Seperate Log for Library Scan info
Hi,
Straightforward request. It would be great if all the library scan, fanart updates etc could be written to a separate log.
I always try to follow "How to report a problem". But I am concerned that all of my content is iterated and logged in the "Log". Some people may have privacy issues and unless the problem reported stems from the library scan those entries provide no value.
A by product is the "log" would be much smaller and to the point.
Thanks for considering
remember to like if you want this "feature" as well
-Vicpa
  • Like 6
