Guest asrequested Posted February 21, 2017 Posted February 21, 2017 (edited) Pass case sensitive Correct? Edited February 21, 2017 by Doofus
Guest asrequested Posted February 21, 2017 Posted February 21, 2017 Cap I too There we go. Testing now
Guest asrequested Posted February 21, 2017 Posted February 21, 2017 Played as if it were my own server. 1
PenkethBoy 2068 Posted February 21, 2017 Posted February 21, 2017 Impressive performance One minor glitch the latest Taylor swift video does not play and just get spinning circle tried a movie and an episode or two works fine 1
PrincessClevage 175 Posted February 21, 2017 Posted February 21, 2017 (edited) I have to report similar good experience, very fast and seek times are great. Testing from Australia. You should be some what careful as you are potentially giving hackers your server host name (nam\username) Thanks for the test tho, I'm stuck with 900Kb upload speed until September:-( Edited February 21, 2017 by PrincessClevage 1
pir8radio 1313 Posted February 21, 2017 Author Posted February 21, 2017 I have to report similar good experience, very fast and seek times are great. Testing from Australia. You should be some what careful as you are potentially giving hackers your server host name (nam\username) Thanks for the test tho, I'm stuck with 900Kb upload speed until September:-( What do you mean? what is (nam\username)? Honor amongst like minded peers. :-)
ozchef 3 Posted February 22, 2017 Posted February 22, 2017 Great streaming from here in Oz with casting to chromecast 1
legallink 187 Posted February 22, 2017 Posted February 22, 2017 (edited) Just a quick update, rather than testing load times and related, I tried to test the play of an entire movie, and that did not go well. I'm not sure of the issue, I tried it in both edge and chrome. @ 60 mbps, I didn't get past the 12 second mark. @30mbps, play would freeze every 20 minutes or so (I did not do a root cause analysis). The freeze at both transmission rates would require me to back out of the OSD completely and then press play again. I'm not sure what the cause was, as it would resume from when the playback froze. I don't have either of these issues on local lan playback. The above was done on a Lenovo laptop T440, over wifi, Windows 10, Edge and Chrome browswers (latest stable builds). Edited February 22, 2017 by legallink
PhyberApex 16 Posted February 22, 2017 Posted February 22, 2017 Tried some things pretty much nothing works (only get Artwork no streaming) at the moment. Maybe the load is too big I dunno ~Cheers
pir8radio 1313 Posted February 22, 2017 Author Posted February 22, 2017 Tried some things pretty much nothing works (only get Artwork no streaming) at the moment. Maybe the load is too big I dunno ~Cheers No load... weird.. What country?
PhyberApex 16 Posted February 22, 2017 Posted February 22, 2017 Germany. Did try some more after posting. Got 1-2 movies to load but most of em did not load. ~Cheers
Never_More 19 Posted February 23, 2017 Posted February 23, 2017 Very nice .. very kind of you to let us all test your server.. strange at first I thought it was mine lol. You have ALOT of the same media as I do Had no problem streaming .. sorry but I did try more than one at a time total of 3..I had to see if I could cause a lag or skipping.. not one. Even tried three access of the same movie. Playing Moana 3 computers with no problem. Not sure were you are but I'm on the west coast.. if that helps 1
sh0rty 727 Posted February 23, 2017 Posted February 23, 2017 Germany. Did try some more after posting. Got 1-2 movies to load but most of em did not load. ~Cheers No load... weird.. What country? Germany too. Every movie I tried in Browsers and Android worked yesterday. In Chrome I always set max bitrate @15Mbit. 1
pir8radio 1313 Posted February 23, 2017 Author Posted February 23, 2017 (edited) Very nice .. very kind of you to let us all test your server.. strange at first I thought it was mine lol. You have ALOT of the same media as I do Had no problem streaming .. sorry but I did try more than one at a time total of 3..I had to see if I could cause a lag or skipping.. not one. Even tried three access of the same movie. Playing Moana 3 computers with no problem. Not sure were you are but I'm on the west coast.. if that helps No problem, That is part of this test, to see what my hardware, emby, and internet can handle! Thanks for the help. @@shorty1483 I'm also curious of the response times for other countries, was the load fast like your own server or was there decent delays due to the long distance? I'm also using a CDN so most JS, CSS, and images should be cached in your country after 3 requests. Edited February 23, 2017 by pir8radio
PenkethBoy 2068 Posted February 23, 2017 Posted February 23, 2017 From the Uk - tried Arrival, The Accountant and the latency is fine On Play the background picture appear almost instantly, and movie plays within 5 seconds - you can jump say 30 minutes ahead and minimal wait time - for 1080p movies very good response Just tried Abyss and the background picture appeared but no movie and the connection appeared to lockup - as interface was unresponsive?? 1
sh0rty 727 Posted February 23, 2017 Posted February 23, 2017 (edited) No problem, That is part of this test, to see what my hardware, emby, and internet can handle! Thanks for the help. @@shorty1483 I'm also curious of the response times for other countries, was the load fast like your own server or was there decent delays due to the long distance? I'm also using a CDN so most JS, CSS, and images should be cached in your country after 3 requests. Response times are around 100-300 ms for the static stuff so it seems cloudflare does a good job. For streaming, it's an up and down, but nothing under the line. Smooth like butter, tried a large one an set browser to 50 Mbit, and it still starts after around 3-4 secs without buffering, artifacts or something else. Edit: You need more german Audio Edited February 23, 2017 by shorty1483 1
sh0rty 727 Posted February 23, 2017 Posted February 23, 2017 Just tested a bit over HTTPS and the results are as good as with plain HTTP. Btw nice one using cloudflare, more state-of-the-art is not possible
pir8radio 1313 Posted February 23, 2017 Author Posted February 23, 2017 (edited) Just tested a bit over HTTPS and the results are as good as with plain HTTP. Btw nice one using cloudflare, more state-of-the-art is not possible You and your encryption lol.... Edited February 23, 2017 by pir8radio 1
PhyberApex 16 Posted February 24, 2017 Posted February 24, 2017 Just tested a bit over HTTPS and the results are as good as with plain HTTP. Btw nice one using cloudflare, more state-of-the-art is not possible Ohhh the irony... 1
Swynol 375 Posted February 24, 2017 Posted February 24, 2017 (edited) used the HTTPS connection. loading is fine, playing was fine. all looks good. I like the branding. @@pir8radio what CSS did you use to 1. Change the Tab favicon and title from Home to Emby 2. Change the Home Title on the Webhome page to your logo? Edited February 24, 2017 by Swynol
pir8radio 1313 Posted February 25, 2017 Author Posted February 25, 2017 used the HTTPS connection. loading is fine, playing was fine. all looks good. I like the branding. @@pir8radio what CSS did you use to 1. Change the Tab favicon and title from Home to Emby 2. Change the Home Title on the Webhome page to your logo? I use nginx as a reverse proxy, it allows you to rewrite html, JS, CSS on the fly as its being passed to the client. So I can edit html without having to edit the emby html files over and over again after updates.
Swynol 375 Posted February 25, 2017 Posted February 25, 2017 i'm using nginx, are you able to share the part of the config that changes the html/css
pir8radio 1313 Posted February 25, 2017 Author Posted February 25, 2017 (edited) i'm using nginx, are you able to share the part of the config that changes the html/css Sure, You have to be using a version that includes the sub_filter module. I created a section below my regular "location" block that only applies these changes to html files. This is not my whole config so it doesnt show all of my sub filters, but basically you open your emby server and view source, find a string you want to replace then enter the replacement string. I also have a root website being served from nginx at mydomain.com so you can put your new images in a folder on the root domain mydomain.com/embyImages/xxxx.png or whatever. In my below example the first sub filter points to the new favicon, the second changes the page title, the third injects my own tracking javascript file that puts additional info into my nginx log file, like client screen width, screen height, color depth, browser language, flash version installed, emby user name, and emby client bitrate setting. BUT you can inject your own javascript to do whatever. ## HTML files only ## location ~* \.(?:html|htm)$ { proxy_pass http://127.0.0.1:8080; sub_filter '<link rel="shortcut icon" href="css/images/favicon.ico">' '<link rel="shortcut icon" href="https://mydomain.com/favicon.ico">'; sub_filter '<title>Emby</title>' '<title>New Title</title>'; sub_filter '</body>' '<script type="text/javascript" src="https://mydomain.com/scripts/tracker.js" defer></script></body>'; sub_filter_last_modified on; proxy_set_header Accept-Encoding ""; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Proxy-Cache $upstream_cache_status; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } Below is the tracker script (inside spoiler) if you are interested, you just need to create a tracker gif 1px x 1px and throw it on your webserver too. Then the includes after the image will contain all of the user info for you to pull from your logs. Your logs will contain something like this that you can report on: https://mydomain.com/web/tracker.gif?screensize=1920x1080&colordepth=24&lang=en-us&fl=24.0.0&vis=1&userId=1de587e5988caadbe5f29s03cabe4s45e0&userBitrate=60000000&r=17247852 You can then convert the userid hash to user name during the log parse. //Tracker Code 2.02 Pir8Radio function RequestTracker(visible) { var imgTracker = new Image(1, 1); imgTracker.src = "/web/tracker.gif?screensize=" + screen.width + "x" + screen.height + "&colordepth=" + screen.colorDepth + "&lang=" + (navigator.language ? navigator.language.toLowerCase() : navigator.browserLanguage.toLowerCase()) + "&fl=" + GetFlashVersion() + "&vis=" + (visible ? "1" : "0") + "&userId=" + GetEmbyuserId() + "&userBitrate=" + GetEmbyBitrate() + "&r=" + Math.random().toString().slice(2, 10); } function GetEmbyuserId() { if (localStorage.getItem("servercredentials3") === null) { return "-" } var cred3 = localStorage.getItem("servercredentials3"); var servers = JSON.parse(cred3); var EmbyuserId = servers.Servers[0].UserId; return EmbyuserId } function GetEmbyBitrate() { if (localStorage.getItem("preferredVideoBitrate") === null) { return "-" } var embyBitrate = localStorage.getItem("preferredVideoBitrate"); return embyBitrate } function GetFlashVersion() { try { if (navigator.plugins && navigator.plugins.length) { for (var i = 0; i < navigator.plugins.length; i++) if (navigator.plugins[i].name.indexOf("Shockwave Flash") != -1) { var arr = navigator.plugins[i].description.split("Shockwave Flash ")[1].replace(" r",".").replace(" d",".").replace(/\s/g,"").split("."); return arr[0] + "." + arr[1] + "." + arr[2]; } } else if (window.ActiveXObject) { var flashObj = new ActiveXObject("ShockwaveFlash.ShockwaveFlash"); if (flashObj) { var arr = flashObj.GetVariable("$version").split(" ")[1].split(","); return arr[0] + "." + arr[1] + "." + arr[2]; } } } catch (e) {} return "0"; } var isPrerendering = false; function handleVisibilityChange(evt) { if (isPrerendering && (document.webkitVisibilityState != "prerender")) { RequestTracker(true); isPrerendering = false; } } if (document.webkitVisibilityState != "prerender") RequestTracker(true); else { RequestTracker(false); isPrerendering = true; document.addEventListener("webkitvisibilitychange", handleVisibilityChange, false); } Edited February 26, 2017 by pir8radio 2
sh0rty 727 Posted February 26, 2017 Posted February 26, 2017 (edited) @@Swynol @@pir8radio tracks some diagnostics, if you just want to replace images that will survive updates, you can also just use css. I e.g. uploaded to imgur and set up the external url. Important is that you use a external image provider that has https connection. If not, you get mixed content security message by e.g. Chrome. /*-------------------------Login Logo------------------------------------------*/ .header { text-align: center; } .imgLogoIcon { height: 100px !important; content: url(https://i.imgur.com/od3W1Jp.png) !important; } /*-------------------------Home Logo------------------------------------------*/ h3.libraryMenuButtonText.headerButton img { content: url(https://i.imgur.com/od3W1Jp.png) !important; height: 35px !important; } Edited February 26, 2017 by shorty1483 2
