CompoUK 16 Posted March 13, 2015 Author Posted March 13, 2015 (edited) While in the Dev mode, I couldn't update the latest plug 1.0.2, as many times that I restarts the server or closed the computer down for a clean restart it doesn't seems to update, I have added a log for your review. resolved Congrat "I am now able to play Live TV through VuPlus" excellent Job, You've nailed it I think that is the main issue the rest will be resolved in no time. However, I noticed that Picon did not dispalyed on I.0.3, so I changed the location to C:\Users\Dell 9020\Desktop\Picon from \\WDMYCLOUDEX4\Public_2\Logos, this cause all tuners to disappear hence no TV channels is displayed, then I change it back and then restart server, then TV channels lisiting resumed but no Picon still. On my Kodi Live TV the Picon path is set to =>>\\WDMYCLOUDEX4\Public_2\Logos, and this work fine, not sure why MB3 did not show I have attached few logs, not meant to overwheelm you but hope it provide sufficient info to establish the issue Cheers! Nice Big One server-63561787663.txt server-63561787838.txt server-63561787970.txt server-63561788015.txt server-63561788192.txt transcode-b7e9ea76-1e66-400f-94d0-3d888b521684.txt transcode-ee358152-a524-4a87-bbe6-85adf170895f.txt That's good news. Regarding the picons, the logs show your config was set to the following 2 paths: 2015-03-12 20:07:51.0401 Info - App: [VuPlus] EnsureConnectionAsync PiconsPath: C:\Users\Dell 9020\Desktop\Picon 2015-03-12 20:13:02.7116 Info - App: [VuPlus] EnsureConnectionAsync PiconsPath: \\WDMYCLOUDEX4\Public_2\Logos You need to add a back slash to the end of them. So in your config you need to have it set to \\WDMYCLOUDEX4\Public_2\Logos\ Please give it a try and see if that fixes it for you. Edited March 13, 2015 by CompoUK
e123enitan 276 Posted March 13, 2015 Posted March 13, 2015 I will try include "\" and report back. Just as an FYI, I tried Live TV on my MB Android wifi, it works like a cham, no bufurringor lag once it started streaming, although my wifi is strong, one thing which is obvious between LAN/WIFI connections are the speed of launching channels is slow, I will suggest we need to log time to establish were it lag for possible improvement. Thanks
t123thomas 63 Posted March 16, 2015 Posted March 16, 2015 Hi C-UK, to keep you update, I have done as suggested adding back slash \ but doesn't show. so I opt for, getting the picons throught Vu box to interface openwebif if that would help, I shall keep you posted. Thanks 1
CompoUK 16 Posted March 16, 2015 Author Posted March 16, 2015 (edited) Hi C-UK, to keep you update, I have done as suggested adding back slash \ but doesn't show. so I opt for, getting the picons throught Vu box to interface openwebif if that would help, I shall keep you posted. Thanks Was it on all of the Live TV pages? Since my Server was recently updated to the latest set of dev builds which included changes to the Live TV suggested page, the suggested page is no longer showing the picons - others are OK apart from when you select a program from the guide. If you could post a copy of your logs where you added the \ at the end, I will try and recreate the issue. Edited March 16, 2015 by CompoUK
e123enitan 276 Posted March 17, 2015 Posted March 17, 2015 (edited) OK when I get home, I will creat a log for your review Edited March 17, 2015 by e123enitan
retsok 2 Posted March 18, 2015 Posted March 18, 2015 I'm so happy now with this new Vu+ LiveTV add-on, just where I was waiting for. Keep up the good work!! After installing the add-on I have for some reason an one hour difference in the TV guide of any channel on Android and web browser view. MB Server side has the right time and also the VU+ Duo2 tuner (Central European Time +1 UTC) I also use XBMC and MB skin with the PVR VU+ add-on enabled and the timing on this TV guide seems in sync without one hour difference. Is there a solution for this problem? Thanks in advance.
CompoUK 16 Posted March 19, 2015 Author Posted March 19, 2015 I'm so happy now with this new Vu+ LiveTV add-on, just where I was waiting for. Keep up the good work!! After installing the add-on I have for some reason an one hour difference in the TV guide of any channel on Android and web browser view. MB Server side has the right time and also the VU+ Duo2 tuner (Central European Time +1 UTC) I also use XBMC and MB skin with the PVR VU+ add-on enabled and the timing on this TV guide seems in sync without one hour difference. Is there a solution for this problem? Thanks in advance. I'm not sure about this one. I looked at other LiveTv plugins for MB and the XBMC/Kodi Vu+ addon and I can't see anything in the code relating to time zones. Can anyone else who is not on GMT confirm whether they are having the same issues?
e123enitan 276 Posted March 20, 2015 Posted March 20, 2015 I'm not sure about this one. I looked at other LiveTv plugins for MB and the XBMC/Kodi Vu+ addon and I can't see anything in the code relating to time zones. Can anyone else who is not on GMT confirm whether they are having the same issues? Good to see another users of Vu+ on board, does any one noticed a slow channels switched in Kodi/Vu+ and possible enhancement to speed up channels changing. Cheers
retsok 2 Posted March 29, 2015 Posted March 29, 2015 I'm not sure about this one. I looked at other LiveTv plugins for MB and the XBMC/Kodi Vu+ addon and I can't see anything in the code relating to time zones. Can anyone else who is not on GMT confirm whether they are having the same issues? Now that we are moved to summer time (GMT +2 CET) and UK time (GMT +1) I noticed that the tv guide has now jumped from 1 hour to 2 hours difference. Could you please check if your guide is in sync with your UK time or that you now also facing a one hour difference. Thanks
CompoUK 16 Posted March 29, 2015 Author Posted March 29, 2015 (edited) Now that we are moved to summer time (GMT +2 CET) and UK time (GMT +1) I noticed that the tv guide has now jumped from 1 hour to 2 hours difference. Could you please check if your guide is in sync with your UK time or that you now also facing a one hour difference. Thanks Just checked and my TV guide is now an hour out Edited March 29, 2015 by CompoUK
retsok 2 Posted March 30, 2015 Posted March 30, 2015 Just checked and my TV guide is now an hour out Hopefully the developers of Emby can advise where to modify the code to setup the local time issue. Let's hope it will be easy solution. Thanks for your update.
CompoUK 16 Posted April 2, 2015 Author Posted April 2, 2015 Hopefully the developers of Emby can advise where to modify the code to setup the local time issue. Let's hope it will be easy solution. Thanks for your update. EPG times should now be fixed.
wally007 6 Posted April 3, 2015 Posted April 3, 2015 hello CompoUK, im about to have weekend to myself so i thought about giving MB3 a annual test and would like to test live tv as well. Regarding limitations of this plugin, are they limitations of dreambox api, MB3 or its just not implemented yet ? Series recording is a biggie at home so in case its not possible, id try dvblink as a middle man thanks EPG times should now be fixed.
CompoUK 16 Posted April 3, 2015 Author Posted April 3, 2015 (edited) hello CompoUK, im about to have weekend to myself so i thought about giving MB3 a annual test and would like to test live tv as well. Regarding limitations of this plugin, are they limitations of dreambox api, MB3 or its just not implemented yet ? Series recording is a biggie at home so in case its not possible, id try dvblink as a middle man thanks The main limitations are down to the api and that series recordings are not natively supported by these tuner boxes. There is a plugin called autotimer, I will look into this and see what the api provides. If you need series recording now then you need to look elsewhere. Edited April 3, 2015 by CompoUK
e123enitan 276 Posted April 4, 2015 Posted April 4, 2015 Few questions - First Just wondering why a delay in playing a channel in Emby, but in the Vuplus it very fast. Second I have not been able to add pic on to my channels list. Is there a path or folder in the server where the picons are saved if that would help.
retsok 2 Posted April 4, 2015 Posted April 4, 2015 EPG times should now be fixed. Hi CompoUK, It seems for UK time to be fixed, but I have instead of 2 hours offset now 1 hour offset. So not completely fixed yet. Hopefully you can have a look at it again. Thanks in advance.
retsok 2 Posted April 4, 2015 Posted April 4, 2015 Few questions - First Just wondering why a delay in playing a channel in Emby, but in the Vuplus it very fast. Second I have not been able to add pic on to my channels list. Is there a path or folder in the server where the picons are saved if that would help. Hi e123enitan, The delay has probably to do with the transcoding that needs to be done on the server side. This needs to be started to be able to stream your channel. The plugin will retrieve the Picons from your VU+ box. The usual folder (depending on which VU+ image you are using) will be /usr/share/enigma2/picon/ on your VU+ box. If you have your picons on your VU+ box present it will retrieve it from there. You can set the folder location in the VU+ add-on settings.
CompoUK 16 Posted April 5, 2015 Author Posted April 5, 2015 Hi CompoUK, It seems for UK time to be fixed, but I have instead of 2 hours offset now 1 hour offset. So not completely fixed yet. Hopefully you can have a look at it again. Thanks in advance. I just altered my timezone and it appears to adjust correctly. Are you able to look at the logs and find any program eg <e2event> <e2eventid>62602</e2eventid> <e2eventstart>1428235200</e2eventstart> <e2eventduration>900</e2eventduration> <e2eventcurrenttime>1428228067</e2eventcurrenttime> <e2eventtitle>BBC News</e2eventtitle> <e2eventdescription></e2eventdescription> ..... Then check the e2eventstart value (which should be the UTC time the program starts) by entering its value on website http://www.epochconverter.com/ For me, by entering 1428235200, I got the following result which is correct: GMT: Sun, 05 Apr 2015 12:00:00 GMT Your time zone: 4/5/2015, 1:00:00 PM GMT+1:00 DST This matches with the start time of the program which, is 1pm my time. Are you able to see what results you get and confirm which values you have are correct and which are wrong?
retsok 2 Posted April 5, 2015 Posted April 5, 2015 (edited) I just altered my timezone and it appears to adjust correctly. Are you able to look at the logs and find any program eg <e2event> <e2eventid>62602</e2eventid> <e2eventstart>1428235200</e2eventstart> <e2eventduration>900</e2eventduration> <e2eventcurrenttime>1428228067</e2eventcurrenttime> <e2eventtitle>BBC News</e2eventtitle> <e2eventdescription></e2eventdescription> ..... Then check the e2eventstart value (which should be the UTC time the program starts) by entering its value on website http://www.epochconverter.com/ For me, by entering 1428235200, I got the following result which is correct: GMT: Sun, 05 Apr 2015 12:00:00 GMT Your time zone: 4/5/2015, 1:00:00 PM GMT+1:00 DST This matches with the start time of the program which, is 1pm my time. Are you able to see what results you get and confirm which values you have are correct and which are wrong? This is what I could find in the logs : <e2event> <e2eventid>6289</e2eventid> <e2eventstart>1428235500</e2eventstart> <e2eventduration>3300</e2eventduration> <e2eventcurrenttime>1428235389</e2eventcurrenttime> <e2eventtitle>Het Uur van de Wolf</e2eventtitle> <e2eventdescription></e2eventdescription> ........ The translation of 1428235500 will be : GMT: Sun, 05 Apr 2015 12:05:00 GMT Your time zone: 5-4-2015 14:05:00 GMT+2:00 DST That is correct, but in Emby it will show like : So the time for "Mo Actueel" should be 15:25 local time and the time for " Het uur van de Wolf" should be 14:05 local time. So the problem lies not at GMT, but still on local time translation. Server time is set on local time "Amsterdam". PC time, Android and VU+ box are set on local time. The guide on VU+ box is giving the correct values. Also using the VU+ PVR add-on for Kodi is giving the correct times in the tv guide. Hopefully this will help you further. Edited April 5, 2015 by retsok
CompoUK 16 Posted April 5, 2015 Author Posted April 5, 2015 (edited) Thanks. Can you please test again with the latest version and see how you get on? This is what I could find in the logs : <e2event> <e2eventid>6289</e2eventid> <e2eventstart>1428235500</e2eventstart> <e2eventduration>3300</e2eventduration> <e2eventcurrenttime>1428235389</e2eventcurrenttime> <e2eventtitle>Het Uur van de Wolf</e2eventtitle> <e2eventdescription></e2eventdescription> ........ The translation of 1428235500 will be : GMT: Sun, 05 Apr 2015 12:05:00 GMT Your time zone: 5-4-2015 14:05:00 GMT+2:00 DST That is correct, but in Emby it will show like : So the time for "Mo Actueel" should be 15:25 local time and the time for " Het uur van de Wolf" should be 14:05 local time. So the problem lies not at GMT, but still on local time translation. Server time is set on local time "Amsterdam". PC time, Android and VU+ box are set on local time. The guide on VU+ box is giving the correct values. Also using the VU+ PVR add-on for Kodi is giving the correct times in the tv guide. Hopefully this will help you further. Edited April 5, 2015 by CompoUK
retsok 2 Posted April 5, 2015 Posted April 5, 2015 Thanks. Can you please test again with the latest version and see how you get on? Excellent, TV guide is now showing the right times. Thanks for solving this problem. Keep up the good work!
retsok 2 Posted April 5, 2015 Posted April 5, 2015 Now that this has been fixed I found another issue and probably also related to time zone. When I want to record a TV show from the TV guide it first will show you the correct time that you scheduled the recording, but looking at "Scheduled" under Live TV menu in Emby it has changed to 1 hour offset again. For example, scheduled recording at 05:00 and under "Scheduled" menu it shows 04:00. You probably need to do the same magic here as well.
CompoUK 16 Posted April 6, 2015 Author Posted April 6, 2015 Now that this has been fixed I found another issue and probably also related to time zone. When I want to record a TV show from the TV guide it first will show you the correct time that you scheduled the recording, but looking at "Scheduled" under Live TV menu in Emby it has changed to 1 hour offset again. For example, scheduled recording at 05:00 and under "Scheduled" menu it shows 04:00. You probably need to do the same magic here as well. Please can you try the latest version to see if it is fixed now?
retsok 2 Posted April 6, 2015 Posted April 6, 2015 Please can you try the latest version to see if it is fixed now? Installed the latest 1.0.0.8 release and problem is still present. When I select a TV Show that I would like to record I am getting the following window : When I press the Record button it will show me the scheduled menu and that looks like this : Recording should start at 18:07 instead of 17:07.
