Airbender 128 Posted November 10, 2013 Posted November 10, 2013 hello I need to buy a eSATA 6Gb/s PCIe 2.0 x2 RAID Controller with Port Port Multiplier JOBD for more detail please look at http://mediabrowser.tv/community/index.php?/topic/940-storage-enclosure-system-vs-nas/page-3 My New unit is:Sans Digital 8-Bay eSATA RAID 0/1/10/5/JBOD Tower Storage Enclosure w/ 6G PCIe Card TR8M+B (Black)TR8M+B8 x Hard Drive TraysPower Cord2 x eSATA CableRR622 Dual-Port eSATA 6Gb/s PCIe 2.0 x1 RAID ControllerSans Digital 8-Bay eSATA RAID 0/1/10/5/JBOD Tower Storage Enclosure w/ 6G PCIe Card TR8M+B (Black) - Newegg.comalso not to forgot to say this unit work as : Drive Bays eSATA 6Gbps (via Port Multiplier) 8 Bay SATA to eSATA (Port Multiplier) JBOD EncHere are DropBox Screenshots:https://www.dropbox.com/sh/coiweqm8rmb9d95/4hEDFmPtyA i think i know where the problem could be it is either the Controller card driver or controller card by it self. This unit used eSATA 6Gbps (via Port Multiplier) Motherboard:ASUS M5A97 Evo - AM3+ - 970 - SATA 6Gbps and USB 3.0 - ATX AMD ATX DDR3 2133 Motherboards so by buying a new card i might be able to fix my issue so i need someone who know this stuff to recommend me or advise on what card to get or if this is a good idea or not Thank you very much
Airbender 128 Posted November 12, 2013 Author Posted November 12, 2013 Hello I would consider this issue resolved as i found a card replacement http://www.newegg.com/Product/Product.aspx?Item=N82E16815287017&Tpk=Vantec%20UGT-ST622%20card Thanks
Airbender 128 Posted November 30, 2013 Author Posted November 30, 2013 Hello Issue resolved got RR642L Card and it worked
