Huberer 0 Posted November 28, 2016 Posted November 28, 2016 (edited) @@hurricanehrndz Yes there're logs but only after installation of the stable release. At the moment there are three .txt and all of them are according to installation of v3.0.8500 (and not 3.1.239) Edit: I posted the latest .txt just to show server-63615940406.txt Edited November 28, 2016 by Huberer
Huberer 0 Posted November 28, 2016 Posted November 28, 2016 Now I could solve the problem. Here is the solution which worked for me. Thanks @@Andy777 for posting this tip.
Luke 42242 Posted November 28, 2016 Author Posted November 28, 2016 Just a heads up about some package changes coming today: https://emby.media/community/index.php?/topic/41928-linux-package-changes/ Thanks ! 1
huge 0 Posted November 30, 2016 Posted November 30, 2016 (edited) WARNING: this post will likely contain a high level of Debian and/or Emby ignorance... I'm just starting to try to install Emby on my media server, a PogoPlug V4 running Debian/Wheezy 7.11 Logged in as root, I tried: echo 'deb http://download.opensuse.org/repositories/home:/emby/Debian_7.0/ /' > /etc/apt/sources.list.d/emby-server.list apt-get update I got a GPG error which I fixed with apt-key adv --keyserver keyserver.opensuse.org --recv-keys 0A506F712A7D8A28 ...after which apt-get update seemed to complete successfully: ... Ign http://download.webmin.com sarge/contrib Translation-en Hit http://download.opensuse.org Packages Ign http://download.opensuse.org Translation-en Fetched 481 B in 27s (17 B/s) But then when I entered "apt-get install emby-server", I got the following message: Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 2.10.1) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. ...at which point I have reached the limit of my abilities to improvise a fix. Any help or advice you can offer a poor noob would be greatly appreciated. Edited December 1, 2016 by huge
Guest Posted November 30, 2016 Posted November 30, 2016 WARNING: this post will likely contain a high level of Debian and/or Emby ignorance... I'm just starting to try to install Emby on my media server, a PogoPlug V4 running Debian/Wheezy 7.11 Logged in as root, I tried: echo 'deb http://download.opensuse.org/repositories/home:/emby/Debian_7.0/ /' > /etc/apt/sources.list.d/emby-server.list apt-get update ...and got the following at the end of the usual "apt-get update" text: ... Ign http://download.webmin.com sarge/contrib Translation-en Hit http://download.opensuse.org Packages Ign http://download.opensuse.org Translation-en Fetched 481 B in 27s (17 B/s) Reading package lists... Done W: GPG error: http://download.opensuse.org Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0A506F712A7D8A28 A little googling on that error message led me to try: apt-key adv --keyserver keyserver.opensuse.org --recv-keys 0A506F712A7D8A28 ...after which apt-get update seemed to complete successfully: Ign http://download.webmin.com sarge/contrib Translation-en Hit http://download.opensuse.org Packages Ign http://download.opensuse.org Translation-en Fetched 481 B in 27s (17 B/s) But then when I entered "apt-get install emby-server", I got the following message: Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 2.10.1) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. ...at which point I have reached the limit of my abilities to improvise a fix. I'm guessing that the two problems are unrelated and that I did actually solve the GPG problem, but I could obviously be wrong. Any help or advice you can offer a poor noob would be greatly appreciated. Well i have a similar Problem. I have (or better had) emby-server running on a raspberry pi3 and i did some upgrades this morning. I noticed too late that some mono upgrades removed the emby-server package, wich is not so bad in the first place. But i can't reinstall it since it's now depending on embymagic but there is no arm build of it (yet ?), only i386 and amd64.
Guest Posted November 30, 2016 Posted November 30, 2016 Ok, it could resolve this by directly pulling the missing packages (embymagick, libembysqlite3) from the ubuntu 14.04 repo. So they are only missing in the debian repo. @huge: You might try adding a mono repo by doing: sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF echo "deb http://download.mono-project.com/repo/debian wheezy main " | sudo tee /etc/apt/sources.list.d/mono-xamarin.list apt-get update and afterwards you can get the two missing emby packages from here https://software.opensuse.org/download.html?project=home%3Aemby&package=libembysqlite3-0 and here https://software.opensuse.org/download.html?project=home%3Aemby&package=embymagick (use the link on the bottom of the page to get the packages directly) i'm guessing the *armhf packages might work for you es well
hurricanehrndz 149 Posted November 30, 2016 Posted November 30, 2016 There is no arm repo for debian. Only Ubuntu. Please check which arch and distros we support here: https://build.opensuse.org/project/monitor/home:emby
hurricanehrndz 149 Posted November 30, 2016 Posted November 30, 2016 WARNING: this post will likely contain a high level of Debian and/or Emby ignorance... I'm just starting to try to install Emby on my media server, a PogoPlug V4 running Debian/Wheezy 7.11 Logged in as root, I tried: echo 'deb http://download.opensuse.org/repositories/home:/emby/Debian_7.0/ /' > /etc/apt/sources.list.d/emby-server.list apt-get update ...and got the following at the end of the usual "apt-get update" text: ... Ign http://download.webmin.com sarge/contrib Translation-en Hit http://download.opensuse.org Packages Ign http://download.opensuse.org Translation-en Fetched 481 B in 27s (17 B/s) Reading package lists... Done W: GPG error: http://download.opensuse.org Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0A506F712A7D8A28 A little googling on that error message led me to try: apt-key adv --keyserver keyserver.opensuse.org --recv-keys 0A506F712A7D8A28 ...after which apt-get update seemed to complete successfully: Ign http://download.webmin.com sarge/contrib Translation-en Hit http://download.opensuse.org Packages Ign http://download.opensuse.org Translation-en Fetched 481 B in 27s (17 B/s) But then when I entered "apt-get install emby-server", I got the following message: Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 2.10.1) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. ...at which point I have reached the limit of my abilities to improvise a fix. I'm guessing that the two problems are unrelated and that I did actually solve the GPG problem, but I could obviously be wrong. Any help or advice you can offer a poor noob would be greatly appreciated. Seems to me like you should be using the 14.04 repo since pogo plug is an arm based device.
huge 0 Posted November 30, 2016 Posted November 30, 2016 (edited) Seems to me like you should be using the 14.04 repo since pogo plug is an arm based device. Thanks for your replies! I'm going to make extra sure I understand, since I'm pretty new at this. Gronkdalonka also sent me a PM saying that I might try the Ubuntu repo (as a temporary workaround), and gave me the command I should use. So if I'm understanding correctly, I should enter: sudo "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' > /etc/apt/sources.list.d/emby-ubuntu.list" ...and then try to install emby-server again. Is that correct? Do I need to do anything else? thanks again to both of you -huge [edit: the link is getting abbreviated in the forum - download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ ] Edited November 30, 2016 by huge
hurricanehrndz 149 Posted November 30, 2016 Posted November 30, 2016 Should be correct. Always check the install instructions on here: https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server
huge 0 Posted November 30, 2016 Posted November 30, 2016 (edited) Thanks for the quick replies! Unfortunately it did not make any difference. I tried both echo 'deb http://download.opensuse.org/repositories/home:/emby/Debian_7.0/ /' > /etc/apt/sources.list.d/emby-ubuntu.list and then echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list ...after each one I tried to install emby-server again, with the same result: root@PogoV4Debian:~# apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 2.10.1) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Do I need to do something different with emby-server.list or emby-ubuntu.list? Thanks very much for helping me with this. Edited November 30, 2016 by huge
hurricanehrndz 149 Posted November 30, 2016 Posted November 30, 2016 Thanks for the quick replies! Unfortunately it did not make any difference. I tried both echo 'deb http://download.opensuse.org/repositories/home:/emby/Debian_7.0/ /' > /etc/apt/sources.list.d/emby-ubuntu.list and then echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list ...after each one I tried to install emby-server again, with the same result: root@PogoV4Debian:~# apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 2.10.1) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Do I need to do something different with emby-server.list or emby-ubuntu.list? Thanks very much for helping me with this. You don't need the debian repo whatsoever. There is no debian arm repo. Please also ensure you are running apt-get update first.
huge 0 Posted November 30, 2016 Posted November 30, 2016 (edited) You don't need the debian repo whatsoever. There is no debian arm repo. Please also ensure you are running apt-get update first. Thanks for your guidance (and patience) ... I *think* I'm following your suggestions correctly now, but still getting the same result (a bunch of unmet dependencies). Here's the whole log: root@PogoV4Debian:~# echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' > /etc/apt/sources.list.d/emby-server.list root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# ls /etc/apt/sources.list.d/ . .. emby-server.list root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# cat /etc/apt/sources.list.d/* deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ / root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# apt-get update Hit http://download.webmin.com sarge Release.gpg Hit http://ftp.us.debian.org wheezy Release.gpg Hit http://security.debian.org wheezy/updates Release.gpg Hit http://ftp.us.debian.org wheezy Release Hit http://security.debian.org wheezy/updates Release Hit http://download.webmin.com sarge Release Hit http://download.opensuse.org Release.gpg Hit http://download.opensuse.org Release Hit http://ftp.us.debian.org wheezy/main armel Packages Hit http://ftp.us.debian.org wheezy/main Translation-en Hit http://security.debian.org wheezy/updates/main armel Packages Hit http://security.debian.org wheezy/updates/contrib armel Packages Hit http://security.debian.org wheezy/updates/non-free armel Packages Hit http://security.debian.org wheezy/updates/contrib Translation-en Hit http://security.debian.org wheezy/updates/main Translation-en Hit http://download.webmin.com sarge/contrib armel Packages Hit http://security.debian.org wheezy/updates/non-free Translation-en Hit http://download.opensuse.org Packages Ign http://download.webmin.com sarge/contrib Translation-en Ign http://download.opensuse.org Translation-en Reading package lists... Done root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libc6 (>= 2.19) but 2.13-38+deb7u11 is to be installed or libc6.1 (>= 2.19) but it is not installable or libc0.1 (>= 2.19) but it is not installable Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. root@PogoV4Debian:~# root@PogoV4Debian:~# Is there any reason to try an earlier or later version of Ubuntu? The installation page for Emby on Ubuntu list separate instructions for xUbuntu 12.04, 14.04, 16.04, 16.10 and "Next", but you specifically pointed me at 14.04 so I'm guessing that was the right one to go with. Edited November 30, 2016 by huge
hurricanehrndz 149 Posted November 30, 2016 Posted November 30, 2016 Look at the architectures support by each distribution. What type of processor are you using. Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted December 1, 2016 Posted December 1, 2016 https://build.opensuse.org/package/binaries/home:emby/mono_4?repository=xUbuntu_14.04 try just installing mono for now Sent from my ONEPLUS A3000 using Tapatalk
huge 0 Posted December 1, 2016 Posted December 1, 2016 (edited) Look at the architectures support by each distribution. What type of processor are you using. Sent from my ONEPLUS A3000 using Tapatalk Architecture: ARMv5te Processor: Marvell Kirkwood 800MHz I see very few references to ARMv5 in the forums here. This page on opensuse.org has several entries for ARMv6 & ARMv7, but no ARMv5 and of course no mention of Pogoplug. Not sure if that means I'm facing too steep of a challenge for my minimal expertise level. https://build.opensuse.org/package/binaries/home:emby/mono_4?repository=xUbuntu_14.04 try just installing mono for now Sent from my ONEPLUS A3000 using Tapatalk Likewise that page has a section on ARMv7l but no reference to ARMv5. I'm worried I'm going to swamp you with my ignorance, but I'm not sure how to "try just installing mono for now" - I did try just apt-get install mono-runtime, which failed with one unmet dependency: root@PogoV4Debian:~# apt-get install mono-runtime Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: mono-runtime : Depends: mono-gac (= 2.10.8.1-8+deb7u1) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Edited December 1, 2016 by huge
hurricanehrndz 149 Posted December 1, 2016 Posted December 1, 2016 Run apt-get -f install Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted December 1, 2016 Posted December 1, 2016 I don't think we support armv5 Sent from my ONEPLUS A3000 using Tapatalk
huge 0 Posted December 1, 2016 Posted December 1, 2016 I don't think we support armv5 OK ... does that mean I should just stop trying because it'll never work, or maybe I can patch it together by installing things manually? Or I guess there's a 3rd possibility, that someone with more linux skills could patch it together but I should probably stop before I break everything. Run apt-get -f install Assuming the answer above is not "OMG stop now you'll never make it work!!!" ... Do you mean "apt-get -f install mono-runtime"? (I had tried that already - same failure with one unmet dependency on mono-gac) Even if the end result is that I can't do what I'm trying to do, I really appreciate you taking the time to dig into this and help me. Thanks, -huge
hurricanehrndz 149 Posted December 1, 2016 Posted December 1, 2016 Run uname -a Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted December 1, 2016 Posted December 1, 2016 I never said it is impossible anything is possible. You need to figure out how to get mono installed. If you can get mono running the rest is easy. Sent from my ONEPLUS A3000 using Tapatalk
huge 0 Posted December 1, 2016 Posted December 1, 2016 I never said it is impossible anything is possible. You need to figure out how to get mono installed. If you can get mono running the rest is easy. Cool, thanks ... I'll keep trying... Run uname -a root@PogoV4Debian:~# uname -a Linux PogoV4Debian 3.18.5-kirkwood-tld-1 #1 PREEMPT Thu Feb 5 17:58:07 PST 2015 armv5tel GNU/Linux
hurricanehrndz 149 Posted December 1, 2016 Posted December 1, 2016 I would suggest you create a topic with the model name of the device and the cpu in the topic Sent from my ONEPLUS A3000 using Tapatalk
huge 0 Posted December 2, 2016 Posted December 2, 2016 I would suggest you create a topic with the model name of the device and the cpu in the topic Sent from my ONEPLUS A3000 using Tapatalk Finally got to write a new post: https://emby.media/community/index.php?/topic/42094-pogoplug-v4-armv5tel-problems-installing-mono/ Thank you so much for your help...
