chef 3811 Posted March 28, 2015 Posted March 28, 2015 (edited) Emby sets the Scene with 'Emby Vera' Vera lite Ui5 and Ui7 Compatible Do you use Home Automation? Do you use Vera Products to trigger z-wave Device events in your home? Then try playing with this plugin. See to it that you have the Emby Device you want to use to trigger the events in your Home Automation on, and some scenes created in your Vera Device. Select your Emby Ready Network Device: Add it to the List CLick on your newly saved Device item, and start to add Vera Scenes to Media Browser Events. Remember to Press Save! Sweet, I tried to make it simple! Yep, you bloody right it might be buggy! But, I've been having so much fun with this plugin I had to share it. Tell me if you like it, or of you think it needs to be fixed. Well besides the obvious fixes which I am aware of. https://dl.dropboxusercontent.com/u/46151346/SampleProject/SampleProject/bin/Debug/Vera%20Smart%20Home%20Automation.zip Have fun. Edited April 9, 2015 by chef 7
Xzener 729 Posted March 28, 2015 Posted March 28, 2015 (edited) Chef, Congrats getting your plugin to a usable state! Although I am having issues. First of all, not sure what this is?? I successfully saved a client, but when I select it to add Vera functionality, it wont save... Here is the client after clicking "Save" and returning to it... Also, it seems I have to click "Back" twice at the Vera Dashboard page in order to get back to the main plugin menu. Edited March 28, 2015 by Xzener
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 Yeah, the radio button is going to be for ignoring music playback events.
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 (edited) So the saved playback scenes are not showing in the ui?Did you select and set up the entire room before you clicked save?I forgot to mention that you want to do that.In other words, choose all the scenes you want for all the events listed, and then press save. For example in this image, I have set up my playback Started events and Stoppped events. But have left the other two events empty before I press Save: You can delete the device entry from the main config page and start it again.I hope that is what you mean. Edited March 28, 2015 by chef
Xzener 729 Posted March 28, 2015 Posted March 28, 2015 (edited) I did not click an unused selection... I simply clicked "Black Lights Off" for the play option and clicked save. Lemme attempt it again. May I recommend a "do nonothing" added to the drop down, otherwise others will have my same issue. Edit: Just tried again... Its not saving my scenes to be used for playback triggers. Any ideas?? Edited March 28, 2015 by Xzener
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 Okay, not saving them in the ui, when you return to the page? Or not saving to the "configuration" folder xml file properly. I can not recreate this.
wraslor 70 Posted March 28, 2015 Posted March 28, 2015 (edited) I'm only using the playback paused and unpaused part but I can confirm it doesn't save the unpaused trigger but the paused trigger does save. "Edit" It does not save to the xml file nor show up in the ui. Edited March 28, 2015 by wraslor
Xzener 729 Posted March 28, 2015 Posted March 28, 2015 I cant explain it... But its working now. All I do know is Firefox in my theater room wasn't allowing the save. I logged in directly to my server, IE allowed it to save. That is all that was different. Ok... MBC, not working. I set the plugin to send the "Black Lights Off" command when playback starts, and "On" when it stops. Neither command is sent. MBT working, although my video backdrops plugin is screwing things up. When I click "Play" while a video backdrop is already playing, the black lights come on while the movie starts. I guess the plugin senses the video backdrop playback stopping, sending the "Black Lights On" command. I know this may be difficult... But is there any way to ignore the video backdrop plugin?? By the way... BRILLIANT WORK CHEF!!!! Loving it!!
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 Here, I know why your not saving properly. Once you have selected a Device on the main page, and it has been added to the main pages list of devices. Press save. Once the list of Devices has been saved on the main page, now you can click on them to enable Scene editing properly. If you don't save the main pages list before you enter the Scene editing, the scene information will not save either. I suppose I could auto save the main page...
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 (edited) I'm only using the playback paused and unpaused part but I can confirm it doesn't save the unpaused trigger but the paused trigger does save. "Edit" It does not save to the xml file nor show up in the ui. Playaback pause and Unpause might not work properly. PlaybackStart and Stop will work best at the moment. I know about this. Thank you wraslor! Edited March 28, 2015 by chef
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 (edited) So, we have found out that some of the Javascript and JQuery is not working the best in some browsers. Which means we'll have to look at the code, and write some cross browser code to make it work. I have read articles which describe things like this happening. In the meantime, perhaps it would be best to use Chrome browser which seems to be working best. And yes we can ignore Intro plugin videos... I think. Edited March 28, 2015 by chef
wraslor 70 Posted March 28, 2015 Posted March 28, 2015 (edited) Playaback pause and Unpause might not work properly. PlaybackStart and Stop will work best at the moment. I know about this. Thank you wraslor! Does it read start and stop with play and pause? What i mean is with my setup I have it set to lights off on mb start and on when you exit mb. I want it to bring the lights up half when I pause and back off when I resume. Edited March 28, 2015 by wraslor 2
chef 3811 Posted March 28, 2015 Author Posted March 28, 2015 Does it read start and stop with play and pause? What i mean is with my setup I have it set to lights off on mb start and on when you exit mb. I want it to bring the lights up half when I pause and back off when I resume. Yeas You'll have to create a scene for your lights to be dimmed half way, but Once I wire up the Pause and Unpause events, that won't be a problem.
chef 3811 Posted March 29, 2015 Author Posted March 29, 2015 Here we go! No more save button on the Main Page. the profile you choose will automatically save. at least in Chrome it will. https://dl.dropboxusercontent.com/u/46151346/SampleProject/SampleProject/bin/Debug/Vera%20Smart%20Home%20Automation.zip
chef 3811 Posted March 29, 2015 Author Posted March 29, 2015 (edited) @@wraslor !! this one handles Playback Paused and Unpaused events! https://dl.dropboxusercontent.com/u/46151346/SampleProject/SampleProject/bin/Debug/Vera%20Smart%20Home%20Automation.zip There is a small delay because there isn't actually any formal events for Playback Paused and Unpaused. So, i check the Playback Progress to see if the server is reporting a stand still in media. If it is we trigger our own event, and the same for when the media has Unpaused. This is why it wasn't wired up at first, we had to make sure we weren't polling for the wrong Progress and stuff. I'll add the awesome plugin icons that xzener made next! Edited March 29, 2015 by chef
AgileHumor 123 Posted March 29, 2015 Posted March 29, 2015 (edited) delete me, pii cleanup Edited April 17, 2015 by AgileHumor
techywarrior 689 Posted March 29, 2015 Posted March 29, 2015 Is there anything in this plugin that allows the Vera to control MB? For example, some LUA code on Vera to an HTTP receiver (no authentication) on the Emby Server to: Launch Emby for WMC Tune to Live TV Channel X Play Music Playlist Y I guess it would be mostly preconfigured "remote commands or Macros" that can be triggered from any HA system that can use an HTTP request to control Emby Server. Cheers! That would really require a plugin written for the Vera. It's a completely separate thing.
chef 3811 Posted March 29, 2015 Author Posted March 29, 2015 (edited) Sweet! Techy warrior. Even if the plugin is a little bit buggy right now, it could not have been even remotely possible with out your patients. Edited March 29, 2015 by chef
Xzener 729 Posted March 29, 2015 Posted March 29, 2015 Chef, any idea how the app could possibly ignore video backdrops?
chef 3811 Posted March 29, 2015 Author Posted March 29, 2015 (edited) Working on it. and Intros too. I think the only way to ignore video backdrops is to tell it to ignore video which has a runtime under a certain amount of ticks. I think we can ask the api how long the media file is, and then ignore short/small media files. Edited March 29, 2015 by chef
chef 3811 Posted March 29, 2015 Author Posted March 29, 2015 (edited) So you would like Vera to control mb. I think we would have to authenticate a user to allow mb to listen to more then just pubic userdto requests, but if you could give me an example of a situation you would like to control mb with Vera, I ahave learned that anything is possible when writing code. I should mention that I don't currently have a dedicated theatre room, but have the lights dim in my front room when a media item starts. I was thinking about add some specific functionality to the plugin regarding TV, movies, audio. Also perhaps time of day functions when certain scene request would be ignored by media browser. I am up for anything really. But I should mention also @@AgileHumor that current the ugin is only set up for 1 Vera device. I was wondering if people ran two. I could implement two, but just one for now I think. Edited March 29, 2015 by chef
chef 3811 Posted March 29, 2015 Author Posted March 29, 2015 (edited) Working on it. and Intros too. I think the only way to ignore video backdrops is to tell it to ignore video which has a runtime under a certain amount of ticks. I think we can ask the api how long the media file is, and then ignore short/small media files. Oh but, with intros.. Do we do we wait for the feature film to start? Or do we ignore the feature film and run the scene when the intro starts? Hmm... Or do we get super complicated and allow for a scene to run for both. Lol! Edited March 29, 2015 by chef
