snazy2000 344 Posted March 4, 2015 Posted March 4, 2015 I have beta app, and i am on latest version and i go to the devices tab and my android device isnt on there and i click camera upload and says no devices. Ive tried logging out and logging in and just wont appear.
CBers 7554 Posted March 4, 2015 Posted March 4, 2015 Goto the Accounts section of settings on your device and make sure the MediaBrowser account has sync enabled.
snazy2000 344 Posted March 5, 2015 Author Posted March 5, 2015 I cant see any sync settings in the mb android app?
snazy2000 344 Posted March 5, 2015 Author Posted March 5, 2015 All sync stuff enabled on mb server, it should still find the device it self on the device list if im signed in though
CBers 7554 Posted March 5, 2015 Posted March 5, 2015 I cant see any sync settings in the mb android app? On the phone/tablet, not in MB App. You do have photos to upload?
snazy2000 344 Posted March 5, 2015 Author Posted March 5, 2015 Ah i see ive enabled that, it now shows in devices but still not in camera upload it says. " You currently don't have any devices that support camera upload." There is loads of photos on my phone and i have take some now to test
thefirstofthe300 292 Posted March 5, 2015 Posted March 5, 2015 I have found that unless the MB Android app is open and connected to the server while I am attempting to configure the server to upload, I get the message you are getting.
richardap1 10 Posted March 5, 2015 Posted March 5, 2015 I am having issues as well. All is set up on the server and it has uploaded about 10 images, but thats it. I can't seem to force it to upload more. I have two sync accounts and i have enabled both just as a test. I can force a manual sync but other than that it doesn't seem to try.
CBers 7554 Posted March 5, 2015 Posted March 5, 2015 There's no option (yet) to upload over wifi only. Not that I've found. 1
hedgehogg 104 Posted March 5, 2015 Posted March 5, 2015 Ignore I'm just too impatient loads there now 1
snazy2000 344 Posted March 5, 2015 Author Posted March 5, 2015 I really dont get whats going on with my device :/
