paul777 13 Posted March 4, 2015 Posted March 4, 2015 (edited) I thought I'd start a new topic for this as it has wider implications that the original thread where it came up. The IsAnamorphic flag in the media info isn't picking up correctly. I believe the code in MediaEncoderHelper.GetMediaStream needs to look something like this - which may be better added as a helper property on the actual streamInfo if (string.Equals(streamInfo.sample_aspect_ratio, "1:1", StringComparison.OrdinalIgnoreCase)) stream.IsAnamorphic = false; else if (!((streamInfo.sample_aspect_ratio==String.Empty) || (string.Equals(streamInfo.sample_aspect_ratio, "0:1", StringComparison.OrdinalIgnoreCase)))) stream.IsAnamorphic = true; else if (streamInfo.display_aspect_ratio==String.Empty || string.Equals(streamInfo.display_aspect_ratio, "0:1", StringComparison.OrdinalIgnoreCase)) stream.IsAnamorphic = false; else { string[] ratioParts = streamInfo.display_aspect_ratio.Split(':'); if (ratioParts.Length != 2) stream.IsAnamorphic = false; else { int ratio0; int ratio1; if (!Int32.TryParse(ratioParts[0],out ratio0)) stream.IsAnamorphic = false; else if (!Int32.TryParse(ratioParts[1],out ratio1)) stream.IsAnamorphic = false; else stream.IsAnamorphic = ((streamInfo.width * ratio1) != (stream.Height * ratio0)); } } with this in place, if I force a refresh the Anamorphic flag looks correct across my library Edited March 4, 2015 by paul777
paul777 13 Posted March 4, 2015 Author Posted March 4, 2015 (edited) My ultimate goal is trying to get a DLNA which will transcode Anamorphic videos as many TVs don't support anamorphic streams properly. I have added this line to the video codec profiles <ProfileCondition condition="NotEquals" property="IsAnamorphic" value="true" isRequired="false" /> and it is now performing transcoding, the only problem is that the output is still anamorphic. I have attached the transcode log file. Can anyone tell me how to force the transcode to output non-anamorphic files? thanks Paul transcode-587df496-05cb-4638-8796-c912b3b0384e.txt Edited March 4, 2015 by paul777
paul777 13 Posted March 4, 2015 Author Posted March 4, 2015 If I force a lower bitrate for the dlna profile the transcoding then produces non-anamorphic streams, the 2 command lines for ffmpeg are here 1. Still produces anamorphic stream C:\Users\mceuser\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150110\ffmpeg.exe -fflags +genpts -i file:"\\lounge\media\Movies\DVD AC3\21 Jump Street (2012).mp4" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 2 -ab 128000 -af "aresample=async=1" -y "D:\Mediabrowser\transcodeTemp\2eb014b981879eec95ad881968a96741.ts" 2. Produces low quality non-anamorphic stream due to forced low bitrate in dlna profile C:\Users\mceuser\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150110\ffmpeg.exe -fflags +genpts -i file:"\\lounge\media\Movies\DVD AC3\21 Jump Street (2012).mp4" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "scale=min(iw\,426):trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 122000 -bufsize 244000 -vsync vfr -level 51 -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 2 -ab 128000 -af "aresample=async=1" -y "D:\Mediabrowser\transcodeTemp\eaa5a8b3e9ee5b5acd28a7daa6583711.ts"
paul777 13 Posted March 4, 2015 Author Posted March 4, 2015 (edited) Ok, so I think I have answered this question MediaBrowser.Model.Dlna.StreamBuilder contains this code in ApplyTranscodingCondtions case ProfileConditionValue.IsAnamorphic: case ProfileConditionValue.AudioProfile: case ProfileConditionValue.Has64BitOffsets: case ProfileConditionValue.PacketLength: case ProfileConditionValue.VideoTimestamp: { // Not supported yet break; } so I guess we just have to wait for those to be implemented Edited March 4, 2015 by paul777
Luke 42184 Posted March 4, 2015 Posted March 4, 2015 Good investigation. Your first post is still useful here although do you have a reference for that information? For IsAnamorphic it can currently be used as part of the direct stream vs transcoding decision making, but once it decides to transcode we haven't added anyway to configure parameters differently based on that value
paul777 13 Posted March 4, 2015 Author Posted March 4, 2015 The code in my first post does seem to work well. the information has been gleaned from a lot of hunting. The basics are that ffprobe returns aspect of 0:1 when it is not specified in the source. A known non-anamorphic file will have sample apsect of 1:1. But where it isn't specified but we do have a display ratio we can calculate the sample ratio to check. One thing the code doesn't allow for is a tolerance - I have seen files with sample aspect ratios of very close to 1:1 and probably anything between 0.98 and 1.02 isn't worth correcting. The issue now is that it triggers transcoding but only as a stream copy, we need to force it to actually do a transcode when we want to remove the anamophic nature of a stream.
paul777 13 Posted March 4, 2015 Author Posted March 4, 2015 So I have got this to work - not sure if it is the way people would envisage but he code is in the attached zip based on a head cut downloaded on 3rd March. With these changes, the use of the below |CodecProfile condition, and a rebuild of metadata to ensure the Anamorphic flag in the media info is correct it all works as it should. <ProfileCondition condition="NotEquals" property="IsAnamorphic" value="true" isRequired="true" /> Files in the attached Api BaseStreamingService.cs StreamRequest.cs Model StreamInfo.cs StreamBuilder.cs MediaEncoding EncodingJobFactory.cs MediaEncoder.cs Controller EncodingJobOptions.cs MediaEncoderHelper.cs As an aside the way the Params string is built in StreamInfo.BuildDlnaParam and then parsed in BaseStreamingService.ParseParams seems very nasty and prone to bugs being introduced, the use of unknown index constants and creating a non-explicit tie between 2 libraries needing to be on the same version. It also took me some time to find it and figure it out. An object to wrap this that is common to both libraries with a SerializeToString and PasreFromString would probably be useful. ChangedFiles.zip
paul777 13 Posted March 5, 2015 Author Posted March 5, 2015 I have found that there is further work was needed - the above results in videos which are shrunk to fit the aspect ratio due to two issues I found 1) BaseStreamingService.GetOutputSizeParam needed tweeking to ensure that anamorphic videos are upscaled in one dimension to keep as much information as possible within the max/min limits allowed - previously a 720x432 2.40:0 source was scaled down to 720x300 and then the TV had to upscale to 1920x800. With the modification in the attached file the source is transcode to 1036x432 preserving all the possible quality. 2) BaseStreamingService.GetState calls the ResolutionNormalizer which has limits set that are aggressive when trying to allow an anamorphic video to upscale, the video I was testing with was 720x432 843kpbs that wanted upscaling to 1036x432 but was being blocked by the resolution normalizer. I removed the normalizer but if it is felt important then the limits need changing to have lower bitrate limits for each of the resolutions.The ResolutionNormalizer also currently causes the loss of the MaxHeight property which is probably not appropriate. BaseStreamingService.zip
paul777 13 Posted April 2, 2015 Author Posted April 2, 2015 I have submitted the relevant changes as a pull request. The family noticed when an auto-update of the server wiped out my custom build of the server and broke it again - my 5year old asked why fireman sam was so thin today :-)
