ksullivan86 3 Posted March 17, 2015 Posted March 17, 2015 on several setting configuration pages (playon plugin config page, users profile config page. Error pops up any time I try to save setting I am getting the error code: "guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx)." I think this was caused when I imported a backup of everything, please help its really had to administer the server with out being able to save. Thanks -Kevin 2015-03-16 19:30:58.3608 Error - HttpServer: Error processing request for /mediabrowser//Plugins/ed9e051b-133e-47fd-90ad-44f2e83516f7/Configuration *** Error Report *** Version: 3.0.5518.7 Command line: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kevin\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). ServiceStack.HttpError server-63562085211.txt
ebr 16307 Posted March 17, 2015 Posted March 17, 2015 Sounds like some of the plugins you restored are not compatible with the server you are using. I would re-install them from the catalog.
