dylanrellis 8 Posted November 10, 2013 Posted November 10, 2013 Hi I was sent here regarding title, cant seem to find any threads. Anyway I can add entry points in mbc3? If not is there anyway to remove the intro animation and edit ehs to look more fitting in wmc? thanks
Solution swhitmore 781 Posted November 10, 2013 Solution Posted November 10, 2013 Here you go bud: http://mediabrowser.tv/community/index.php?/topic/1127-entry-points-in-mce7-not-working/?hl=%2Bentry+%2Bpoints For the splash screen, put ExtSplash.jpg and LoginSplash.png in %appdata%/MediaBrowser-Classic/Configurations to customize. EHS will depend on what theme you are using. 1
dylanrellis 8 Posted November 10, 2013 Author Posted November 10, 2013 thx a lot for that, is there a particular theme that suits wmc more natively?
yardameus 221 Posted November 10, 2013 Posted November 10, 2013 Maybe Chocolate with the blue theme setting? Or Diamond?
dylanrellis 8 Posted November 10, 2013 Author Posted November 10, 2013 cool thx blue chocolate looks nice 1
keef 37 Posted November 10, 2013 Posted November 10, 2013 thx a lot for that, is there a particular theme that suits wmc more natively? Or you could turn things around and make your wmc theme suit your media browser classic theme. Something like this for example... 2
