Fourdee 0 Posted December 4, 2016 Posted December 4, 2016 (edited) Hi all, Unable to install Emby-Server, due to lack of ARM packages in Debian 8 repo:https://build.opensuse.org/package/binaries/home:emby/embymagick?repository=Debian_8.0 root@DietPi:~# apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable E: Unable to correct problems, you have held broken packages. Does anyone know where I can find these packages for ARMv6+/64, or, any online docs to allow for compiling them? Also, will Emby/OpenSuse support the main ARM archs (v6+/64) and provide the required packages in the future?Thanks in advanced. Edited December 4, 2016 by Fourdee
hurricanehrndz 149 Posted December 4, 2016 Posted December 4, 2016 Hi all, Unable to install Emby-Server, due to lack of ARM packages in Debian 8 repo: https://build.opensuse.org/package/binaries/home:emby/embymagick?repository=Debian_8.0 root@DietPi:~# apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable E: Unable to correct problems, you have held broken packages. Does anyone know where I can find these packages for ARMv6+/64, or, any online docs to allow for compiling them? Also, will Emby/OpenSuse support the main ARM archs (v6+/64) and provide the required packages in the future? Thanks in advanced. We support ARM and have always supported ARM within the openSUSE repos. The distros supported are Ubuntu14.04 and openSUSE ARM. We have never supported ARM within the Debian repos because the openbuild service does not. You can use the Ubuntu14.04 repo on Debian, it should work perfectly fine.
hurricanehrndz 149 Posted December 4, 2016 Posted December 4, 2016 PS You can see all the architectures for what specific distrubtions we support here: https://build.opensuse.org/project/monitor/home:emby
Fourdee 0 Posted December 5, 2016 Posted December 5, 2016 We support ARM and have always supported ARM within the openSUSE repos. The distros supported are Ubuntu14.04 and openSUSE ARM. We have never supported ARM within the Debian repos because the openbuild service does not. You can use the Ubuntu14.04 repo on Debian, it should work perfectly fine. Thanks, ARM64: Missing packages/deps when using 14.04 repo on Debian 8: root@DietPi:~# apt-get install emby-server embymagick Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: embymagick : Depends: libjpeg8 (>= 8c) but it is not installable E: Unable to correct problems, you have held broken packages. Resolved by grabbing libjpeg8 from sid: root@DietPi:~# wget http://ftp.de.debian.org/debian/pool/main/libj/libjpeg8/libjpeg8_8d1-2_arm64.deb --2016-12-05 14:12:47-- http://ftp.de.debian.org/debian/pool/main/libj/libjpeg8/libjpeg8_8d1-2_arm64.deb Resolving ftp.de.debian.org (ftp.de.debian.org)... 141.76.2.4 Connecting to ftp.de.debian.org (ftp.de.debian.org)|141.76.2.4|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 110022 (107K) [application/x-debian-package] Saving to: ‘libjpeg8_8d1-2_arm64.deb’ libjpeg8_8d1-2_arm64.d 100%[===========================>] 107.44K --.-KB/s in 0.1s 2016-12-05 14:12:47 (718 KB/s) - ‘libjpeg8_8d1-2_arm64.deb’ saved [110022/110022] root@DietPi:~# dpkg -i libjpeg8_8d1-2_arm64.deb Selecting previously unselected package libjpeg8:arm64. (Reading database ... 16847 files and directories currently installed.) Preparing to unpack libjpeg8_8d1-2_arm64.deb ... Unpacking libjpeg8:arm64 (8d1-2) ... Setting up libjpeg8:arm64 (8d1-2) ... Processing triggers for libc-bin (2.19-18+deb8u6) ... ARMv7: Same, resolved by grabbing libjpeg8 from sid.
hurricanehrndz 149 Posted December 5, 2016 Posted December 5, 2016 Thanks, ARM64: Missing packages/deps when using 14.04 repo on Debian 8: root@DietPi:~# apt-get install emby-server embymagick Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: embymagick : Depends: libjpeg8 (>= 8c) but it is not installable E: Unable to correct problems, you have held broken packages. Resolved by grabbing libjpeg8 from sid: root@DietPi:~# wget http://ftp.de.debian.org/debian/pool/main/libj/libjpeg8/libjpeg8_8d1-2_arm64.deb --2016-12-05 14:12:47-- http://ftp.de.debian.org/debian/pool/main/libj/libjpeg8/libjpeg8_8d1-2_arm64.deb Resolving ftp.de.debian.org (ftp.de.debian.org)... 141.76.2.4 Connecting to ftp.de.debian.org (ftp.de.debian.org)|141.76.2.4|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 110022 (107K) [application/x-debian-package] Saving to: ‘libjpeg8_8d1-2_arm64.deb’ libjpeg8_8d1-2_arm64.d 100%[===========================>] 107.44K --.-KB/s in 0.1s 2016-12-05 14:12:47 (718 KB/s) - ‘libjpeg8_8d1-2_arm64.deb’ saved [110022/110022] root@DietPi:~# dpkg -i libjpeg8_8d1-2_arm64.deb Selecting previously unselected package libjpeg8:arm64. (Reading database ... 16847 files and directories currently installed.) Preparing to unpack libjpeg8_8d1-2_arm64.deb ... Unpacking libjpeg8:arm64 (8d1-2) ... Setting up libjpeg8:arm64 (8d1-2) ... Processing triggers for libc-bin (2.19-18+deb8u6) ... ARMv7:Same, resolved by grabbing libjpeg8 from sid. Glad to hear. Thank you for updating your results. What is the default jpeg library in Debian Jessie? Sent from my ONEPLUS A3000 using Tapatalk
Fourdee 0 Posted December 5, 2016 Posted December 5, 2016 Glad to hear. Thank you for updating your results. What is the default jpeg library in Debian Jessie? Sent from my ONEPLUS A3000 using Tapatalk Not entirely sure, but possibly one of the following: root@DietPi-XU4:~# apt-cache search libjpeg | grep runtime libjpeg62-turbo - libjpeg-turbo JPEG runtime library libturbojpeg1 - TurboJPEG runtime library - SIMD optimized libturbojpeg1-dbg - TurboJPEG runtime library - SIMD optimized (debugging symbols)
hurricanehrndz 149 Posted December 5, 2016 Posted December 5, 2016 I'll see if I can change to turbo Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted December 5, 2016 Posted December 5, 2016 (edited) Not entirely sure, but possibly one of the following: root@DietPi-XU4:~# apt-cache search libjpeg | grep runtime libjpeg62-turbo - libjpeg-turbo JPEG runtime library libturbojpeg1 - TurboJPEG runtime library - SIMD optimized libturbojpeg1-dbg - TurboJPEG runtime library - SIMD optimized (debugging symbols) NM. Edited December 5, 2016 by hurricanehrndz
zxvfxwing 0 Posted December 17, 2016 Posted December 17, 2016 Thank to you I can now install Emby Server on my Odroid-XU4 https://github.com/Fourdee/DietPi/issues/619 nice thread. I had to run this wget : wget ftp.de.debian.org/debian/pool/main/libj/libjpeg8/libjpeg-progs_8d-1+deb7u1_armhf.deb My odroid is running https://www.armbian.com/ distro.
clyir 0 Posted December 18, 2016 Posted December 18, 2016 (edited) Just installed the latest stable update that came out today, however when I logged into the dashboard I saw this. Version 3.1.0.0 betaA new version of Emby Server is available!Version 3.1.259 is now available for download. But when I checked the repo, emby-server-beta_3.1.259~beta.orig.tar.gz is the beta version. Why does the currently installed version have the beta tag and reporting that the beta version is available for download? Edited December 18, 2016 by clyir
hoppel118 37 Posted December 18, 2016 Posted December 18, 2016 (edited) My server reported the the following tonight: CRON-APT RUN [/etc/cron-apt/config]: Sun Dec 18 07:35:26 CET 2016CRON-APT SLEEP: 1408, Sun Dec 18 07:58:54 CET 2016CRON-APT ACTION: 3-downloadCRON-APT LINE: /usr/bin/apt-get -o Acquire::http::Dl-Limit=25 dist-upgrade -d -y -o APT::Get::Show-Upgraded=trueReading package lists...Building dependency tree...Reading state information...The following packages will be upgraded: emby-server1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 11.0 MB of archives.After this operation, 4223 kB disk space will be freed.Get:1 http://download.opensuse.org/repositories/home:/emby/Debian_8.0/ emby-server 3.1.0-9.1 [11.0 MB]Fetched 11.0 MB in 7min 0s (26.1 kB/s)Download complete and in download only mode Didn't do the update. So it's not the next stable version 3.0.9000.0 mentioned in the fast startup sync plugin thread. Greetings Hoppel Edited December 18, 2016 by hoppel118
clyir 0 Posted December 18, 2016 Posted December 18, 2016 Didn't do the update. So it's not the next stable version 3.0.9000.0 mentioned in the fast startup sync plugin thread. I don't quite understand. Are you saying version 3.0.9000.0 is the latest stable release? All the linux repos are reporting 3.1.0 as stable, 3.1.259 as beta and 3.1.6195 as dev.
hoppel118 37 Posted December 18, 2016 Posted December 18, 2016 (edited) Sorry, I don't know the latest stable version. I thought it will be "3.0.9000.0", but now my server reports the update "3.1.0-9.1". At the moment I am using "3.0.8500.0". I don't use the beta versions for my emby server. Here is written the following: https://emby.media/community/index.php?/topic/21348-emby-latest-versions/ Emby ServerWindowsPublic: v3.0.8500Beta: v3.1.257.0Dev: v3.1.6195.28581 Greetings hoppel Edited December 18, 2016 by hoppel118
clyir 0 Posted December 18, 2016 Posted December 18, 2016 (edited) Just checked the Github repo and it appears 3.1.0 is the latest stable release. I guess it's just a bug that the dashboard is reporting that it's a beta release. Edited December 18, 2016 by clyir
nwcatalyst 4 Posted December 25, 2016 Posted December 25, 2016 Just curious - my ODROID C2 seems to have some limited HW support for transcoding on the amlogic board, but on Android (seen via Kodi, here http://kodi.wiki/view/Android_hardware).I'm wondering if this will ever pan out to being able to offer better transcoding in Emby on Linux (currently using DietPi // Debian) ? Thx
Luke 42242 Posted December 25, 2016 Author Posted December 25, 2016 Just curious - my ODROID C2 seems to have some limited HW support for transcoding on the amlogic board, but on Android (seen via Kodi, here http://kodi.wiki/view/Android_hardware).I'm wondering if this will ever pan out to being able to offer better transcoding in Emby on Linux (currently using DietPi // Debian) ? Thx We already have VA API, doesn't that cover it?
nwcatalyst 4 Posted December 27, 2016 Posted December 27, 2016 Honestly I haven't enabled and tested yet. Will report back soon
Simon_rb 0 Posted December 30, 2016 Posted December 30, 2016 Hi, I can't get this to install on my raspberry Pi 3.. Got same issue as above - those two dependencies.. Tried the fix above and it still doesn't work.. Any ideas root@raspberrypi:/home/pi# sudo dpkg -i libjpeg8_8d1-2_arm64.deb dpkg: error processing archive libjpeg8_8d1-2_arm64.deb (--install): package architecture (arm64) does not match system (armhf) Errors were encountered while processing: libjpeg8_8d1-2_arm64.deb Thought mine was an arm64.. Followed the tutorials and even tried https://akosresch.wordpress.com/2016/05/11/installing-emby-server-on-raspberry-pi-3/ Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable E: Unable to correct problems, you have held broken packages. root@raspberrypi:/home/pi# uname -a Linux raspberrypi 4.4.26-v7+ #915 SMP Thu Oct 20 17:08:44 BST 2016 armv7l GNU/Linux Cheers
Luke 42242 Posted December 30, 2016 Author Posted December 30, 2016 Hi @@Simon_rb, we have our own instructions for raspberry pi on our download page, I would just use those: https://emby.media/download.html Both the docker and general debian instructions should work. let us know how it goes. thanks !
hurricanehrndz 149 Posted December 30, 2016 Posted December 30, 2016 Thank to you I can now install Emby Server on my Odroid-XU4 https://github.com/Fourdee/DietPi/issues/619 nice thread. I had to run this wget : wget ftp.de.debian.org/debian/pool/main/libj/libjpeg8/libjpeg-progs_8d-1+deb7u1_armhf.deb My odroid is running https://www.armbian.com/ distro. This should no longer be necessary.
Simon_rb 0 Posted December 30, 2016 Posted December 30, 2016 Thanks Luke - I used the Ubuntu 14.04 repos/instructions - cheers I seem to have an issue that the server crashes a min or so into scanning my library. Any ideas? 2016-12-30 19:44:27.5541 Info HttpClient: HttpClientManager GET: https://image.tmdb.org/t/p/original/pstLWDvW5gGxmNJiqbC0i5zqJFQ.jpg 2016-12-30 19:44:29.5505 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 3.1.2.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.38.7 64-Bit OS: False 64-Bit Process: False Mono: 4.6.2 (Stable 4.6.2.7/08fd525 Mon Nov 28 21:10:03 UTC 2016) Processor count: 4 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.UnauthorizedAccessException: Access to the path "/home/pi/mnt/S/Movies/Batman vs Superman Dawn of Justice (2016)/Batman vs Superman Dawn of Justice (2016).nfo" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0025f] in <8f2c484307284b51944a1a13a14c0266>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int) at Emby.Common.Implementations.IO.ManagedFileSystem.GetFileStream (System.String path, MediaBrowser.Model.IO.FileOpenMode mode, MediaBrowser.Model.IO.FileAccessMode access, MediaBrowser.Model.IO.FileShareMode share, System.Boolean isAsync) [0x00045] in <bef7798f4baf4a2cbd193bda78100cb9>:0 at MediaBrowser.XbmcMetadata.Savers.BaseNfoSaver.SaveToFile (System.IO.Stream stream, System.String path) [0x00063] in <333117a7114649b9b7c503e982597308>:0 at MediaBrowser.XbmcMetadata.Savers.BaseNfoSaver.Save (MediaBrowser.Controller.Entities.IHasMetadata item, System.Threading.CancellationToken cancellationToken) [0x00026] in <333117a7114649b9b7c503e982597308>:0 at MediaBrowser.Providers.Manager.ProviderManager+<SaveMetadata>c__async3.MoveNext () [0x001ff] in <4524d7985e294e9696ebc4a30f5a4c54>:0 System.UnauthorizedAccessException at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0025f] in <8f2c484307284b51944a1a13a14c0266>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int) at Emby.Common.Implementations.IO.ManagedFileSystem.GetFileStream (System.String path, MediaBrowser.Model.IO.FileOpenMode mode, MediaBrowser.Model.IO.FileAccessMode access, MediaBrowser.Model.IO.FileShareMode share, System.Boolean isAsync) [0x00045] in <bef7798f4baf4a2cbd193bda78100cb9>:0 at MediaBrowser.XbmcMetadata.Savers.BaseNfoSaver.SaveToFile (System.IO.Stream stream, System.String path) [0x00063] in <333117a7114649b9b7c503e982597308>:0 at MediaBrowser.XbmcMetadata.Savers.BaseNfoSaver.Save (MediaBrowser.Controller.Entities.IHasMetadata item, System.Threading.CancellationToken cancellationToken) [0x00026] in <333117a7114649b9b7c503e982597308>:0 at MediaBrowser.Providers.Manager.ProviderManager+<SaveMetadata>c__async3.MoveNext () [0x001ff] in <4524d7985e294e9696ebc4a30f5a4c54>:0 2016-12-30 19:44:30.4904 Info HttpClient: HttpClientManager GET: https://image.tmdb.org/t/p/original/uwir4SZOaXy5syDbqfC2ItkmIna.jpg
Simon_rb 0 Posted December 30, 2016 Posted December 30, 2016 What does crash mean? The Emby Server stops running, I have to restart it and when I scan my library it will stop running again.
