charliekay74 0 Posted March 14, 2015 Posted March 14, 2015 Is it possible, to get bigger Fonts in the Media Browser Classic (Chocolate or classic Theme)? I personally prefer the chocolate theme because it has Rotten tomatoes rating.
ebr 16334 Posted March 14, 2015 Posted March 14, 2015 I believe you can use the normal Windows facility to expand the font size but, if you get too crazy with it some things might go a bit wonky .
charliekay74 0 Posted March 14, 2015 Author Posted March 14, 2015 (edited) i tried it with bigger fonts in windows 8.1 and with scaling up to 150 percent...but no effect...the fonts in media browser stayed at the same level....i have so bad eyes and need bigger fonts;-)...i think in earlier versions there was an option to change some files in the media browser directory for bigger fonts Edited March 14, 2015 by charliekay74
ebr 16334 Posted March 14, 2015 Posted March 14, 2015 You can still modify the styles files but that is an undocumented feature at this point because doing that can cause problems with updates sometimes. chocolate_custom_styles.mcml I think is what you'd want to create. Start with the normal chocolate_styles.mcml file and modify from there.
charliekay74 0 Posted March 14, 2015 Author Posted March 14, 2015 and where i find this files?...in media browser directory i cannot find them
ebr 16334 Posted March 15, 2015 Posted March 15, 2015 Actually the file you want to edit I think is Chocolate_fonts.mcml in the Chocolate folder under plugins. Make a backup of your mods because this file may be overwritten on an update.
