fantaxp7 191 Posted May 29, 2015 Posted May 29, 2015 Is that the XML file from the configuration folder? Or is that the "extention-less" downloaded file, fanta? yea that was the extension-less one.
fantaxp7 191 Posted May 29, 2015 Posted May 29, 2015 Hmm I just followed your instructions and the reset is gone, however I was not paying attention but I think that reset message wasn't even there before following your instructions.
chef 3811 Posted May 29, 2015 Author Posted May 29, 2015 fanta, you should be able to remove the plugin, delete the "Vera Home Automation.xml" file in the "Plugins\configuration" folder and then download the new plugin from the catalog. Let me know how it goes.
MEB 27 Posted September 1, 2015 Posted September 1, 2015 Are we going to get a reverse usage? So if a scene is triggered I can have Emby pause my movie? I have a scene for my doorbell and would like Emby to pause if its rung. Or if I get a phone call can there be a integration with Android somehow to pause the video like you can with Yatse and XBMC. I miss using that feature when I switched to roku.
chef 3811 Posted September 1, 2015 Author Posted September 1, 2015 Are we going to get a reverse usage? So if a scene is triggered I can have Emby pause my movie? I have a scene for my doorbell and would like Emby to pause if its rung. Or if I get a phone call can there be a integration with Android somehow to pause the video like you can with Yatse and XBMC. I miss using that feature when I switched to roku. I like this idea, and it has been brought up before. I have to learn about luua code, but this is definitely possible. Would this be an emby plugin for the Vera dashboard then?
chef 3811 Posted September 2, 2015 Author Posted September 2, 2015 So, this Vera Plugin looks promising to get the reverse control working: https://github.com/dmlogic/vera-GenericWebService
vageesh79 1 Posted September 26, 2015 Posted September 26, 2015 Chef . Having trouble installing Vera pluging. For some reason my Veralte does not show up in Devices. It is on the same network, have tried restarting server also. Is there anything i am missing in it.
Xzener 729 Posted September 26, 2015 Posted September 26, 2015 (edited) Your Vera is not listed under "Devices", that is where the Emby clients are populated when active. Do you have a big red "X" at the top of your Vera plugin screen?? If so, try refreshing the browser. If that doesn't work, use a different browser all together. Also, try rebooting the Vera Lite too. If working correctly, there should be a picture of a Vera Lite next to the units IP address. Edited September 26, 2015 by Xzener
Xzener 729 Posted October 9, 2015 Posted October 9, 2015 @@chef the plugin isn't sensing my Xbox One anymore... Has anything changed??
chef 3811 Posted October 9, 2015 Author Posted October 9, 2015 No, I let me take a look and see If I can recreate this on Xbox one... One second...
chef 3811 Posted October 9, 2015 Author Posted October 9, 2015 (edited) @@Xzener it sees my X1 okay.. Are you able to see your X1 in the emby device list? And also are you able to see it in the DLNA "play to" list? Try restarting your Xbox. Edited October 9, 2015 by chef
chef 3811 Posted October 9, 2015 Author Posted October 9, 2015 Chef . Having trouble installing Vera pluging. For some reason my Veralte does not show up in Devices. It is on the same network, have tried restarting server also. Is there anything i am missing in it. @@vageesh79 were you able to figure out the plugin?
Xzener 729 Posted October 9, 2015 Posted October 9, 2015 (edited) Restarted my Xbox... Yes and yes to your questions. The plugin still is not seeing it. Any ideas?? Just rebooted the Vera... Nope, still not seeing it. Edited October 9, 2015 by Xzener
Xzener 729 Posted October 9, 2015 Posted October 9, 2015 Deleted the Xbox from Embys device list. Powered it up... Emby sees it just fine.
chef 3811 Posted October 9, 2015 Author Posted October 9, 2015 (edited) A couple question @xzener: In the config XML does it appear? Do other devices appear in the plugin config select box? Are you on a Dev build? Let me know.... Edited October 9, 2015 by chef 1
Xzener 729 Posted October 9, 2015 Posted October 9, 2015 Not sure about the config XML, at work ATM. Yes, other devices appear in the select box. (The Xbox is still setup in the app GUI, so I assume the XML still has it setup too) I'm on Beta Server builds.
Xzener 729 Posted October 9, 2015 Posted October 9, 2015 (edited) Fixed. Looked at the XML... It was clean, only Vera scenes populated, even though the plugin listed the Xbox as added and configured. Here is my XML file. FYI, all configured devices not working, had only checked Xbox. Deleted the XML file, restarted the Server, no change. Deleted the plugin and XML file, restarted the Server (Edge)... The plugin was still listed as installed. Opened with IE... The plugin was not listed. Installed the plugin. All running clients properly listed. Added clients, configured. Everything checks good now. Thanks for the help Chef. Edited October 9, 2015 by Xzener
Xzener 729 Posted October 9, 2015 Posted October 9, 2015 By the way, I have no clue when this broke. The Xbox is in my theater room... Don't play Xbox everyday. Noticed it playing Forza 6 waiting for Star Wars Battlefront Beta to finish downloading.
chef 3811 Posted October 9, 2015 Author Posted October 9, 2015 Yes! SW Battlefront is amazing! I am glad it is working again, really strange occurrence. Let me know if anything else pops up like that again 1
Xzener 729 Posted October 10, 2015 Posted October 10, 2015 Yes, by far the best SW game EVER!! So much fun. Have you flown and X-Wing, Walker, AT-AT, etc?? Or been killed by Darth Vader?? Lol, talk about an adrenaline rush... Like Luke Skywalker deflecting all your shots with the light saber, then Jedi jumps your ass. 1
vageesh79 1 Posted October 11, 2015 Posted October 11, 2015 @@vageesh79 were you able to figure out the plugin?Yes got it working. Thanks Sent from my SM-N910W8 using Tapatalk 1
Xzener 729 Posted November 7, 2015 Posted November 7, 2015 Here we go again... Xbone not being detected by the plugin. Its listed in the server active devices list. Unable to configure in the plugin.
Xzener 729 Posted November 7, 2015 Posted November 7, 2015 Used the fix above... Xbone is detected and configured but does not work, Vera commands not sent. MBT working fine.
chef 3811 Posted November 8, 2015 Author Posted November 8, 2015 Okay, this sounds familar. The xbox one is stubborn with giving up its uuid number (its ui). Please check the configuration XXL and see if xbox saved it's id. @@Xzener let me know... 1
