aspdend 177 Posted November 12, 2013 Posted November 12, 2013 I cannot start mediabrowser server on my machine following updates to some of the plugins. I get the error message "There was a problem starting Media Browser: Index was outside the bounds of the array" This is Server version 3.0.5061.25570 Log file is as attached Any help gratefully received server-63519834548.log
aspdend 177 Posted November 12, 2013 Author Posted November 12, 2013 Anyone got any ideas at all? Am currently without mediabrowser at all until this is resolved!
ebr 16304 Posted November 12, 2013 Posted November 12, 2013 Does it start if you remove all plug-ins?
ebr 16304 Posted November 12, 2013 Posted November 12, 2013 Actually, I don't think this is related to a plug-in. @@Luke - looks like a corrupted image size dictionary cache...
aspdend 177 Posted November 12, 2013 Author Posted November 12, 2013 Does it start if you remove all plug-ins? Can't open the software to uninstall the plugins!
Solution ebr 16304 Posted November 12, 2013 Solution Posted November 12, 2013 Should probably wait for Luke to respond but, if you are desperate, deleting the file imagesizes.json in the data directory on the server, may get you going again. 1
aspdend 177 Posted November 12, 2013 Author Posted November 12, 2013 Should probably wait for Luke to respond but, if you are desperate, deleting the file imagesizes.json in the data directory on the server, may get you going again. Will try that!
aspdend 177 Posted November 12, 2013 Author Posted November 12, 2013 Yes! That worked perfectly! Than you so much for that, the wife is now happy again! 1
CashMoney 94 Posted November 12, 2013 Posted November 12, 2013 (edited) I'll try that with JBClarke's machine tomorrow. Popped down there after he'd posted yesterday but had no luck myself. He'll be very pleased to get it back. He's very new to MB, although seen it on my own system since MB2, and even though it's been only a couple of months for him with MB3, he's become very dependant on it Thanks for the fix guys, I'll let you know how it goes. Edited November 12, 2013 by CashMoney
ebr 16304 Posted November 12, 2013 Posted November 12, 2013 Okay, now we just have to figure out how it got corrupted in the first place...
aspdend 177 Posted November 13, 2013 Author Posted November 13, 2013 Okay, now we just have to figure out how it got corrupted in the first place... That was going to be my next question...
Heuer 76 Posted November 14, 2013 Posted November 14, 2013 Just happened to me - short power cut (1 or 2 seconds) if that helps.
demonseed 44 Posted November 14, 2013 Posted November 14, 2013 add me to the list of affected. and deleting the file fixed it, 2
aspdend 177 Posted November 14, 2013 Author Posted November 14, 2013 Just happened to me - short power cut (1 or 2 seconds) if that helps. I haven't had a power cut/power loss at all
yardameus 221 Posted November 14, 2013 Posted November 14, 2013 I don't know how to feel about seeing a post by demonseed and seeing he has a 0 (neutral) status. Unsettling... 1
CashMoney 94 Posted November 14, 2013 Posted November 14, 2013 Worked for jbclarke as well, thanks guys.
aspdend 177 Posted November 14, 2013 Author Posted November 14, 2013 it's fixed for the next release. Ah, OK, so it wasn't my machine as such then? that's good to know! Thanks for the prompt responses and updates!
