gmontem 6 Posted September 6, 2020 Posted September 6, 2020 22 minutes ago, gmontem said: I installed Emby Server onto a new Windows server. I then installed the Vera plugin. After restarting the Emby Server, the Emby Server crashed. It looks like the Vera plugin is making a request to my VeraSecure's port 3480 which is probably closed. My browser receives a connection reset error when I try to navigate to http://192.168.11.224:3480/data_request?id=sdata. Is there something I need to setup from my Vera's web frontend to get this work? I tried re-installing the "Emby Interface" app for Vera, but that didn't help. I attached the server log and the Vera plugin's XML file. embyserver.txt 19.29 kB · 0 downloads VeraHomeAutomation.xml 271 B · 1 download Looks like the way you access ports has changed after some Vera FW release. This request works with my Vera FW: http://192.168.11.224/port_3480/data_request?id=sdata
chef 3811 Posted September 6, 2020 Author Posted September 6, 2020 (edited) 4 hours ago, gmontem said: I installed Emby Server onto a new Windows server. I then installed the Vera plugin. After restarting the Emby Server, the Emby Server crashed. It looks like the Vera plugin is making a request to my VeraSecure's port 3480 which is probably closed. My browser receives a connection reset error when I try to navigate to http://192.168.11.224:3480/data_request?id=sdata. Is there something I need to setup from my Vera's web frontend to get this work? I tried re-installing the "Emby Interface" app for Vera, but that didn't help. I attached the server log and the Vera plugin's XML file. embyserver.txt 19.29 kB · 0 downloads VeraHomeAutomation.xml 271 B · 1 download @gmontem Did you manually change the port and url settings for your Vera in the dashboard? EDIT: There are some setting in your Vera to enable secure connection. I'll do some testing and see if I can fix this. Edited September 6, 2020 by chef
chef 3811 Posted September 6, 2020 Author Posted September 6, 2020 @gmontem Would you try un-checking this setting in your vera dashboard and tell me if the issue goes away.
gmontem 6 Posted September 6, 2020 Posted September 6, 2020 6 hours ago, chef said: @gmontem Would you try un-checking this setting in your vera dashboard and tell me if the issue goes away. Unchecking the setting seems to work! Web browser navigating to http://192.168.11.224:3480/data_request?id=sdata gives me JSON data. It turns out this address still works regardless of security setting: http://192.168.11.224/port_3480/data_request?id=sdata Something to consider in case the Vera guys decide to close ports in a future FW update. But most important, your Vera plugin works! Although I have a Vera Secure model and not the Vera Plus. I will try to turn on my HTPC and run MB Theater so it'll show up as a network device. If you don't hear from me, you can assume my problems are gone. Thanks! 1
chef 3811 Posted September 6, 2020 Author Posted September 6, 2020 1 hour ago, gmontem said: Unchecking the setting seems to work! Web browser navigating to http://192.168.11.224:3480/data_request?id=sdata gives me JSON data. It turns out this address still works regardless of security setting: http://192.168.11.224/port_3480/data_request?id=sdata Something to consider in case the Vera guys decide to close ports in a future FW update. But most important, your Vera plugin works! Although I have a Vera Secure model and not the Vera Plus. I will try to turn on my HTPC and run MB Theater so it'll show up as a network device. If you don't hear from me, you can assume my problems are gone. Thanks! Is there a way to give me the device type serial for a Vera secure? I was collecting device types and coding them into a list inside the plugin. I hadn't met anyone with a secure version, so this is why it says "plus".
bluemonkey07 590 Posted January 10, 2021 Posted January 10, 2021 using Chrome browser with emby server 4.5.4.0 running on a freenas server the plugin settings page is non functional.... nothing appears in any dropdown selector
bluemonkey07 590 Posted January 23, 2021 Posted January 23, 2021 @chef is this plug-in still being actively maintained?
chef 3811 Posted February 9, 2021 Author Posted February 9, 2021 On 1/10/2021 at 10:17 AM, Vidman said: using Chrome browser with emby server 4.5.4.0 running on a freenas server the plugin settings page is non functional.... nothing appears in any dropdown selector I'll see what's up.
chef 3811 Posted February 9, 2021 Author Posted February 9, 2021 @Vidman Can you please try unchecking this option in the vera dashboard and then see if the ui loads up okay
bluemonkey07 590 Posted February 10, 2021 Posted February 10, 2021 i have all these options unchecked, does upnp need to be enabled(checked)? On 2/10/2021 at 12:12 AM, chef said: @Vidman Can you please try unchecking this option in the vera dashboard and then see if the ui loads up okay
chef 3811 Posted February 11, 2021 Author Posted February 11, 2021 (edited) 18 hours ago, Vidman said: i have all these options unchecked, does upnp need to be enabled(checked)? @Vidman I'll have to check that. The plugin is just making requests to the vera device through it's api. in the affected browser, could you try this url and see if the vera device is return "OK" "http://YOUR_CONTROLLER_IP:3480/data_request?id=alive" Edited February 11, 2021 by chef
bluemonkey07 590 Posted February 12, 2021 Posted February 12, 2021 14 hours ago, chef said: @Vidman I'll have to check that. The plugin is just making requests to the vera device through it's api. in the affected browser, could you try this url and see if the vera device is return "OK" "http://YOUR_CONTROLLER_IP:3480/data_request?id=alive" The Vera returns "OK" if i replace YOUR_CONTROLLER_IP with my actual Vera ip address 1
bluemonkey07 590 Posted February 12, 2021 Posted February 12, 2021 .... and if i click the Vera button in the header of the settings page it opens my Vera dashboard webui
chef 3811 Posted February 12, 2021 Author Posted February 12, 2021 5 hours ago, Vidman said: The Vera returns "OK" if i replace YOUR_CONTROLLER_IP with my actual Vera ip address Okay, I'm looking into it further.
bluemonkey07 590 Posted February 16, 2021 Posted February 16, 2021 On 2/12/2021 at 7:26 PM, chef said: Okay, I'm looking into it further. check your pm
bluemonkey07 590 Posted February 22, 2021 Posted February 22, 2021 @chef Next issue: I'm only able to have 2 devices configured
chef 3811 Posted February 23, 2021 Author Posted February 23, 2021 18 hours ago, Vidman said: @chef Next issue: I'm only able to have 2 devices configured What are the devices you aren't able to configure? Keep in mind that we can't really differentiate between browsers because they change their ID's all the time. You should definitely be able to have more then two.
bluemonkey07 590 Posted February 24, 2021 Posted February 24, 2021 (edited) @chef ok so i set up a couple of dummy Vera scenes that toggle a dummy Vera virtual switch and setup your plugin to run the scenes when watching on my mobile (android mobile app). that worked fine. then i set another device up (nvidia sheild-android TV app) and when saving that configuration it deleted my first trial device. (android mobile app) so i re-added the mobile trial settings and it deleted my other device(nvidia sheild android TV app) settings. so it seems i can only have two devices saved (the other is the original device that was originally already setup) To be clear I am able to configure and save these settings ....and they work until I add a 3rd device, then the 3rd device is saved and works but the 2nd device is removed and no longer works Edited February 24, 2021 by Vidman
chef 3811 Posted February 24, 2021 Author Posted February 24, 2021 2 hours ago, Vidman said: @chef ok so i set up a couple of dummy Vera scenes that toggle a dummy Vera virtual switch and setup your plugin to run the scenes when watching on my mobile (android mobile app). that worked fine. then i set another device up (nvidia sheild-android TV app) and when saving that configuration it deleted my first trial device. (android mobile app) so i re-added the mobile trial settings and it deleted my other device(nvidia sheild android TV app) settings. so it seems i can only have two devices saved (the other is the original device that was originally already setup) To be clear I am able to configure and save these settings ....and they work until I add a 3rd device, then the 3rd device is saved and works but the 2nd device is removed and no longer works Okay, I'll check it out. Thanks!
chef 3811 Posted February 24, 2021 Author Posted February 24, 2021 @Vidman I went through the code and found some problematic stuff. I have pushed a new release. This was the first plugin I had ever written, so... the code is old, and when I read, it I wonder what in the world I was thinking at the time. Realizing that my skill has advanced substantially, I think this plugin needs an entire overhaul. For now I believe I have fixed the issue with saving device profiles for now. But please let me know. I have tested it, and haven't found an issue.... (means nothing LOL). I do plan on rewriting this thing. It probably won't look very different on the outside, but it will be better over all in the future. I look forward to hearing back from you. Thank again for letting me know about this stuff.
bluemonkey07 590 Posted February 24, 2021 Posted February 24, 2021 well after updating to the new release i can now have 3 devices showing, but it seems the one i set up to test isn't triggering the scenes (Android mobile app) i will not be able the check the other two devices until i fly home in a few hours. curiously after i updated to the latest release i noticed my previous 2 devices has disappeared, was this expected?
chef 3811 Posted February 25, 2021 Author Posted February 25, 2021 1 hour ago, Vidman said: well after updating to the new release i can now have 3 devices showing, but it seems the one i set up to test isn't triggering the scenes (Android mobile app) i will not be able the check the other two devices until i fly home in a few hours. curiously after i updated to the latest release i noticed my previous 2 devices has disappeared, was this expected? Ah crap! Its buggy AF. Hold on, I have to figure out what is happening.
chef 3811 Posted February 25, 2021 Author Posted February 25, 2021 (edited) I pushed another fix. I would remove any saved devices from the list, and recreate them. They should stick, and not duplicate. Edited February 25, 2021 by chef
bluemonkey07 590 Posted February 25, 2021 Posted February 25, 2021 installed 1.0.3.7 and restarted emby and still no devices are triggering scenes. deleted the 3 devices and reconfigured then again and still they are not triggering scenes
chef 3811 Posted February 25, 2021 Author Posted February 25, 2021 (edited) 4 hours ago, Vidman said: installed 1.0.3.7 and restarted emby and still no devices are triggering scenes. deleted the 3 devices and reconfigured then again and still they are not triggering scenes inside: "/Emby-Server/applicationdata/Plugins/configuration" folder there is a VeraHomeAutomation.xml file (this is the configuration xml) please send me a copy of that xml, and a log file from when you tried playback. not sure if you are using EmbyIntros, but we ignore intros, and only run the scene when the actual media item starts playing. Edited February 25, 2021 by chef
