TedA 36 Posted March 9, 2015 Posted March 9, 2015 Just curious why this doesn't exist. Because there is no dedicated sub forum for support of this client, the questions end up all over (general, theater, server, other) The web client seems to be a highly used client. Might be good to have a dedicated support forum? 1
Latchmor 584 Posted March 9, 2015 Posted March 9, 2015 I think it has just been considered part of the Server since it's all in one. That's how I've always seen and I post in the server section. However I guess you have a point, as it gets more advanced the server (setup/settings) and client could be separate forums.
TedA 36 Posted March 9, 2015 Author Posted March 9, 2015 Also server is broken up in to sub forums by os. Since the web client is common across them it is confusing where to post a question or issue. I've just been seeing web client questions pop up in 3 or 4 different locations and I think it is because it is confusing where it should go. I think a lot of people would consider the dashboard section to be the "server" and everything else to be a web client "app" 1
darkNiGHTS 1 Posted April 11, 2015 Posted April 11, 2015 Also server is broken up in to sub forums by os. Since the web client is common across them it is confusing where to post a question or issue. I've just been seeing web client questions pop up in 3 or 4 different locations and I think it is because it is confusing where it should go. I think a lot of people would consider the dashboard section to be the "server" and everything else to be a web client "app" Agreed. I just posted a web client in the windows section because I was not sure where else to put it. But it'd be the same issue on Mac OS X and Linux.
Luke 42239 Posted April 11, 2015 Posted April 11, 2015 sure, we can do a web client subforum. that will give you guys a good place to voice your thoughts about it 1
Larry SA 3 Posted April 30, 2015 Posted April 30, 2015 sure, we can do a web client subforum. that will give you guys a good place to voice your thoughts about it When will this be up? I'm currently having issues with the web ui on the xbox one. Using the latest Beta but for the web ui is loading correctly on it. But i'm not sure what subforum to post in.
Luke 42239 Posted April 30, 2015 Posted April 30, 2015 @@Abobader can you create "Web Client" under app support? Thanks
Luke 42239 Posted April 30, 2015 Posted April 30, 2015 When will this be up? I'm currently having issues with the web ui on the xbox one. Using the latest Beta but for the web ui is loading correctly on it. But i'm not sure what subforum to post in. We can help with that although I would suggest trying Xbox Media Player because a lot of work has been done recently to improve dlna with Xbox one.
Larry SA 3 Posted April 30, 2015 Posted April 30, 2015 Tried... We can help with that although I would suggest trying Xbox Media Player because a lot of work has been done recently to improve dlna with Xbox one. Tried but it goes crazy on me... files don't always play. It usually will occur if my son is signed in and an adult account is needed to allow him to watch using the app. Because it cant tell the age rating of the file it just simply asks every time.
Luke 42239 Posted April 30, 2015 Posted April 30, 2015 Tried... Tried but it goes crazy on me... files don't always play. It usually will occur if my son is signed in and an adult account is needed to allow him to watch using the app. Because it cant tell the age rating of the file it just simply asks every time. it asks what? can you explain that? i want to get the media player nailed completely so let's get this ironed out.
Larry SA 3 Posted April 30, 2015 Posted April 30, 2015 Before you posted I re-installed the latest beta. Did a test and it solved the problem.... Basically on the Xbox One if you have accounts that have media restriction i.e, age ratings for video files. If they start a file it will ask you(Parent) to allow them to watch it. When I tried this yesterday... every time I would allow him by typing in my passcode it just ended up asking me to do it again and again and again. It looks like the update process did not work correctly
Larry SA 3 Posted April 30, 2015 Posted April 30, 2015 I've attached a pic of what the Web ui looks like.The options in the top left and top right is missing. Also clicking on a action item like play does nothing. But reloading the page seem to work.
Abobader 3485 Posted April 30, 2015 Posted April 30, 2015 @@Abobader can you create "Web Client" under app support? Thanks Done buddy.
Larry SA 3 Posted May 1, 2015 Posted May 1, 2015 (edited) So dlna is working well? DLNA works great for me. But I still prefer the Web UI over the Xbox Media Player. The controls are just better. Cant wait for a native app. If only it could be like eMBy for WMC. I still miss cover flow... :-( Edited May 6, 2015 by Larry SA
