hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Hmm, just leave them for now. I will run more test Sent from my D6603 using Tapatalk
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 Hmm, just leave them for now. I will run more test OK. Thank you. I just ran: sudo service emby-server start and got: emby-server: unrecognized service
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 lol strange, okay well what exactly was the installation command you ran?
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 lol strange, okay well what exactly was the installation command you ran? I'm following the instructions here: https://emby.media/downloads/linux-server/
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 (edited) Yeah okay, those are old and haven't been updated, so yes uninstall those packages. Then just do a sudo apt-get install emby-server libsqlite-dev and report back. apt-get remove --purge. We did a major update this week. We are sort of in a testing phase and trying to see what is left to fix from all the changes. Edited December 5, 2015 by hurricanehrndz
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 (edited) Yeah okay, those are old and haven't been updated, so yes uninstall those packages. Then just do a sudo apt-get install emby-server libsqlite-dev and report back. apt-get remove --purge. We did a major update this week. We are sort of in a testing phase and trying to see what is left to fix from all the changes. Well, I seemed to have successfully removed one of the pkgs, but trying to remove the "common" one got me: dpkg -r imagemagick-common dpkg: dependency problems prevent removal of imagemagick-common: libmagickcore-6.q8-2:amd64 depends on imagemagick-common (= 8:6.9.1-2). libmagickwand-6.q8-2:amd64 depends on imagemagick-common (= 8:6.9.1-2). dpkg: error processing imagemagick-common (--remove): dependency problems - not removing Errors were encountered while processing: imagemagick-common So not sure what's going on there. Do I have to also get rid of these: libmagic1:amd64 5.11-2+deb7u8 amd64 File type determination library using "magic" numbers libmagickcore-6.q8-2:amd64 8:6.9.1-2 amd64 low-level image manipulation library -- quantum depth Q8 libmagickcore-6.q8-2-extra:amd64 8:6.9.1-2 amd64 low-level image manipulation library - extra codecs (Q8) libmagickwand-6.q8-2:amd64 8:6.9.1-2 amd64 image manipulation library And when you write: Then just do a sudo apt-get install emby-server libsqlite-dev and report back. apt-get remove --purge. is there an order to those commands? Do sudo apt-get install emby-server libsqlite-dev first and then apt-get remove --purge or vice versa? Really sorry to be such a PITA! Thanks very much for your patience. Edited December 5, 2015 by nicheplayer
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 No worries. I'm happy to help. I would run the following in the this order: sudo apt-get remove --purge libmagickwand-6.q8-2 libmagickcore-6.q8-2 imagemagick-common emby-server If that is successful sudo apt-get install emby-server
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 All right, ran the first line and got this: sudo apt-get remove --purge libmagickwand-6.q8-2 libmagickcore-6.q8-2 imagemagick-common emby-server Reading package lists... Done Building dependency tree Reading state information... Done Package 'emby-server' is not installed, so not removed The following packages were automatically installed and are no longer required: libdjvulibre-text libdjvulibre21 libfftw3-3 libilmbase6 liblqr-1-0 libnetpbm10 libopenexr6 libwebp5 libwmf0.2-7 netpbm Use 'apt-get autoremove' to remove them. The following packages will be REMOVED: imagemagick-common* libmagickcore-6.q8-2* libmagickcore-6.q8-2-extra* libmagickwand-6.q8-2* 0 upgraded, 0 newly installed, 4 to remove and 83 not upgraded. 70 not fully installed or removed. After this operation, 8,609 kB disk space will be freed. Do you want to continue [Y/n]? Y Proceeded, got a bunch of output, and ended up at a prompt, but no error message there. So...try your second line of code now?
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 Actually, there was one error along the way: adduser: Warning: The home directory `/var/lib/colord' does not belong to the user you are currently creating.
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Yes, and do you mind waiting a couple of minutes. I got to push an update to fix some issues.
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 Yes, and do you mind waiting a couple of minutes. I got to push an update to fix some issues. Of course. I'll wait as long as you like. Thanks again.
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Okay I will address that issue as well for now.
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 What command have you run by the way?
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 What command have you run by the way? You mean what's the last one I ran? It was: sudo apt-get remove --purge libmagickwand-6.q8-2 libmagickcore-6.q8-2 imagemagick-common emby-server
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Okay awesome, for now since I see you have some issues with your packages run the following: apt-get -f install apt-get autoremove apt-get clean 1
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 Here's the output: apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libdjvulibre-text libdjvulibre21 libfftw3-3 libilmbase6 liblqr-1-0 libnetpbm10 libopenexr6 libwebp5 libwmf0.2-7 netpbm Use 'apt-get autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 83 not upgraded. root:~# apt-get autoremove Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be REMOVED: libdjvulibre-text libdjvulibre21 libfftw3-3 libilmbase6 liblqr-1-0 libnetpbm10 libopenexr6 libwebp5 libwmf0.2-7 netpbm 0 upgraded, 0 newly installed, 10 to remove and 83 not upgraded. After this operation, 13.7 MB disk space will be freed. Do you want to continue [Y/n]? Y (Reading database ... 54667 files and directories currently installed.) Removing libdjvulibre21 ... Removing libdjvulibre-text ... Removing libfftw3-3:amd64 ... Removing libopenexr6 ... Removing libilmbase6 ... Removing liblqr-1-0:amd64 ... Removing netpbm ... Removing libnetpbm10 ... Removing libwebp5:amd64 ... Removing libwmf0.2-7:amd64 ... Processing triggers for man-db ... Processing triggers for libgdk-pixbuf2.0-0:amd64 ... root:~# apt-get clean root:~#
nicheplayer 8 Posted December 5, 2015 Posted December 5, 2015 perfect. So I'm standing by for sudo apt-get install emby-server ?
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Yes... I will let you know once its ready.
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Okay I have initiated a new build, once its done run the install command and you should be ready to go: Please look here to see once it's done https://build.opensuse.org/package/show/home:emby/emby-server 1
Tessla 0 Posted December 8, 2015 Posted December 8, 2015 I just tried to install on a remote server running Debian 7 using the instructions at the Emby site and got as far as sudo apt-get install emby-server before hitting this: Errors were encountered while processing: /var/cache/apt/archives/libembymagickcore-6.q8-2_8%3a6.9.2-8_amd64.deb /var/cache/apt/archives/libembymagickwand-6.q8-2_8%3a6.9.2-8_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Thoughts? Thanks! Hello, I have the same problem there is a solution. thanks.
nicheplayer 8 Posted December 8, 2015 Posted December 8, 2015 Hello, I have the same problem there is a solution. thanks. Take a look at page 6 of the comments on this thread. It gets good right about here.
Tessla 0 Posted December 8, 2015 Posted December 8, 2015 (edited) Take a look at page 6 of the comments on this thread. It gets good right about here. profit not make it work, thanks for the tip. PD: I am using a translator. my English is bad already is solved, thanks Edited December 8, 2015 by Tessla
Guest Posted December 28, 2015 Posted December 28, 2015 Could it be that the recent beta only listens on IPv6? I can't connect any more... Here's my netstat: root@svr:/# netstat -lpn | grep mono tcp6 0 0 :::8096 :::* LISTEN 12972/mono-sgen tcp6 0 0 :::8920 :::* LISTEN 12972/mono-sgen udp 0 0 127.0.0.1:46124 0.0.0.0:* 12972/mono-sgen udp 0 0 192.168.1.10:1900 0.0.0.0:* 12972/mono-sgen udp 0 0 127.0.0.1:1900 0.0.0.0:* 12972/mono-sgen udp 0 0 0.0.0.0:1900 0.0.0.0:* 12972/mono-sgen udp 0 0 192.168.1.10:55610 0.0.0.0:* 12972/mono-sgen udp 0 0 192.168.1.10:43332 0.0.0.0:* 12972/mono-sgen udp 0 0 0.0.0.0:7359 0.0.0.0:* 12972/mono-sgen udp 0 0 127.0.0.1:48609 0.0.0.0:* 12972/mono-sgen How can i re-enable listening on v4 again?
Luke 42242 Posted December 28, 2015 Author Posted December 28, 2015 Could it be that the recent beta only listens on IPv6? I can't connect any more... Here's my netstat: root@svr:/# netstat -lpn | grep mono tcp6 0 0 :::8096 :::* LISTEN 12972/mono-sgen tcp6 0 0 :::8920 :::* LISTEN 12972/mono-sgen udp 0 0 127.0.0.1:46124 0.0.0.0:* 12972/mono-sgen udp 0 0 192.168.1.10:1900 0.0.0.0:* 12972/mono-sgen udp 0 0 127.0.0.1:1900 0.0.0.0:* 12972/mono-sgen udp 0 0 0.0.0.0:1900 0.0.0.0:* 12972/mono-sgen udp 0 0 192.168.1.10:55610 0.0.0.0:* 12972/mono-sgen udp 0 0 192.168.1.10:43332 0.0.0.0:* 12972/mono-sgen udp 0 0 0.0.0.0:7359 0.0.0.0:* 12972/mono-sgen udp 0 0 127.0.0.1:48609 0.0.0.0:* 12972/mono-sgen How can i re-enable listening on v4 again? Can you please provide the full server log? thanks.
