lilvfr400boy 0 Posted February 11, 2016 Posted February 11, 2016 @@CompoUK apologies if this is really unrelated but your threads the closest to what I'm wanting to know , I'm after something similar to dreamplex but for emby ? Would you have any know how on how to implement such an add on possibly building on dreamplex add on ? Literally can't find anything for enigma 2 for emby Sent from my HTC One M9 using Tapatalk
Lee 212 Posted February 12, 2016 Posted February 12, 2016 @@CompoUK apologies if this is really unrelated but your threads the closest to what I'm wanting to know , I'm after something similar to dreamplex but for emby ? Would you have any know how on how to implement such an add on possibly building on dreamplex add on ? Literally can't find anything for enigma 2 for emby Sent from my HTC One M9 using Tapatalk Nothing yet. Would be nice tho, not sure @@Luke @@ebr etc. are really aware of enigma2 receivers....
pprezzla 2 Posted February 14, 2016 Posted February 14, 2016 ok so ... it seems the plugin wasn't updating my ip address. it was stuck at what I put in originally! I deleted the old config files in user>appdata>roaming>embyserver>plugins>config and BOOM... full guide and the lot.. #winning Would you be able to print screen your settings please? I just got my Vu Solo2 yesterday and trying to get this working. i deleted config files and entered ip address without http:// but still not working.
pprezzla 2 Posted February 14, 2016 Posted February 14, 2016 Actually, my recordings and schedule shows up but no guide or channels
Lee 212 Posted February 14, 2016 Posted February 14, 2016 Actually, my recordings and schedule shows up but no guide or channels is this in theatre or the web console?
pprezzla 2 Posted February 14, 2016 Posted February 14, 2016 (edited) is this in theatre or the web console? Both. I've got web port as 80 and streaming as 8001. My Vu+ iphone app has a transcoding port as 8002. Tried that as well but no joy i can stream on my Vu+ iOS app Edit: I have got it to work although there must be something wrong with my boutique. I have it set to use only one, FreeSat (UK) - All Channels. My problem is, there are 1000 channels populating in the EPG, mostly Sky channels. I don't have sky enabled in service providers. What sort of quality are you getting on your stream? mines is awful. Picture was like Minecraft and the sound was about 5 seconds behind. Edited February 14, 2016 by pprezzla
Lee 212 Posted February 15, 2016 Posted February 15, 2016 I don't get any channels in theatre but the web console works fine.. Also openwebif is fine. Your theatre screenshot is more than what I've got!
Lee 212 Posted February 15, 2016 Posted February 15, 2016 I'm hoping for sat>ip integration in the server as this plugin looks too hit n miss for me and isn't being updated by the dev...
Luke 42241 Posted February 15, 2016 Posted February 15, 2016 I'm hoping for sat>ip integration in the server as this plugin looks too hit n miss for me and isn't being updated by the dev... In the latest beta and dev servers, see if you have any log messages starting with SAT IP found at Just want to see if we're at least discovering the devices. thanks.
Lee 212 Posted February 17, 2016 Posted February 17, 2016 @@Luke I'll look at enabling the sat>ip server on my enigma box do I need to enable any specific logging anywhere in the server?
tgessendorfer 7 Posted March 12, 2016 Posted March 12, 2016 Just installed Emby (FreeNAS Plugin) and tried to get my Channels from my VuPlus Duo2 and confirmed settings for WebIf and Streaming Port but don't get the Channels retrieved!? 016-03-12 17:16:59.0547 Error App: Error getting service status info from VuPlus *** Error Report *** Version: 3.0.5882.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe One or more errors occurred. MediaBrowser.Model.Net.HttpException
horstepipe 423 Posted March 15, 2016 Posted March 15, 2016 hey when I want to watch a channel, I'm getting the following notification: "Playback error occured. Please make sure you have a free tuner" (paraphrased) I have a VU+ Solo SE which only has one tuner, but with other apps (blackbox for IOS) the "zap before channel switch" function works. Regards
Luke 42241 Posted March 15, 2016 Posted March 15, 2016 hey when I want to watch a channel, I'm getting the following notification: "Playback error occured. Please make sure you have a free tuner" (paraphrased) I have a VU+ Solo SE which only has one tuner, but with other apps (blackbox for IOS) the "zap before channel switch" function works. Regards Hi there, in order to best help you, please see how to report a media playback issue. Thanks.
tgessendorfer 7 Posted March 15, 2016 Posted March 15, 2016 Make sure you have available tuners showing in the WebGui of Emby and the option in the plugin settings checked to switch the tuner. The only thing currently not working for me is importing the picons, neither from WebInterface nor from local folders...
Nazgulled 11 Posted March 17, 2016 Posted March 17, 2016 I have setup an external service (VuPlus) for Live TV but I can't find a way to use it. AFAIK, everything is setup properly and it should be working. But I can't see any kind of option or menu to list my channels and pick one to watch... What setting could I be missing?
Nazgulled 11 Posted March 17, 2016 Posted March 17, 2016 I looked at the log and there was a configuration error there so I fixed it but now I get this: 2016-03-17 00:07:00.8098 Info App: Refreshing guide with 14 days of guide data 2016-03-17 00:07:00.8098 Info App: [VuPlus] Start GetProgramsAsync 2016-03-17 00:07:00.8098 Info App: [VuPlus] Start EnsureConnectionAsync 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync HostName: hostname.no-ip.org 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync StreamingPort: 8001 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePort: 85 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync UseSecureHTTPS: False 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync OnlyOneBouquet: True 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync TVBouquet: #Channels 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync ZapToChannel: False 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync FetchPiconsFromWebInterface: True 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync PiconsPath: 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync RecordingPath: 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync EnableDebugLogging: False 2016-03-17 00:07:00.8098 Info App: [VuPlus] EnsureConnectionAsync Validation of config parameters completed 2016-03-17 00:07:00.8098 Info App: [VuPlus] Start InitiateSession, validates connection and returns Bouquet reference if required 2016-03-17 00:07:00.8098 Info HttpClient: HttpClientManager GET: http://hostname.no-ip.org:85/web/getservices 2016-03-17 00:07:00.8971 Info HttpClient: HttpClientManager GET: http://hostname.no-ip.org:85/web/epgservice?sRef=1:0:1:579:68:53:CE40000:0:0:0: 2016-03-17 00:07:02.4462 Info App: [VuPlus] Start GetProgramsAsync 2016-03-17 00:07:02.4462 Info App: [VuPlus] Start EnsureConnectionAsync 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync HostName: hostname.no-ip.org 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync StreamingPort: 8001 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePort: 85 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync UseSecureHTTPS: False 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync OnlyOneBouquet: True 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync TVBouquet: #Channels 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync ZapToChannel: False 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync FetchPiconsFromWebInterface: True 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync PiconsPath: 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync RecordingPath: 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync EnableDebugLogging: False 2016-03-17 00:07:02.4462 Info App: [VuPlus] EnsureConnectionAsync Validation of config parameters completed 2016-03-17 00:07:02.4462 Info App: [VuPlus] Start InitiateSession, validates connection and returns Bouquet reference if required 2016-03-17 00:07:02.4462 Info HttpClient: HttpClientManager GET: http://hostname.no-ip.org:85/web/getservices 2016-03-17 00:07:02.5249 Info HttpClient: HttpClientManager GET: http://hostname.no-ip.org:85/web/epgservice?sRef=1:0:1:57A:68:53:CE40000:0:0:0: 2016-03-17 00:07:02.8558 Error App: [VuPlus] Failed to parse program information. 2016-03-17 00:07:02.8558 Error App: [VuPlus] GetProgramsAsync error: '', hexadecimal value 0x1A, is an invalid character. Line 338, position 40. 2016-03-17 00:07:02.8568 Error App: Error getting programs for channel SPORT TV 2 HD *** Error Report *** Version: 3.0.5882.0 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby -restartpath /usr/sbin/emby.sh Operating system: Unix 3.16.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.2.2 (Stable 4.2.2.30/996df3c Mon Feb 15 17:30:30 UTC 2016) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe Failed to parse channel information. System.ApplicationException at MediaBrowser.Plugins.VuPlus.LiveTvService+<GetProgramsAsync>d__7d.MoveNext () <0x41b32000 + 0x02057> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x7fdba4801860 + 0x00029> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x7fdba47ff840 + 0x000a7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x7fdba47ff7c0 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x7fdba47ff770 + 0x0003a> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x7fdba47ffea0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__d4.MoveNext () <0x41a72000 + 0x018da> in <filename unknown>:0
horstepipe 423 Posted March 23, 2016 Posted March 23, 2016 Hi there, in order to best help you, please see how to report a media playback issue. Thanks. Make sure you have available tuners showing in the WebGui of Emby and the option in the plugin settings checked to switch the tuner. The only thing currently not working for me is importing the picons, neither from WebInterface nor from local folders... sorry for late answer, live tv integration had the smallest priority for me. But now everything else works well, I'll spend my time to it. Here we go: WebGUI shows an available tuner and the option to switch channel is enabled, too. here is my log: 2016-03-23 20:56:02.8021 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:02.8021 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Plugins/SecurityInfo 2016-03-23 20:56:02.8021 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/1068adda3c6342a196f9ffb4225691a3/Items/979ff8c1fc2eb7077860a9fd5bf71be4. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:02.8712 Info App: [VuPlus] Start GetTimerAsync, retrieve the 'Pending' recordings 2016-03-23 20:56:02.8712 Info App: [VuPlus] Start EnsureConnectionAsync 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync HostName: 192.168.0.4 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync StreamingPort: 8001 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePort: 80 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync UseSecureHTTPS: False 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync OnlyOneBouquet: True 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync TVBouquet: Favourites (TV) 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync ZapToChannel: True 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync FetchPiconsFromWebInterface: True 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync PiconsPath: 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync RecordingPath: 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync EnableDebugLogging: False 2016-03-23 20:56:02.8712 Info App: [VuPlus] EnsureConnectionAsync Validation of config parameters completed 2016-03-23 20:56:02.8712 Info App: [VuPlus] Start InitiateSession, validates connection and returns Bouquet reference if required 2016-03-23 20:56:02.8712 Info HttpClient: HttpClientManager GET: http://192.168.0.4:80/web/getservices 2016-03-23 20:56:02.9368 Info HttpClient: HttpClientManager GET: http://192.168.0.4:80/web/timerlist 2016-03-23 20:56:03.0103 Info HttpServer: HTTP Response 200 to ::1. Time: 203ms. http://localhost:8096/emby/Users/1068adda3c6342a196f9ffb4225691a3/Items/979ff8c1fc2eb7077860a9fd5bf71be4 2016-03-23 20:56:03.0264 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/1068adda3c6342a196f9ffb4225691a3/Items/979ff8c1fc2eb7077860a9fd5bf71be4/Intros. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.0264 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/Users/1068adda3c6342a196f9ffb4225691a3/Items/979ff8c1fc2eb7077860a9fd5bf71be4/Intros 2016-03-23 20:56:03.0414 Info HttpServer: HTTP GET http://localhost:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.0414 Info HttpServer: HTTP Response 200 to ::1. Time: 5ms. http://localhost:8096/emby/Playback/BitrateTest?Size=1000000 2016-03-23 20:56:03.0544 Info HttpServer: HTTP GET http://localhost:8096/emby/Playback/BitrateTest?Size=2400000. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.0544 Info HttpServer: HTTP Response 200 to ::1. Time: 11ms. http://localhost:8096/emby/Playback/BitrateTest?Size=2400000 2016-03-23 20:56:03.0834 Info HttpServer: HTTP POST http://localhost:8096/emby/Items/979ff8c1fc2eb7077860a9fd5bf71be4/PlaybackInfo?UserId=1068adda3c6342a196f9ffb4225691a3&StartTimeTicks=0. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.0834 Info App: Bitrate exceeds DirectPlay limit 2016-03-23 20:56:03.0834 Info App: Bitrate exceeds DirectPlay limit 2016-03-23 20:56:03.0834 Info App: Profile: Unknown Profile, Path: http://192.168.0.10:8096, isEligibleForDirectPlay: False, isEligibleForDirectStream: False 2016-03-23 20:56:03.0834 Info App: Bitrate exceeds DirectPlay limit 2016-03-23 20:56:03.0834 Info App: Bitrate exceeds DirectPlay limit 2016-03-23 20:56:03.0834 Info App: Profile: Unknown Profile, Path: http://192.168.0.10:8096, isEligibleForDirectPlay: False, isEligibleForDirectStream: False 2016-03-23 20:56:03.0834 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/Items/979ff8c1fc2eb7077860a9fd5bf71be4/PlaybackInfo?UserId=1068adda3c6342a196f9ffb4225691a3&StartTimeTicks=0 2016-03-23 20:56:03.0834 Info HttpServer: HTTP POST http://localhost:8096/emby/LiveStreams/Open?UserId=1068adda3c6342a196f9ffb4225691a3&StartTimeTicks=0&ItemId=979ff8c1fc2eb7077860a9fd5bf71be4&PlaySessionId=6bb7f4b2ed594e54825fc090c0ed8767. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.0834 Info App: Opening channel stream from VuPlus, external channel Id: 1:0:1:7004:436:1:C00000:0:0:0: 2016-03-23 20:56:03.0834 Info App: [VuPlus] Start GetChannelStream 2016-03-23 20:56:03.0834 Info App: [VuPlus] Start ZapToChannel 2016-03-23 20:56:03.0834 Info App: [VuPlus] Start EnsureConnectionAsync 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync HostName: 192.168.0.4 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync StreamingPort: 8001 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePort: 80 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync UseSecureHTTPS: False 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync OnlyOneBouquet: True 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync TVBouquet: Favourites (TV) 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync ZapToChannel: True 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync FetchPiconsFromWebInterface: True 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync PiconsPath: 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync RecordingPath: 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync EnableDebugLogging: False 2016-03-23 20:56:03.0834 Info App: [VuPlus] EnsureConnectionAsync Validation of config parameters completed 2016-03-23 20:56:03.0834 Info App: [VuPlus] Start InitiateSession, validates connection and returns Bouquet reference if required 2016-03-23 20:56:03.0834 Info HttpClient: HttpClientManager GET: http://192.168.0.4:80/web/getservices 2016-03-23 20:56:03.1565 Info HttpClient: HttpClientManager GET: http://192.168.0.4:80/web/zap?sRef=1:0:1:7004:436:1:C00000:0:0:0: 2016-03-23 20:56:03.2314 Info App: Live stream info: {"Protocol":"Http","Id":"3","Path":"http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:","Type":"Default","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"d37efd43cad0f16f0cc9993500eaec64_3","MediaStreams":[{"IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}} 2016-03-23 20:56:03.2314 Info App: Profile: Unknown Profile, Path: http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-03-23 20:56:03.2314 Info App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0: 2016-03-23 20:56:03.2314 Info App: Profile: Unknown Profile, Path: http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-03-23 20:56:03.2314 Info App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0: 2016-03-23 20:56:03.2314 Info App: Profile: Unknown Profile, Path: http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-03-23 20:56:03.2314 Info App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0: 2016-03-23 20:56:03.2314 Info HttpServer: HTTP Response 200 to ::1. Time: 144ms. http://localhost:8096/emby/LiveStreams/Open?UserId=1068adda3c6342a196f9ffb4225691a3&StartTimeTicks=0&ItemId=979ff8c1fc2eb7077860a9fd5bf71be4&PlaySessionId=6bb7f4b2ed594e54825fc090c0ed8767 2016-03-23 20:56:03.6143 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/0ee7b55b6248a899d4e9ca014ac08222/Images/Primary?width=545&tag=66ce815ce9d1f4575e5661678fc8650e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.6143 Info HttpServer: HTTP GET http://localhost:8096/emby/videos/979ff8c1fc2eb7077860a9fd5bf71be4/stream.webm?DeviceId=2497fd368966cef910ee34a14b00fd3130bf3c5d&MediaSourceId=3&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=-1&VideoBitrate=1535680000&AudioBitrate=320000&MaxAudioChannels=6&PlaySessionId=6bb7f4b2ed594e54825fc090c0ed8767&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_d37efd43cad0f16f0cc9993500eaec64_3&CopyTimestamps=false&EnableAutoStreamCopy=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:03.6153 Info HttpClient: HttpClientManager GET: http://root:xxxxx@192.168.0.4:80/picon/1_0_1_7004_436_1_C00000_0_0_0.png 2016-03-23 20:56:03.6153 Info App: C:\Users\horstepipe\AppData\Roaming\Emby-Server\ffmpeg\20160131\ffmpeg.exe -fflags +genpts -i "http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 8000000 -bufsize:v (8000000*2) -b:v 8000000 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ac 6 -ab 320000 -af "aresample=async=1" -y "C:\Users\horstepipe\AppData\Roaming\Emby-Server\transcoding-temp\9d826df55be2ed394508016b124664e6.webm" 2016-03-23 20:56:03.6153 Error HttpClient: Error getting response from http://root:xxxxx@192.168.0.4:80/picon/1_0_1_7004_436_1_C00000_0_0_0.png *** Error Report *** Version: 3.0.5916.0 Command line: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\horstepipe\AppData\Roaming\Emby-Server Application Path: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Mindestens ein Fehler ist aufgetreten. System.AggregateException bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) bei MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1b.MoveNext() InnerException: System.Net.WebException Der Remoteserver hat einen Fehler zurückgegeben: (401) Nicht autorisiert. bei System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) bei System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2016-03-23 20:56:03.6153 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5916.0 Command line: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\horstepipe\AppData\Roaming\Emby-Server Application Path: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Mindestens ein Fehler ist aufgetreten. MediaBrowser.Model.Net.HttpException bei MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1b.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__5.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Providers.Manager.ProviderManager.<SaveImage>d__a.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Server.Implementations.Library.LibraryManager.<ConvertImageToLocal>d__138.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei Emby.Drawing.ImageProcessor.<ProcessImage>d__7.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Api.Images.ImageService.<GetImageResult>d__f.MoveNext() InnerException: System.AggregateException Mindestens ein Fehler ist aufgetreten. bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) bei MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1b.MoveNext() InnerException: System.Net.WebException Der Remoteserver hat einen Fehler zurückgegeben: (401) Nicht autorisiert. bei System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) bei System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2016-03-23 20:56:03.6153 Error HttpServer: Error processing request for /emby/Items/0ee7b55b6248a899d4e9ca014ac08222/Images/Primary?width=545&tag=66ce815ce9d1f4575e5661678fc8650e&quality=90 *** Error Report *** Version: 3.0.5916.0 Command line: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\horstepipe\AppData\Roaming\Emby-Server Application Path: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Mindestens ein Fehler ist aufgetreten. ServiceStack.HttpError No Stack Trace Available 2016-03-23 20:56:03.6153 Info HttpServer: HTTP Response 500 to ::1. Time: 11ms. http://localhost:8096/emby/Items/0ee7b55b6248a899d4e9ca014ac08222/Images/Primary?width=545&tag=66ce815ce9d1f4575e5661678fc8650e&quality=90 2016-03-23 20:56:03.6793 Info App: FFMpeg exited with code 1 2016-03-23 20:56:04.7617 Error App: Error streaming media. The client has most likely disconnected or transcoding has failed. *** Error Report *** Version: 3.0.5916.0 Command line: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\horstepipe\AppData\Roaming\Emby-Server Application Path: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Mindestens ein Fehler ist aufgetreten. System.AggregateException bei System.Threading.Tasks.Task.WaitAll(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) bei MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.WriteToInternal(Stream responseStream) InnerException: System.IO.FileNotFoundException Die Datei "C:\Users\horstepipe\AppData\Roaming\Emby-Server\transcoding-temp\9d826df55be2ed394508016b124664e6.webm" konnte nicht gefunden werden. bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) bei System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) bei System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize) bei CommonIO.ManagedFileSystem.GetFileStream(String path, FileMode mode, FileAccess access, FileShare share, Boolean isAsync) bei MediaBrowser.Api.Playback.Progressive.ProgressiveFileCopier.<StreamFile>d__0.MoveNext() 2016-03-23 20:56:04.7617 Info HttpServer: HTTP Response 500 to ::1. Time: 1148ms (slow). http://localhost:8096/emby/videos/979ff8c1fc2eb7077860a9fd5bf71be4/stream.webm?DeviceId=2497fd368966cef910ee34a14b00fd3130bf3c5d&MediaSourceId=3&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=-1&VideoBitrate=1535680000&AudioBitrate=320000&MaxAudioChannels=6&PlaySessionId=6bb7f4b2ed594e54825fc090c0ed8767&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_d37efd43cad0f16f0cc9993500eaec64_3&CopyTimestamps=false&EnableAutoStreamCopy=false 2016-03-23 20:56:04.8077 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0 2016-03-23 20:56:04.8077 Info App: Deleting partial stream file(s) C:\Users\horstepipe\AppData\Roaming\Emby-Server\transcoding-temp\9d826df55be2ed394508016b124664e6.webm 2016-03-23 20:56:04.8077 Info App: Closing live stream from VuPlus, stream Id: 3 2016-03-23 20:56:04.8077 Error App: Error closing live stream *** Error Report *** Version: 3.0.5916.0 Command line: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\horstepipe\AppData\Roaming\Emby-Server Application Path: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Die Methode oder der Vorgang ist nicht implementiert. System.NotImplementedException bei MediaBrowser.Plugins.VuPlus.LiveTvService.<CloseLiveStream>d__99.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<CloseLiveStream>d__1ed.MoveNext() 2016-03-23 20:56:04.8077 Error SessionManager: Error closing live stream *** Error Report *** Version: 3.0.5916.0 Command line: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\horstepipe\AppData\Roaming\Emby-Server Application Path: C:\Users\horstepipe\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Die Methode oder der Vorgang ist nicht implementiert. System.NotImplementedException bei MediaBrowser.Plugins.VuPlus.LiveTvService.<CloseLiveStream>d__99.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<CloseLiveStream>d__1ed.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Server.Implementations.Library.MediaSourceManager.<CloseLiveStream>d__4b.MoveNext() --- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde --- bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) bei MediaBrowser.Server.Implementations.Session.SessionManager.<OnPlaybackStopped>d__5d.MoveNext() 2016-03-23 20:56:04.8077 Info Trakt: Playback Stopped 2016-03-23 20:56:04.8077 Error Trakt: Could not match trakt user 2016-03-23 20:56:04.8077 Info HttpServer: HTTP Response 204 to ::1. Time: 2ms. http://localhost:8096/emby/Sessions/Playing/Stopped 2016-03-23 20:56:05.3209 Info App: Emby.Kodi.SyncQueue: Starting User Changes Sync... 2016-03-23 20:56:05.3209 Info App: [VuPlus] Start GetRecordingsAsync, retrieve all 'Inprogress' and 'Completed' recordings 2016-03-23 20:56:05.3209 Info App: [VuPlus] Start EnsureConnectionAsync 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync HostName: 192.168.0.4 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync StreamingPort: 8001 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync WebInterfacePort: 80 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync WebInterfaceUsername: ******** 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync UseSecureHTTPS: False 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync OnlyOneBouquet: True 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync TVBouquet: Favourites (TV) 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync ZapToChannel: True 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync FetchPiconsFromWebInterface: True 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync PiconsPath: 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync RecordingPath: 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync EnableDebugLogging: False 2016-03-23 20:56:05.3209 Info App: [VuPlus] EnsureConnectionAsync Validation of config parameters completed 2016-03-23 20:56:05.3209 Info App: [VuPlus] Start InitiateSession, validates connection and returns Bouquet reference if required 2016-03-23 20:56:05.3209 Info HttpClient: HttpClientManager GET: http://192.168.0.4:80/web/getservices 2016-03-23 20:56:05.3893 Info HttpClient: HttpClientManager GET: http://192.168.0.4:80/web/movielist 2016-03-23 20:56:05.7378 Info App: Emby.Kodi.SyncQueue: "USERSYNC" User 1068adda3c6342a196f9ffb4225691a3(horstepipe) posted 2 Updates: 979ff8c1fc2eb7077860a9fd5bf71be4(Live-TV, Comedy Central/VIVA),df7576921e2a4fb04a4453600aa32c76(Live-TV) 2016-03-23 20:56:05.7378 Info App: Emby.Kodi.SyncQueue: User Changes Sync Finished Taking 00:00:00.4169325 and a logfile called "transcode" http://localhost:8096/emby/videos/979ff8c1fc2eb7077860a9fd5bf71be4/stream.webm?DeviceId=2497fd368966cef910ee34a14b00fd3130bf3c5d&MediaSourceId=3&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=-1&VideoBitrate=1535680000&AudioBitrate=320000&MaxAudioChannels=6&PlaySessionId=6bb7f4b2ed594e54825fc090c0ed8767&api_key=e6820a057dbb4aebbb03174d5bc82681&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_d37efd43cad0f16f0cc9993500eaec64_3&CopyTimestamps=false&EnableAutoStreamCopy=false {"Protocol":"Http","Id":"3","Path":"http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:","Type":"Default","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"1a755974de5dc3461dc6ecae8ddec68b_d37efd43cad0f16f0cc9993500eaec64_3","MediaStreams":[{"IsInterlaced":true,"BitRate":8000000,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":8000000,"RequiredHttpHeaders":{}} C:\Users\horstepipe\AppData\Roaming\Emby-Server\ffmpeg\20160131\ffmpeg.exe -fflags +genpts -i "http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 8000000 -bufsize:v (8000000*2) -b:v 8000000 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ac 6 -ab 320000 -af "aresample=async=1" -y "C:\Users\horstepipe\AppData\Roaming\Emby-Server\transcoding-temp\9d826df55be2ed394508016b124664e6.webm" ffmpeg version N-78218-gc86ecdf Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libopenh264 --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 16.101 / 55. 16.101 libavcodec 57. 24.100 / 57. 24.100 libavformat 57. 23.101 / 57. 23.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 27.100 / 6. 27.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [http @ 000002128b9299c0] HTTP error 401 Unauthorized http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:: Server returned 401 Unauthorized (authorization failed) http://192.168.0.4:8001/1:0:1:7004:436:1:C00000:0:0:0:: Server returned 401 Unauthorized (authorization failed) Tried both port 8001 and transcoding port 8002
Luke 42241 Posted March 23, 2016 Posted March 23, 2016 The VuPlus tv server is throwing a 401 unauthorized error. I am not an expert on that software so I cannot explain why it might be doing that, but I'm sure there are others in here who can. 1
horstepipe 423 Posted March 23, 2016 Posted March 23, 2016 (edited) thank you, here is some other strange behavior: When I uncheck "fetch picons from webinterface" the tuner disappears from live tv tuner page... I'm using 400x170px picons stored in /usr/share/enigma2/picon if this is of importance Edited March 23, 2016 by horstepipe
horstepipe 423 Posted March 23, 2016 Posted March 23, 2016 works now! Disabled authentification for streaming (authentification for http is still active) in openwebif settings of my VU+. some minor things: - Is it normal that the channel list needs quite long (15 secs) to show up? Can't it be cached somehow? - Picons only show up under "suggestions" - would be nice if the picons format could be adjusted to the existing format. Emby only shows them in squares, but mine (400x170px) are rectangular. But that's just "nice to have", I'm happy that it works now. Thank's for the plugin and for help. Regards
Lee 212 Posted March 25, 2016 Posted March 25, 2016 works now! Disabled authentification for streaming (authentification for http is still active) in openwebif settings of my VU+. some minor things: - Is it normal that the channel list needs quite long (15 secs) to show up? Can't it be cached somehow? - Picons only show up under "suggestions" - would be nice if the picons format could be adjusted to the existing format. Emby only shows them in squares, but mine (400x170px) are rectangular. But that's just "nice to have", I'm happy that it works now. Thank's for the plugin and for help. Regards you can manually adjust the picons in the web dashboard. if you go to live tv > channels then click the 3 dots you get edit images. admittedly that can be time consuming but the option is there... 1
chrisoldroyd 12 Posted April 21, 2016 Posted April 21, 2016 Anyone else have transcoding issues using this? The stream appears but doesn't play even an SD stream, just a spinning wheel. Is transcoding really necessary? I am using an iPad and I am sure it could handle the content? Thanks Chris
Del007 0 Posted April 21, 2016 Posted April 21, 2016 Hey there I'm very new to Emby. I've managed to add .m3u's to live tv, some of them play well and some of them don't but that could be down to the .m3u file. I've been reading that I can use VU+ box through Emby. I've installed the VU+ plugin from Emby but I'm lost as to what to put into the settings. I've tried searching google/youtube but I'm not having any luck. Does anyone have any step by step guide or a video tutorial to how to get it to work?# Cheers for you help
Lee 212 Posted April 27, 2016 Posted April 27, 2016 Hey there I'm very new to Emby. I've managed to add .m3u's to live tv, some of them play well and some of them don't but that could be down to the .m3u file. I've been reading that I can use VU+ box through Emby. I've installed the VU+ plugin from Emby but I'm lost as to what to put into the settings. I've tried searching google/youtube but I'm not having any luck. Does anyone have any step by step guide or a video tutorial to how to get it to work?# Cheers for you help Same settings as in openwebif (assuming you have used that?)
