manf0001 4 Posted March 20, 2015 Posted March 20, 2015 Hello, Recently I had to wipe and reload my open media vault, upon set up I reinstalled Media Browser. However media browser will not load. It is activated, but the web client button doesn't highlight or when I click on the admin button it just takes me to a blank page almost like the website isn't loading. I've updated my nas software to the latest and still nothing. I've tried in the Media browser plugin to say force update but the same results happen which are nothing. When I go to the services section it shows media browser there and turned on but a Red Dot under the running column. How can I get media browser to start running so I can use it again? Thanks
thefirstofthe300 292 Posted March 20, 2015 Posted March 20, 2015 Please see http://mediabrowser.tv/community/index.php?/topic/739-how-to-report-a-problem/. Logs would be really nice.
sanderman123 0 Posted September 19, 2015 Posted September 19, 2015 Any updates on this issue? I'm currently experiencing the same problem with emby in omv running on a raspberry pi 2. Omv dashboard shows a red dot in the "running" column for emby.
Luke 42243 Posted September 19, 2015 Posted September 19, 2015 Any updates on this issue? I'm currently experiencing the same problem with emby in omv running on a raspberry pi 2. Omv dashboard shows a red dot in the "running" column for emby. This is from March. there is no known issue. Please see post #2 right above you.
tekkb 13 Posted September 20, 2015 Posted September 20, 2015 Ffmpeg does not auto download for the rpi2, like it does for amd64 i386 architectures. That is why it s not working. Once it does emby should work as the other libraries are ready to go in the plugin for the rpi2. The older pis are to weak to use with emby. Sent from my SPH-L710 using Tapatalk
