pr3dict 33 Posted August 1, 2017 Posted August 1, 2017 Is there not a debian release of 3.2.26.0 yet?
Jdiesel 1435 Posted August 1, 2017 Posted August 1, 2017 Is there not a debian release of 3.2.26.0 yet? Yes there should be a release available. You may wish to run sudo apt-get update and check that your Emby repository key has not expired. If it has follow the install directions again for adding the key. https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server 1
pr3dict 33 Posted August 1, 2017 Posted August 1, 2017 Thank you! I needed to update my key. That worked! Yes there should be a release available. You may wish to run sudo apt-get update and check that your Emby repository key has not expired. If it has follow the install directions again for adding the key. https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server 1
lpt2007 0 Posted September 2, 2017 Posted September 2, 2017 (edited) I try to install emby on armbian (debian 8.9) and I get error: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages.The following packages have unmet dependencies: emby-server : Can somebody help? Edited September 2, 2017 by lpt2007
nicheplayer 8 Posted September 21, 2017 Posted September 21, 2017 Thank you! I needed to update my key. That worked! I’m running Debian 7 and am getting the KEYEXPIRED error. So do I run this: wget -nv https://download.opensuse.org/repositories/home:emby/Debian_7.0/Release.key -O Release.key apt-key add - < Release.key apt-get update before I try apt-get update again? Here’s the contents of my sources.list file, for reference: # # deb cdrom:[Debian GNU/Linux 7.0.0 _Wheezy_ - Official amd64 CD Binary-1 20130504-14:44]/ wheezy main #deb cdrom:[Debian GNU/Linux 7.0.0 _Wheezy_ - Official amd64 CD Binary-1 20130504-14:44]/ wheezy main deb http://ftp.us.debian.org/debian/ wheezy main non-free deb-src http://ftp.us.debian.org/debian/ wheezy main non-free deb http://security.debian.org/ wheezy/updates main non-free deb-src http://security.debian.org/ wheezy/updates main non-free # wheezy-updates, previously known as 'volatile' deb http://ftp.us.debian.org/debian/ wheezy-updates main non-free deb-src http://ftp.us.debian.org/debian/ wheezy-updates main non-free deb http://ppa.launchpad.net/jcfp/ppa/ubuntu precise main deb https://apt.sonarr.tv/ master main
Luke 42242 Posted September 22, 2017 Author Posted September 22, 2017 hi @@nicheplayer What you basically will do is go back to the install page for your distro, and follow the steps to add the key again. In this case wget -nv https://download.opensuse.org/repositories/home:emby/Debian_7.0/Release.key -O Release.key apt-key add - < Release.key apt-get update After that you should be able to perform your regular update. Please let us know if this helps. Thanks ! 1
nicheplayer 8 Posted September 22, 2017 Posted September 22, 2017 hi @@nicheplayer Please let us know if this helps. Thanks ! It did indeed! Thanks!
Luke 42242 Posted October 2, 2017 Author Posted October 2, 2017 For those who would like to help test emby server running on .net core, we have debian packages available for testing: https://emby.media/community/index.php?/topic/50012-emby-server-for-net-core/ Just jump right into that discussion. Thanks !
superforno 0 Posted October 9, 2017 Posted October 9, 2017 I try to install emby on armbian (debian 8.9) and I get error: Can somebody help? I'm in the same situation, can everybody help me?
Luke 42242 Posted October 9, 2017 Author Posted October 9, 2017 I'm in the same situation, can everybody help me? hi @@superforno, can you show us the exact error message you're getting? thanks.
superforno 0 Posted October 9, 2017 Posted October 9, 2017 hi @@superforno, can you show us the exact error message you're getting? thanks. Sure! Here it is! The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. After this I've also tried with apt-get install -f but nothing changed.
superforno 0 Posted October 17, 2017 Posted October 17, 2017 Hi @Luke could be possible that these errors are generated because I am on a i386 arch? I've seen in the repo that libembysqlite and embymagik are available only for amd64 arch...Thanks! Sure! Here it is! The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. After this I've also tried with apt-get install -f but nothing changed.
hurricanehrndz 149 Posted October 20, 2017 Posted October 20, 2017 Hi @Luke could be possible that these errors are generated because I am on a i386 arch? I've seen in the repo that libembysqlite and embymagik are available only for amd64 arch... Thanks! I suspect you have added the wrong repo. From your posts so far I discern that you are on arm cpu, as soon you really should be following the sticky: https://emby.media/community/index.php?/topic/43166-arm-devices-official-instructions/
superforno 0 Posted October 23, 2017 Posted October 23, 2017 I suspect you have added the wrong repo. From your posts so far I discern that you are on arm cpu, as soon you really should be following the sticky: https://emby.media/community/index.php?/topic/43166-arm-devices-official-instructions/ Nope, maybe my first quote mislead this. I'm on a 32bit Intel system. I've resolved Mono errors installing Mono directly but still having these: Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable
civilmann 0 Posted November 19, 2017 Posted November 19, 2017 What happened to the different install packages for Linux for Debian? The one I now get does not work with Webmin. The last update I installed was named emby-server_3.2.33.0+59.1_all.deb . The only download I'm able to get now is named emby-server-deb_3.2.36.0_amd64.deb . It is much larger and does not work properly with Webmin. Can anyone direct me to the old style download page? Very confusing.
Luke 42242 Posted November 19, 2017 Author Posted November 19, 2017 @@civilmann, what exactly is the problem that you're having? Thanks.
civilmann 0 Posted November 20, 2017 Posted November 20, 2017 Luke, would just like to get the options or choices like I used to get i.e. betas Debian 7 ,8 ,9 so on. This new package is not working the way the old ones were. I'm not a Linux expert. The old packages worked great with Webmin management. No command line stuff. I don't see any options to get to the packages the way the site used to be laid out. What changed? Can we still get those package options via ftp or something?
Luke 42242 Posted November 20, 2017 Author Posted November 20, 2017 There is a direct link to the .deb binary on the website. If you can download it that way, how would ftp be better for you? Sorry I'm a little unsure of what your issue actually is. We never had an ftp and we always had terminal commands that needed to be executed to install.
SkyBehind 23 Posted November 20, 2017 Posted November 20, 2017 Luke, would just like to get the options or choices like I used to get i.e. betas Debian 7 ,8 ,9 so on. This new package is not working the way the old ones were. I'm not a Linux expert. The old packages worked great with Webmin management. No command line stuff. I don't see any options to get to the packages the way the site used to be laid out. What changed? Can we still get those package options via ftp or something? I have webmin, but I don't use it to install the server. How exactly is it not working? How are you trying to install and what error are you getting? It's pretty easy to install on the command line though, it's two commands. If it's easier, you can just download it on your computer and then use Webmin's file browser to upload the file to the server from your computer.
civilmann 0 Posted November 20, 2017 Posted November 20, 2017 Well, tried the command line and now nothing works. I had a system for upgrading it worked well now it is trashed. The new version wrote a new .conf file now the server won't start. Tried to go back because that always worked before now that it trashed too. I use Turnkey Linux based on Debian 8.0 it has worked well for me for over a year now it is junk. I don't understand why change something that worked so well. Is this new package all the Debian releases rolled up in one? Why is it 4 times the size of previous packages? Wher can we get the different versions for different releases of Debian do the not exist anymore? I guess now we going to have to upload a bunch of error messages and back and forth ... it is exhausting!
Luke 42242 Posted November 20, 2017 Author Posted November 20, 2017 It is larger because it now has zero dependencies. We have dropped the mono runtime in favor of Microsoft's new .NET Core runtime, which is lighter and has major performance improvements that you can read about here: https://blogs.msdn.microsoft.com/dotnet/2017/08/14/announcing-net-core-2-0/ Even better, the .NET Core runtime is small enough that we can bundle it into the package so that there are no longer any external dependencies, so that's what we've done.
SkyBehind 23 Posted November 20, 2017 Posted November 20, 2017 Well, tried the command line and now nothing works. I had a system for upgrading it worked well now it is trashed. The new version wrote a new .conf file now the server won't start. Tried to go back because that always worked before now that it trashed too. I use Turnkey Linux based on Debian 8.0 it has worked well for me for over a year now it is junk. I don't understand why change something that worked so well. Is this new package all the Debian releases rolled up in one? Why is it 4 times the size of previous packages? Wher can we get the different versions for different releases of Debian do the not exist anymore? I guess now we going to have to upload a bunch of error messages and back and forth ... it is exhausting! I had trouble upgrading too. I used a procedure listed in the forum and that didn't help. What I ended up doing was using the backup plugin to backup Emby. Uninstall Emby >> sudo apt remove Emby Remove the Emby repository from apt, don't remember where off the top of my head, you can use the file manage in Webmin to browse to it (think it's under /etc/apt/sources or something like that). Reboot Install using the instructions for Linux Restore Backup Done - easy peasy (lemon squeezy)
civilmann 0 Posted November 22, 2017 Posted November 22, 2017 Ok, well somehow got emby running but when I look at my library no content! Have tried several times to delete and recreate but nothing seems to help. Could it be a permissions issue, or is something else is wrong? Please, anyone help? I would just like my emby back!
Luke 42242 Posted November 22, 2017 Author Posted November 22, 2017 @@civilmann do your libraries show up in emby library setup? thanks.
