buddyweiser 105 Posted November 9, 2013 Posted November 9, 2013 When attempting to launch N64 games from GB3, Project64 launches, but I receive an error message saying "Unable to open file." However, I can click File, Open Rom, and find the ROM and then it works fine. Can anyone shed some light on this issue for me?
Logos302 86 Posted November 9, 2013 Posted November 9, 2013 did you use UNC pathing when setting up your games directory?
shaefurr 1340 Posted November 9, 2013 Posted November 9, 2013 Could be a problem with the switch for the emulator. But im not at my pc at the moment to help
Redshirt 1487 Posted November 9, 2013 Posted November 9, 2013 The Mediabrowser classic log will show the command line used.
buddyweiser 105 Posted November 9, 2013 Author Posted November 9, 2013 Sorry guys, I'm very low level on the knowledge base, I don't even know what UNC pathing is I havent used emulators since using zsnes 12 years ago in high school computer class. I only just discovered emulators for newer systems, and just installed dolphin today(but I seem to have the same problem as with project64, but with a longer error message) As with project 64, I can open the game once in the emulator, but the direct launch doesnt work.
shaefurr 1340 Posted November 10, 2013 Posted November 10, 2013 I'm guessing you're using MB classic? Using a UNC path just means using the shared network path, not the local path on the hard drive. You can enter this manually as well. When you open the Mediabrowser classic configurator, go to plugins > gamebrowser, what is the switch used for N64? I'm not running MBC right now, but I thought the switch in the GB config was just {rom}, can someone confirm that? Dolphin I believe was --exec={rom} 1
buddyweiser 105 Posted November 10, 2013 Author Posted November 10, 2013 AWESOME!, Dolphin games are fixed, I had the switch wrong. Well the Wii games are right, I can't try the gamecube games yet due to the metada not populating, and so the games don't show up in MBC. However still having issues with the N64 emulator. I tried changing to the network path, but now games shows up in MBC, so i changed the path back the regular K drive.
shaefurr 1340 Posted November 10, 2013 Posted November 10, 2013 gamecube should be the same switch if you're using dolphin, im sure someone on here can post the switch for project 64 for you since my games arn't set up at the moment
buddyweiser 105 Posted November 10, 2013 Author Posted November 10, 2013 I have the default {rom} set, but it doesn't work for project64. Also, do you happen to know why my Gamecube games metadata aren't populating? I verified the folder titles with those on thegamesdb.net
Redshirt 1487 Posted November 10, 2013 Posted November 10, 2013 I take it you've marked the game folder as Nintendo64 and the game files are of one of the following extensions. ".z64", ".v64", ".usa", ".jap", ".pal", ".rom", ".n64", ".zip"
buddyweiser 105 Posted November 10, 2013 Author Posted November 10, 2013 I have the folder just marked N64 "K:\My Media\My Games\N64\Games" and yes I have multiples of .z64 and .v64
Redshirt 1487 Posted November 10, 2013 Posted November 10, 2013 In the gamebrowser server configuration, that folder is set as Nintendo64?
Redshirt 1487 Posted November 10, 2013 Posted November 10, 2013 ok. Go into the server dashboard. In the task section, run the start new log file task and then run the scan media library task. When it's done, let me see that log.
buddyweiser 105 Posted November 10, 2013 Author Posted November 10, 2013 2013-11-09 21:29:53.8317, Info, App, Start new log file Completed after 0 minute(s) and 0 seconds2013-11-09 21:29:54.7365, Info, App, Sending web socket message ScheduledTaskEnded2013-11-09 21:30:04.7829, Info, App, Executing Scan media library2013-11-09 21:30:04.7829, Info, App, Validating media library2013-11-09 21:30:04.7985, Info, App, Validating collection folders within C:\Users\Jesse\AppData\Roaming\MediaBrowser-Server\root\default2013-11-09 21:30:05.4693, Info, App, Sending web socket message ScheduledTaskStarted2013-11-09 21:30:27.2626, Info, App, ScheduledTasksWebSocketListener stop transmitting over websocket to 127.0.0.1:492902013-11-09 21:30:29.3998, Info, App, ScheduledTasksWebSocketListener Begin transmitting over websocket to 127.0.0.1:492902013-11-09 21:30:32.3170, Info, App, Scan media library Completed after 0 minute(s) and 27 seconds2013-11-09 21:30:32.3170, Info, App, Sending web socket message ScheduledTaskEnded2013-11-09 21:30:34.4698, Info, App, ScheduledTasksWebSocketListener stop transmitting over websocket to 127.0.0.1:492902013-11-09 21:30:35.4994, Info, App, LogFileWebSocketListener Begin transmitting over websocket to 127.0.0.1:49290
buddyweiser 105 Posted November 10, 2013 Author Posted November 10, 2013 I solved the gamecube metadata issue, I had the iso's zipped but still having the issue with project 64 not launching properly
Redshirt 1487 Posted November 10, 2013 Posted November 10, 2013 post a link to a mediabrowser-classic log with you attempting to launch an n64 game.
buddyweiser 105 Posted November 11, 2013 Author Posted November 11, 2013 (edited) I think this is what you asked for... 2013-11-11 02:50:41.8298,Debug,,Loading full details for The Legend of Zelda: Ocarina of Time actors: null,1,Application2013-11-11 02:50:41.8298,Info,,Sending Http Get to http://mediabrowser/Users/a163cb73-eb72-84b7-68a2-16b352ae0a3f/Items/2c3aee1b-4cfe-c32a-6daa-b4e5513a30f4?format=Json,1,Application2013-11-11 02:50:41.8349,Info,,Sending Http Get to http://mediabrowser/Localization/ParentalRatings?format=Json,1,Application2013-11-11 02:50:41.8379,Info,,Sending Http Get to http://mediabrowser/Localization/ParentalRatings?format=Json,1,Application2013-11-11 02:50:43.5399,Debug,,Creating a new instance of GamePlaybackController,22,Worker thread for Play Action2013-11-11 02:50:43.5469,Info,,Gamebrowser playback controller about to play The Legend of Zelda: Ocarina of Time(K:\My Media\My Games\N64\Games\The Legend of Zelda- Ocarina Of Time\The Legend of Zelda- Ocarina Of Time.z64) ,22,Worker thread for Play Action2013-11-11 02:50:43.5549,Info,,Gamebrowser playback controller playing The Legend of Zelda: Ocarina of Time,22,Worker thread for Play Action2013-11-11 02:50:43.5609,Info,,*** GAMEBROWSER *** Trying to match GameSystem for Nintendo 64,22,Worker thread for Play Action2013-11-11 02:50:44.6050,Info,,*** GAMEBROWSER *** Process.Start(Nintendo 64,, C:\Program Files\Project64 1.6\Project64.exe "K:\My Media\My Games\N64\Games\The Legend of Zelda- Ocarina Of Time\The Legend of Zelda- Ocarina Of Time.z64"),22,Worker thread for Play Action Edited November 11, 2013 by buddyweiser
Solution Redshirt 1487 Posted November 11, 2013 Solution Posted November 11, 2013 for version 1.6 of Project64 you have to use {rom} if you use "{rom}" with the quotes then the emulator complains that it can't find the file. It's in their faq here. 1
buddyweiser 105 Posted November 11, 2013 Author Posted November 11, 2013 Thanks a lot Redshirt! I just assumed it would require the quotes same as all the other emulators
