jbclarke 0 Posted November 12, 2013 Posted November 12, 2013 (edited) Tried to watch a film earlier and found my server wasn't running. Upon starting the server I get a window pop up saying - "There was a problem starting Media Browser: guid should contain 32 digits and 4 dashes" I've tried rebooting the PC but still get the same error. The only thing I can think of thats changed is installing the new restart plugin yesterday which I don't see how it would have made any difference. I can't get you logs because the server won't even start. Is there like a safe mode or something? Server version 3.0.5061.25570 which I believe is the latest beta. Thanks, Alan. Edited November 11, 2013 by jbclarke
ebr 16354 Posted November 12, 2013 Posted November 12, 2013 If you are getting that error, there must be at least some portion of a log...
Luke 42287 Posted November 12, 2013 Posted November 12, 2013 if no log is created check the event viewer. if that doesn't pan out, remove plugin dll's one at a time and try to start the server.
jbclarke 0 Posted November 12, 2013 Author Posted November 12, 2013 https://drive.google.com/file/d/0B5oP5NqzzfOFNE9LZ2YxRmtVa00/edit?usp=sharing Hope that works. Thanks.
jbclarke 0 Posted November 12, 2013 Author Posted November 12, 2013 (edited) Just tried renaming all the plugin.dll's to plugin.old and still same error. Also tried emptying the IBN and cache folders, no go. Edited November 11, 2013 by jbclarke
ebr 16354 Posted November 12, 2013 Posted November 12, 2013 Looks like the chapters database is corrupt. Try deleting it.
ebr 16354 Posted November 12, 2013 Posted November 12, 2013 Forget that. Looks like the same problem as here.
CBers 7571 Posted November 21, 2013 Posted November 21, 2013 (edited) I've just had this error on server startup: 2013-11-20 20:15:08.1838, Info, SqliteUserRepository, Opening C:\Users\Media\AppData\Roaming\MediaBrowser-Server\data\users.db 2013-11-20 20:15:08.8702, Info, SqliteItemRepository, Opening C:\Users\Media\AppData\Roaming\MediaBrowser-Server\data\chapters.db 2013-11-20 20:15:15.5002, Error, App, Error parsing image size cache file Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). System.FormatException at System.Guid.GuidResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument, String failureArgumentName, Exception innerException) at System.Guid.TryParseGuidWithNoStyle(String guidString, GuidResult& result) at System.Guid.TryParseGuid(String g, GuidStyles flags, GuidResult& result) at System.Guid..ctor(String g) at ServiceStack.Text.Common.DeserializeBuiltin`1.<GetParseFn>b__9(String value) at ServiceStack.Text.Common.JsReader`1.<>c__DisplayClassb`1.<GetCoreParseFn>b__7(String value) at ServiceStack.Text.Common.DeserializeDictionary`1.ParseDictionary[TKey,TValue](String value, Type createMapType, ParseStringDelegate parseKeyFn, ParseStringDelegate parseValueFn) at ServiceStack.Text.Common.DeserializeDictionary`1.ParseDictionaryType(String value, Type createMapType, Type[] argTypes, ParseStringDelegate keyParseFn, ParseStringDelegate valueParseFn) at ServiceStack.Text.Common.DeserializeDictionary`1.<>c__DisplayClass1.<GetParseMethod>b__0(String value) at ServiceStack.Text.Json.JsonReader`1.Parse(String value) at ServiceStack.Text.JsonSerializer.DeserializeFromString[T](String value) at ServiceStack.Text.JsonSerializer.DeserializeFromStream[T](Stream stream) at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromFile[T](String file) at MediaBrowser.Server.Implementations.Drawing.ImageProcessor..ctor(ILogger logger, IServerApplicationPaths appPaths, IFileSystem fileSystem, IJsonSerializer jsonSerializer) Server log. I renamed the imagesizes.json file and server restarted OK. Edited November 20, 2013 by CBers
TheKamakaZi 15 Posted November 12, 2014 Posted November 12, 2014 (edited) Hi guys, I've noticed this error popping up in my logs the past few days, unfortunately not sure how long. The server restarts just fine, but everytime it tries to initiate a library scan, it fails. Full log can be found here: http://pastebin.com/DinspsVD 2014-11-12 16:05:08.7901 Error - App: Error Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). System.FormatException at System.Guid.GuidResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument, String failureArgumentName, Exception innerException) at System.Guid.TryParseGuidWithDashes(String guidString, GuidResult& result) at System.Guid.TryParseGuid(String g, GuidStyles flags, GuidResult& result) at System.Guid..ctor(String g) at MediaBrowser.Server.Implementations.Persistence.SqliteProviderInfoRepository.<GetStatus>b__b(String i) at System.Linq.Enumerable.WhereSelectArrayIterator`2.MoveNext() at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Server.Implementations.Persistence.SqliteProviderInfoRepository.GetStatus(IDataReader reader) at MediaBrowser.Server.Implementations.Persistence.SqliteProviderInfoRepository.GetMetadataStatus(Guid itemId) at MediaBrowser.Providers.Manager.MetadataService`2.GetLastResult(IHasMetadata item) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__3d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__e1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<>c__DisplayClassd6.<<RefreshMetadataRecursive>b__d1>d__d8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__db.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__e1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__db.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Controller.Entities.Folder.<ValidateChildrenInternal>d__c2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<PerformLibraryValidation>d__57.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<ValidateMediaLibraryInternal>d__50.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<>c__DisplayClassf.<<ExecuteTask>b__e>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<Execute>d__6.MoveNext() 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory C:\Users\TheKamakaZi\AppData\Roaming\MediaBrowser-Server\data\collections 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory C:\Users\TheKamakaZi\AppData\Roaming\MediaBrowser-Server\data\playlists 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory D:\Media\MP3\Artists.new 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory F:\Media\Movies 3D 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory F:\Media\Movies HD 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory F:\Media\Movies\DVDRip 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory G:\Media\Shows\Complete 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory G:\Media\Shows\Ongoing 2014-11-12 16:05:08.7901 Info - LibraryMonitor: Watching directory C:\Users\TheKamakaZi\AppData\Roaming\MediaBrowser-Server\root 2014-11-12 16:05:08.7901 Info - App: Scan media library Failed after 0 minute(s) and 40 seconds It doesn't seem to be impacting new additions to the library, only the full scans. Any ideas? EDIT: forgot to add that I did try to remove the imagesizes.json file, but it had no effect Edited November 12, 2014 by TheKamakaZi
Rainey 2 Posted November 14, 2014 Posted November 14, 2014 I got that error when trying to call up a actor (Click on name space in movie detail) to then browser for and add a image (ImageByName) for the actor. I started getting these a few days back, but i also copied over my MB2 ImageaByName folder to my new MB3 install, so i though it might of had some different indexes or something, but now after so many others report this type of error i think it might be some other problem with the last MB Cliect update.
