pir8radio 1313 Posted March 10, 2015 Posted March 10, 2015 (edited) My Mediabrowser supporter key isnt working... Something i need to do? It was fine a few hours ago. also check for application updates and plugin updates tasks failing. Edited March 10, 2015 by pir8radio
ebr 16307 Posted March 10, 2015 Posted March 10, 2015 More than likely you are unable to connect to our server then.
Luke 42184 Posted March 10, 2015 Posted March 10, 2015 yea the info is cached locally in MBS for up to 7 days, so if this happens it means you would have to have 7 consecutive days of failures refreshing the info
pir8radio 1313 Posted March 10, 2015 Author Posted March 10, 2015 (edited) Is there an issue with your servers. Ip4 or 6? Also you should code something so this "check" isn't required for lifetime supporter keys? Edited March 10, 2015 by pir8radio
pir8radio 1313 Posted March 10, 2015 Author Posted March 10, 2015 (edited) Soooooo, still not working... are your servers up? Some reason I would not be able to reach them? @@Luke i dont get what your saying, if i have one failure i will continue to have 7? Or do you mean the info is cached so my features will still work for up to 7 days with no server contact. Edited March 10, 2015 by pir8radio
Beardyname 198 Posted March 11, 2015 Posted March 11, 2015 I think what he meant was that if your server gets an "ok" it cashes that for 7 days (but still checks daily), so if you are seeing the error it means it has been more than 7 days where it continues to fail everyday. (it just won't show the error the upcoming 6 days)
ebr 16307 Posted March 11, 2015 Posted March 11, 2015 Please post a server log. No one else is reporting a problem so it must be a local issue of some sort.
pir8radio 1313 Posted March 11, 2015 Author Posted March 11, 2015 (edited) Please post a server log. No one else is reporting a problem so it must be a local issue of some sort. You may be right, i looked today and it was happy.... not sure what happened, i tried for a few days re-entering the but no go... then today its happy again... when i get home ill look through the logs. its weird though i could still surf the web, all of my other inbound services were functioning, i didnt try to reach the mbadmin site... but who knows.. Edited March 11, 2015 by pir8radio
