komital 0 Posted March 8, 2015 Posted March 8, 2015 I'm looking for media server solution and so far I can see Mediabrowser like best for my needs. As I can see that it also support plugins, can somebody tell me is it possible to use it alos for books (books ar alos media)?
Maleficarum 68 Posted March 8, 2015 Posted March 8, 2015 You can install a plugin for the server called MB Bookshelf that will allow it to use mobi, pdf and epub files. There is also a plugin for Media browser classic called MB Bookshelf-Classic, you will need the server plugin installed if you wish to use this.
komital 0 Posted March 8, 2015 Author Posted March 8, 2015 You can install a plugin for the server called MB Bookshelf that will allow it to use mobi, pdf and epub files. There is also a plugin for Media browser classic called MB Bookshelf-Classic, you will need the server plugin installed if you wish to use this. Thanks. It looks like that what I search.
fantaxp7 191 Posted July 31, 2015 Posted July 31, 2015 What is the proper file structure for books? I made it similar to movies but I am not getting any metdata. Books/Stephen King/The Green Mile for example.
Spaceboy 2573 Posted July 31, 2015 Posted July 31, 2015 I don't believe emby downloads metadata for books, I used another program to create it. Let me see if I can find it
Luke 42140 Posted July 19, 2025 Posted July 19, 2025 Emby Server 4.9.1.8+ will now have a book reader in the web app for the following formats: PDF EPUB MOBI FB2 CBZ CBR Please try it out once available and report your experience in the Testing Area of the community: Thanks !
