Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 When will the latest RC expire please ?? pretty soon
Lee 212 Posted November 19, 2013 Posted November 19, 2013 Found MB3 android folder. Last log is from Nov 4th ???
jordy 284 Posted November 19, 2013 Posted November 19, 2013 Red, never got around to installing RC5. went straight to the play store version. I see you got it figured. do you want a log?
Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 Red, never got around to installing RC5. went straight to the play store version. I see you got it figured. do you want a log? only if it still happens with 1.0.1 which should be visible shortly.
speechles 2062 Posted November 19, 2013 Posted November 19, 2013 I know what both issues are. I'll take care of them tonight Sweet. Just purchased the app. The update will be hitting play store copy? So I can just sit back and let the auto-update joy happen?
Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 Found MB3 android folder. Last log is from Nov 4th ??? can you delete all thise logs and see if a new one generates. I have no idea why logging would just stop
Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 aye. the app is far enough along now all future updates and bug fixes will be published through the store rather than side-loading
Tikuf 663 Posted November 19, 2013 Posted November 19, 2013 (edited) Do you think the monkey (on the screen shots) gives it away . Well done Red It has been a long path so happy it's now in the wild. Gotta hate typos tho Edited November 18, 2013 by Tikuf 1
Delphi 83 Posted November 19, 2013 Posted November 19, 2013 Had to run out and buy a GooglePlay Gift Card for this... Amazing Product redshirt...
Crestj 68 Posted November 19, 2013 Posted November 19, 2013 Could someone please tell me the default LAN\Wifi bitrate? I've changed mine and now get wildly different performance from my videos. Some play fine, some take ages to load and some start but the transcode is killing my server (HP Micro Server). TBH I don't really understand how to set this bitrate properly if anyone can explain that as well. Cheers!
Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 The default is 6.0 mb/s for wifi and 850 kb/s for cellular. You want to set the value as high as possible, while still remaining lower than what the network connection can sustain. If you are connected to cellular which is capable of 1.4 mb/s (for example) and have your cellular bitrate set to 10.0 mb/s... The server is going to send a 10.0 mb/s stream unaware that the network can't maintain that speed. That would cause the client to have to stop and buffer constantly. The client takes the source files bitrate into consideration when requesting streams from the server as well. If you have your cellular bitrate set to 1.4 mb/s and the source file bitrate is 4.0 mb, then the client is going to request a transcoded stream of 1.4 mb/s. Even if the file is a supported codec. The startup time is dependent on whether files are being transcoded, stream-copy or direct-streamed. Transcoding being the slowest. The reason being is that the server doesn't start streaming the video until a certain amount of segments have been created. 1
Crestj 68 Posted November 19, 2013 Posted November 19, 2013 Thanks Redshirt, looks like I'll need to test my Wifi out a bit to determine the optimum setting.
MrLinford 62 Posted November 19, 2013 Posted November 19, 2013 MediaBrowser Android client is now in the play store I'll write a full blog post about it this evening and provide thoughts as to where the client is going to go from here in terms of features and such. The play store link is here. I'd like to thank everybody for being a part of this ride. I've had a blast and I hope you guys have too. Auto-update here we come All beta/RC users must uninstall this client before installing from the store. Release apps are signed with a different security key than dev builds and the installer will complain if you try to install over top of the RC. Well done!
CBers 7554 Posted November 19, 2013 Author Posted November 19, 2013 (edited) @@Redshirt - if you have a user profile with the "Hide this user from login screens" option set, there's no option to manually login using it in the app, like there is in the Dashboard. Is it possible to add this? Also, I'm unable to uncheck the "Stay signed in" option. TIA. Edited November 19, 2013 by CBers
Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 At some point. It's on my to-do list, but not at the top.
seanbuff 1356 Posted November 19, 2013 Posted November 19, 2013 Hi Red, I'm finding that when sorting my 'Movies' by 'Date Added' and then toggling between Ascending and Descending - - the order randomly changes. This doesn't seem right. Are you able to confirm?
Redshirt 1487 Posted November 19, 2013 Posted November 19, 2013 I just tried, I'm not able to confirm that. Are you seeing it on other clients?
Jasoon 9 Posted November 19, 2013 Posted November 19, 2013 Red is there going to be another way to purchase the app? I have a Nabi 2 which is an android device but as its aimed at kids it doesn't have google play store installed on it, when the app was in development I had to side load it onto the Nabi 2
RaxPower 4 Posted November 19, 2013 Posted November 19, 2013 Thanks for the great app. Ive been using the beta versions and have been more than happy with it
Tharnax 49 Posted November 19, 2013 Posted November 19, 2013 Red is there going to be another way to purchase the app? I have a Nabi 2 which is an android device but as its aimed at kids it doesn't have google play store installed on it, when the app was in development I had to side load it onto the Nabi 2 @ Jasoon - you could try "This" to root and install Google Play. Once Google Play is installed on the Nabi and you've logged into it using your Google Play account, Google play will show up on your device list and MediaBrowser is an accepted device.
CBers 7554 Posted November 19, 2013 Author Posted November 19, 2013 (edited) You should be able to install the Play Store apk without rooting. Use something like ES FILE EXPLORER to back up the Google Play Services on your Android device, copy the backed-up apk to the Nabi and install. Edited November 19, 2013 by CBers
Tharnax 49 Posted November 19, 2013 Posted November 19, 2013 MediaBrowser Android client is now in the play store All beta/RC users must uninstall this client before installing from the store. Release apps are signed with a different security key than dev builds and the installer will complain if you try to install over top of the RC. Congratulations Redshirt!!! It's been a long process but certainly worth the work with the excellent product you have released. So many enhancements since the early pre-beta version and it has always just gotten better and better! I'm only a tinsey-bit upset because all my devices have one version or another of Media Browser on it so I can't just blast through the Google Play store and click "Install on all devices!!!"
