deuce9498 6 Posted March 13, 2015 Posted March 13, 2015 I've had LiveTV working for months with HDHomeRun, NextPVR, and Roku3 client. Bought a new router and default DHCP network on it was different than my old one. I figured out NextPVR wasn't streaming because firewall rules were wrong now - but in process of figuring that out I dumped my old channel mappings and re-scanned. NextPVR all set now. But Mediabrowser is not happy. I see the channels map in from NextPVR but on Roku3 when you open a channel there's no option to watch even in the list now. I uninstalled the NextPVR plugin, restarted server a few times no changes. I'm suspecting there's still saved variables, metadata or something hanging around hosing things up? Would like to clean anything to do with LiveTV out without doing a complete MB install from scratch and losing all my other metadata mappings etc. Anyone know all the places to "clean" for LiveTV to get a fresh shot at it?
deuce9498 6 Posted March 16, 2015 Author Posted March 16, 2015 Uninstalled Mediabrowser. Deleted every directory I could find in Appdata/Roaming that had anything to do with Mediabrowser. Reinstalled MB, installed NextPVR Plugin. Getting same behavior. Description of troubleshooting and symptoms No errors in MB configurations, see all the channel metadata coming Going to Mediabrowser URL from windows client see all the channels, pushing the play button results in nothing On Roku3, see all the channels, selecting a channel only shows the "...More" option under the channel where when working there should be a "plan or watch" option, don't recall word NextPVR works by itself Installed newest version of Kodi with NextPVR plugin, Kodi/NextPVR work. Installed ServerMCE plugin, Windows media center works by itself MB pulls in data from ServerMCE, see the channels, same behavior as NextPVR, no play option on Roku I played with enabling debug on the nextpvr and servermce plugins but I'm not sure I see additional diagnostics in the MB log. Been trying to look in the server logs here - Appdata\Roaming\MediaBrowser-Server\Logs\Server-Datetime* See no lines with the word fail/error/etc. that indicates a problem. Where should I be looking to maybe even see an error? Thanks!
deuce9498 6 Posted March 18, 2015 Author Posted March 18, 2015 So the LiveTV services do work. Appears to only be a UI glitch. If I select a channel from the Roku there's no play option to start the stream. If I scroll to the right there's programs listed from the guide that are on now. If I select one the stream will start and it works.
