illinomad 0 Posted March 11, 2015 Posted March 11, 2015 Hi, Does anyone happen to know which Windows clients, if any, support the SendString general command?(per https://github.com/MediaBrowser/MediaBrowser/wiki/Web-Socket) I would like to be able to do a remote search for media titles by substring -- akin to the browse results that appear if I locally search for media using the search field in Dashboard. I'm trying to use the general commands as documented in the wiki: 1. GoToSearch 2. SendString The only client on which GoToSearch is "working" for me currently is Dashboard. Sending this message opens a Search panel on the right-hand side of the screen (see screenshot). However, I can do nothing within this search panel because I can't figure out how to enter a string in the text field. There's no indication that the SendString message is being received. I don't know if there's a log for Dashboard? I couldn't find one. The server log shows nothing. Is there some other command apart from SendString that I should be using instead? Thanks in advance.
Luke 42243 Posted March 11, 2015 Posted March 11, 2015 not many at this point. if any, i would say mbt and roku but i don't recall if i incorporated send string or not.
illinomad 0 Posted March 11, 2015 Author Posted March 11, 2015 Thanks for the prompt reply, Luke. Much appreciated. So far I haven't been able to remote control MBT at all, so I couldn't test SendString with MBT. I asked about this in an earlier post, and some people mentioned that it may not be possible at this point? Basically, only Dashboard is working for me to any reasonable degree in terms of RC. Alas, not SendString.
illinomad 0 Posted March 15, 2015 Author Posted March 15, 2015 However, I can do nothing within this search panel because I can't figure out how to enter a string in the text field. There's no indication that the SendString message is being received. I don't know if there's a log for Dashboard? I couldn't find one. The server log shows nothing. Is there some other command apart from SendString that I should be using instead? Or some other method to accomplish the objective described in my initial post. thx.
Luke 42243 Posted March 15, 2015 Posted March 15, 2015 i checked and roku has implemented this. you can always search with the api and then send the browse command. but if you want the search to happen on-screen then i guess you'll have to wait until the apps support these features.
