XiaNYdE 13 Posted March 21, 2015 Posted March 21, 2015 (edited) I just did a fresh install on my HTPC and now for some reason my folder images for box sets aren't showing, i am just getting the default folder image, all other artwork below the boxset folder (ie for each movie in the box set) is showing fine but not the box image, even more frustrating they are showing just fine on my main pc. For the life of me i can't find what i am doing wrong, have i missed a setting somewhere, maybe an add-on, please help before i go completely insane. Using Titan BETA skin btw. EDIT: Couldn't work it out, so i ended up copying my user profile from this pc to the htpc and all is good now, no idea what happened, but oh well! Edited March 21, 2015 by XiaNYdE
bluc 21 Posted April 1, 2015 Posted April 1, 2015 (edited) If you go to box set right click edit then images find the artwork you want for boxset then set it as primary cheers Edited April 1, 2015 by bluc
