Luke 42241 Posted January 25, 2017 Posted January 25, 2017 How can I wipe the channel list from emby server? I have added a new bouquet on my vuplus STB and changed the settings to sync channels from within the Emby LiveTV Plugin but obviously the previous channels don't get wiped and new bouquet channels are added to the old ones? Try removing it from Emby, refreshing the guide, then adding it back.
tgessendorfer 7 Posted January 25, 2017 Posted January 25, 2017 Try removing it from Emby, refreshing the guide, then adding it back. Tried that except refreshing the guide...Somehow seems to cache the channel list somewhere...Will try again tomorrow
tgessendorfer 7 Posted February 27, 2017 Posted February 27, 2017 OK all looks fine... However I would like to completely wipe the plugin settings after uninstalling it. Seems that all settings and channel lists are cached or stored somewhere? I would like to resetup cleanly and create a new channel list sorting as well.
docb7 3 Posted October 8, 2017 Posted October 8, 2017 Hi Guys, I really love this Plugin but I have one little feature request as my VU often is in deep standby: It would be great to have another field in configuration: "Wake-up command". There you could specifiy a wake-up command, either a system command (e.g. ehterwake) or an http command (would be great in my case, cause my VU has no WOL and I start it via an Logitech Harmony http command). And then if Emby needs the VU (eg. to refresh guide or when you want to watch TV and emby gets no connection, this command is applied and emby starts the next try to connect to the VU 15 secs. later. Thanks for all your great work!
noxx 3 Posted October 10, 2017 Posted October 10, 2017 whats i do wrong? i see only my records, but no channels. channels section is empty 2017-10-10 19:25:32.512 Info App: [VuPlus] Start GetRecordingsAsync, retrieve all 'Inprogress' and 'Completed' recordings 2017-10-10 19:25:32.517 Info App: [VuPlus] Start EnsureConnectionAsync 2017-10-10 19:25:32.518 Info HttpServer: HTTP Response 200 to ::1. Time: 45ms. http://localhost:8096/emby/Packages/Updates?PackageType=System 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync HostName: 192.168.1.155 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync StreamingPort: 8001 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePort: 80 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePassword: 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync UseSecureHTTPS: False 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync OnlyOneBouquet: True 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync TVBouquet: FreeTV 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync ZapToChannel: False 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync FetchPiconsFromWebInterface: True 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync PiconsPath: 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync RecordingPath: 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync EnableDebugLogging: True 2017-10-10 19:25:32.527 Info App: [VuPlus] EnsureConnectionAsync Validation of config parameters completed 2017-10-10 19:25:32.532 Info App: [VuPlus] Start InitiateSession, validates connection and returns Bouquet reference if required 2017-10-10 19:25:32.532 Info HttpClient: HttpClientManager GET: http://192.168.1.155:80/web/getservices 2017-10-10 19:25:32.545 Info HttpServer: HTTP Response 200 to ::1. Time: 143ms. http://localhost:8096/emby/Sessions 2017-10-10 19:25:32.548 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36 2017-10-10 19:25:32.552 Info InstallationManager: Opening C:\Users\Ralf\AppData\Roaming\Emby-Server\cache\serverpackages.json 2017-10-10 19:25:32.565 Info HttpClient: HttpClientManager GET: http://192.168.1.155:80/web/movielist
Luke 42241 Posted October 10, 2017 Posted October 10, 2017 Please attach the complete emby server log, thanks.
noxx 3 Posted October 10, 2017 Posted October 10, 2017 here the complete log https://pastebin.com/raw/C1NEwkD8
Luke 42241 Posted October 10, 2017 Posted October 10, 2017 here the complete log https://pastebin.com/raw/C1NEwkD8 This is only a log of server startup and it does not contain any obvious problems. can you please run the refresh guide scheduled task, and then attach the emby server log? thanks.
noxx 3 Posted October 10, 2017 Posted October 10, 2017 (edited) ok, here is the log https://pastebin.com/raw/pkshDQ7j but, now i see the channel Edited October 10, 2017 by noxx
Luke 42241 Posted October 10, 2017 Posted October 10, 2017 So i guess that's all you needed to do. Thanks.
Miasko 0 Posted October 25, 2017 Posted October 25, 2017 Hi everyone. Its my first post about EMBY and STB Enigma2. I have problem because in emby I install plugin VUPlus but they cant find my STB ;-( I dont know whats is wrong. When I login to Webif then i can waching all TV canal.
Luke 42241 Posted October 28, 2017 Posted October 28, 2017 @@Miasko, please attach the information requested in how to report a problem. thanks !
DarzLir 0 Posted October 31, 2017 Posted October 31, 2017 I think I have a problem with this plugin. In my sat receiver I have 3 types of channels, SAT, DVB and some IPTV Channels. Everything works even EPG from that IPTV Channels that have it, but the picons for this channels doesn't appear on emby apps/server This is a screenshot from E-Channelizer, a tool for Enigma2 receivers, all logos are ok, they are from a local location on the server. When I syncronize this tool with the receiver, all picons are transfered to the receiver. When I active the plugin and refresh guide on Emby, everthing it's ok. EPG is ok, even for those IPTV channels but no logos, I can put it manually, but... Why doesn't take from openwebif? I used both options, I selected from a local location too, like I wrote E-Channelizer is using that location, and doesn't work either for the plugin :\ In Open Webif shows all (Channel "CanalSurHD" doesn't appear here because doesn't have EPG, this is a screenshot from MultiEPG option) RED = DVB YELLOW = SAT BLUE = IPTV So, IPTV can't get picons?
Luke 42241 Posted November 9, 2017 Posted November 9, 2017 if you have an enigma tv tuner then we have a better way of using that with Emby. Now with OpenVix you can add your enigma tuner directly to Emby using Emby's native support. No VU+ plugin needed. You can learn more here: https://emby.media/community/index.php?/topic/52762-enigma2-livetvdvr-support/ Thanks ! 1
DarzLir 0 Posted November 9, 2017 Posted November 9, 2017 if you have an enigma tv tuner then we have a better way of using that with Emby. Now with OpenVix you can add your enigma tuner directly to Emby using Emby's native support. No VU+ plugin needed. You can learn more here: https://emby.media/community/index.php?/topic/52762-enigma2-livetvdvr-support/ Thanks ! Great news Luke, I'll try later
Peppe 4 Posted December 9, 2017 Posted December 9, 2017 Hi, is it possible to add more than one favourite bouquet? If yes, how can i add a second bouquet into Vu+ TVBouquet: ? Separate with a , or ; doesnt help...
tgessendorfer 7 Posted January 30, 2018 Posted January 30, 2018 I have currently issues using https for Enigma2 Webinterface. Did the following to make sure all fine: set up OpenWebIf Extension to use https with authentication on port 8886 configured the Enigma2 LiveTV plugin to use port 8886 and https provided same username/password for OpenWebIf user as before (with http still works just fine!= provided my own key.pem and cert.pem files on my Engima2 Box (/etc/enigma2) and rebooted. Verified by loging in via Chrome Webbrowser through https on port 8887 the security page doesn't show up Now in the logfiles I get the following error: 2018-01-30 15:55:17.268 Info HttpClient: GET: https://<My_FQDN>:8887/web/getservices2018-01-30 15:55:17.467 Error HttpClient: Error getting response from https://<My_FQDN>:8887/web/getservices *** Error Report *** Version: 3.2.70.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.112 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Peer certificate cannot be authenticated with given CA certificates at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() System.Net.Http.HttpRequestException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() InnerException: System.Net.Http.CurlException System.Net.Http.CurlException: Peer certificate cannot be authenticated with given CA certificates at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) First I thought that the SSL security is requiring an official SSL certificate but now I have no clue anymore as when opening the link https://<My_FQDN>:8887/web/getservices through Chrome all definately looks fine! Any ideas what I am missing here???
Coxeroni 27 Posted February 7, 2019 Posted February 7, 2019 (edited) Is this safe to be used remotely? I have my emby server setup at a VPS and think about sharing my Vu+ at home with it to have access to TV whereever I want to. If I set a strong password for the OpenWebIF I should be safe opening the respective ports am I? Is the streaming itself also secured with the user/password or is it just the WebIF itself?Edit: one of the questions I can answer myself, the OpenWebIF at the VU has a toggle for "require user/pw for streaming". Edited February 7, 2019 by Coxeroni
RonnieSK 1 Posted December 6, 2023 Posted December 6, 2023 Dear Emby Team ! I would like to kindly ask for assistance with mentioned plugin. Im using actually most recent version of Emby Server with Premiere and the most recent VuPlus plugin. Im using livetv strictly via openwebif on multiple platforms for years, so it would be fantastic to have finally everything under one app. I have everything managed and configured. Bouquets, Picons, EPG, everything works great, but i cant find the "Zap before streaming" option. Without this possibility im sadly unable to use the plugin, since i have to switch/zap to preferred channel any other way (manually on stb, via web openwebif, vlc or different openwebif app in my phone/appletv) to get the stream in Emby. Thank you very much !
Luke 42241 Posted December 6, 2023 Posted December 6, 2023 7 minutes ago, RonnieSK said: Dear Emby Team ! I would like to kindly ask for assistance with mentioned plugin. Im using actually most recent version of Emby Server with Premiere and the most recent VuPlus plugin. Im using livetv strictly via openwebif on multiple platforms for years, so it would be fantastic to have finally everything under one app. I have everything managed and configured. Bouquets, Picons, EPG, everything works great, but i cant find the "Zap before streaming" option. Without this possibility im sadly unable to use the plugin, since i have to switch/zap to preferred channel any other way (manually on stb, via web openwebif, vlc or different openwebif app in my phone/appletv) to get the stream in Emby. Thank you very much ! Hi, what does Zap mean? Why can't you just press play in Emby?
RonnieSK 1 Posted December 7, 2023 Posted December 7, 2023 9 hours ago, Luke said: Hi, what does Zap mean? Why can't you just press play in Emby? Dear Luke ! Thank you for your reply ! Of course i do that, but the stream doesnt start if i didnt "switch" manually in any upper described way to the channel i would like to play in "EMBY". This is called "zapping", so changing-switching to the desired channel. The device should first Zap/switch to the requested channel and then start streaming. For instance when i stream "MTV" and i would like to switch to "VH1", it doesnt work in Emby, since the VH1 stream doesnt start (still streaming MTV in background, because the device does not Zap to the next channel). The option is listed in built-in OpenWebIf. Every other app/software has this (working) functionality. Sadly i miss it here and is unable for me to use the plugin like this
RonnieSK 1 Posted December 7, 2023 Posted December 7, 2023 (edited) @Lukei also find in this topic on previous pages two screenshots from config page of previous versions of this plugin (date cca 2016). Both hast the "zap" checkbox-functionality : Edited December 7, 2023 by RonnieSK image editing
Luke 42241 Posted December 8, 2023 Posted December 8, 2023 Why can't you just stop mtv in Emby and then play VH1?
RonnieSK 1 Posted December 8, 2023 Posted December 8, 2023 Sadly im unable to describe better the OpenWebIf stream functionality in Enigma2 OS. In basics : You start the internal OpenWebIf player, or some external app (web based player, VLC, VuPlusTV, Emby Vu+ plugin...), choose your channel -> push play -> the app sends the Zap command to the Satellite STB to switch to the requested channel and start streaming -> you receive the choosen stream/channel in your preferred app (web based player, VLC, VuPlusTV, Emby Vu+ plugin...). What is in my case missing in this procedure is the "the app sends the Zap command to the Satellite STB to switch to requested channel and start streaming". Quote Why can't you just stop mtv in Emby and then play VH1? As i mentioned, i can do that, but i didnt get the VH1 stream, because my STB isnt "ZAPPED" to VH1 channel and remains still on MTV. So ill STOP MTV in Emby -> i push play VH1 in Emby -> black screen = no stream is playing -> i switch back to MTV in Emby -> the channel/stream is playing. But no other channel ! I have to go to OpenWebIf player, VLC, any 3rd party app for this purpose or switch the STB manually to different channel. Now THIS channel is again possible to stream in Emby, no other.
MatthieuM 0 Posted December 18, 2023 Posted December 18, 2023 On 06/12/2023 at 22:58, RonnieSK said: Dear Emby Team ! I would like to kindly ask for assistance with mentioned plugin. Im using actually most recent version of Emby Server with Premiere and the most recent VuPlus plugin. Im using livetv strictly via openwebif on multiple platforms for years, so it would be fantastic to have finally everything under one app. I have everything managed and configured. Bouquets, Picons, EPG, everything works great, but i cant find the "Zap before streaming" option. Without this possibility im sadly unable to use the plugin, since i have to switch/zap to preferred channel any other way (manually on stb, via web openwebif, vlc or different openwebif app in my phone/appletv) to get the stream in Emby. Thank you very much ! I am also using the latest VuPlus plugin but have not had much luck importing the Picons automatically through the plugin. Would you mind indicating to me the format and path of your Picons folder in your enigma2 receiver ?
