Flirc + Harmony Ultimate + MBC + MPC-HC
JustEric78
Just curious if anyone out there has a setup similar to the topic? I got a Flirc since my Imon had lots of problems and I got sick of playing with it. Curious to know what profiles you all are using in your Harmony. I know they have an XBMC profile and I guess I can change the controls around in MPC so that they work. I guess that might be the best option, any comments or help appreciated.
MSattler
I use just on normal Harmony's and for me most of the playback controls for MBC work for MPC, I believe I had to add ffwd and rewind within MPC.  Somewhere there is a document on best settings for MPC with MBS, which is what I followed.
JustEric78
Thanks for the reply. I ended up using the XBMC profile and just adjusted some of their keys I will never use.  I think I was ready for it to be more of a battle which is why I posted but Flirc is pretty amazing. No fuss just hit the keyboard strokes and then the remote and you are done. I am very happy! So much better then that Imon garbage. Now I need to figure out how to navigate through netflix with a remote for my wife and I am done.. I think its going to require a keyboard though :(
