thefirstofthe300 292 Posted March 12, 2015 Posted March 12, 2015 Have you tried simply refreshing the entire library? You said that one folder that you refreshed actually had the correct treatments getting applied.
Alceste 3 Posted March 12, 2015 Author Posted March 12, 2015 This folder only got the correct treatment because before I forced MB to save mdeia files in the same folder as the respecitve media file resides in. But I want the files to remain in the appdata folder!
Alceste 3 Posted March 13, 2015 Author Posted March 13, 2015 Update: Tonight I got so mad that I installed the server software on my main PC pulled two movies from my server and installed the cover art plugin to see if the problem reproduced. Guess what it did! Now I did not enter my Supporter's key because but I should still be in the trial period, right!? So that should not be the cause.
Alceste 3 Posted March 13, 2015 Author Posted March 13, 2015 Update2: I found the cause of the problem - I had to untick the option "Ignore images sourced from IBN. I'm still unsure what this actually menas but now Cover art is working correctly. Thanks for you support everyone! 1
Luke 42253 Posted March 13, 2015 Posted March 13, 2015 that is strange but i am glad it's working for you. I'm sure Ebr can explain or may ask more questions to improve that.
ebr 16342 Posted March 13, 2015 Posted March 13, 2015 Oh, crap - this is because you combined the IBN and metadata folders... There is no way for that option to work anymore.
Luke 42253 Posted March 13, 2015 Posted March 13, 2015 you can't check for object types, like person, genre, etc?
ebr 16342 Posted March 13, 2015 Posted March 13, 2015 I think at this point it is best to just eliminate the option in CA because it is convoluted and has too many exceptions now and custom creating artwork for items is probably fairly rare. However, I'm sure there will be some folks that will have a problem with this. The original point of this option was the fact that the IBN was a custom location entirely so, if someone put an image there, it was likely in the form they wanted to see it and don't want an image processor messing with it. However, with it now just being a part of the overall metadata area, that isn't a valid assumption anymore.
Alceste 3 Posted March 13, 2015 Author Posted March 13, 2015 Dear ebr, I don't understand a word. However, primarily I would like to know whether it is my setup that is screwed up or whether your plugin works in slightly different ways than you expected!? Maybe you could start by explaining to me what IBN (folders!?) are...
ebr 16342 Posted March 13, 2015 Posted March 13, 2015 There is nothing wrong with your setup. A recent change to how the server manages its data has created a problem for CoverArt in certain situations - those situations being a brand new install and the option you discovered being selected. Thank you for your patience on this issue. ImagesByName Folder
