RonnieSK 1 Posted January 25, 2024 Posted January 25, 2024 On 1/23/2024 at 9:10 PM, Luke said: @RonnieSK? @LukeHi Luke ! Im sorry for the delay, my server broke and had to be replaced. Im on my way to restore it, give me please bit time and ill get back to you with logs. Since i have to install also Emby again, should i use the plugin provided by you again i think, right ? Thank you !
Luke 42239 Posted January 25, 2024 Posted January 25, 2024 1 hour ago, RonnieSK said: @LukeHi Luke ! Im sorry for the delay, my server broke and had to be replaced. Im on my way to restore it, give me please bit time and ill get back to you with logs. Since i have to install also Emby again, should i use the plugin provided by you again i think, right ? Thank you ! Yes please and thanks.
RonnieSK 1 Posted April 12, 2024 Posted April 12, 2024 Dear @Luke, im finally back in "business"... Some "things in life" appeared with higher priority. Can you please tell me how should we approach, continue to solve the "Zap" issue please ? Greetings Ronnie
Luke 42239 Posted April 12, 2024 Posted April 12, 2024 1 hour ago, RonnieSK said: Dear @Luke, im finally back in "business"... Some "things in life" appeared with higher priority. Can you please tell me how should we approach, continue to solve the "Zap" issue please ? Greetings Ronnie Hi, can you please go back through my previous postings and try those things again and provide the requested information? Thanks.
MatthieuM 0 Posted October 6, 2024 Posted October 6, 2024 (edited) On 21/12/2023 at 20:31, MatthieuM said: The most detailed information on the matter that I have seen: So I concur with this previous post that says that the kodi enigma2/vuplus plugin is corretly loading all of the picons using the only available SNP formatted picons files. (channel names) format by making this "un-documented" API call referred to. I checked that this was the case with a kodi add-on install, and indeed all of the picons are extracted from the vuplus openwebif interface. while the current Vuplus plugin in Emby and/or the JellyFin enigma2 plugin are both still not capable of working that way and fail to retrieve most picons if the SRP picon is not present which is most likely the case for the new firmware released on the vuplus series. Emby vuplus plug-in and jellyfin enigma2 add-on fail as the old way of creating picons in the SRP format (1_0_1 / 1_0_19 etc) is no longer possible and only SNP formatted picons are present I commented on the matter here: https://github.com/knackebrot/jellyfin-plugin-enigma2/issues/23#issuecomment-2266064223 Would be great to see if the kodi-enigma2 plugin method of extraacting the picons could be replicated in a newer emby vuplus plugin. Edited October 6, 2024 by MatthieuM
MatthieuM 0 Posted October 6, 2024 Posted October 6, 2024 The current vuplus plugin does indeed only work with e2servicereference (SRP) picon .png files
MatthieuM 0 Posted October 6, 2024 Posted October 6, 2024 The kodi-enigma2/vuplus add-on does offer the use of OpenWebif 1.3.5 or higher to get the picon using the "servicename" picon (SNP .png) * **Use OpenWebIf picon path**: Fetch the picon path from OpenWebIf instead of constructing from ServiceRef. Requires OpenWebIf 1.3.5 or higher.
Luke 42239 Posted September 28, 2025 Posted September 28, 2025 6 hours ago, gerry1284 said: nessun aggiornamento? Hi, what exactly are you asking for an update on?
