 1, 2015 Any assistance would be most appreciated. Just a contact for the developer of the plugin would be great. Thanks
Luke 42253 Posted April 1, 2015 Posted April 1, 2015 Snazy is the developer of the plugin but all the plugin does is talk to the play on installation that you already have. So you need to have that up and running first
snazy2000 345 Posted April 1, 2015 Posted April 1, 2015 Im guessing you havent installed playon itself which is required. http://www.playon.tv/playon. This is a windows only application as far as i know
