madfloyd 0 Posted November 8, 2013 Posted November 8, 2013 If I watch a dvd rip it is a tiny rectangle in the middle of my 1080p screen. I don't recall making any settings changes. I'm using MPC-HC with MADVR and I've checked the Madvr settings to make sure I'm still upscaling and the settings look right. Any ideas what the culprit could be? It's driving me nuts...
swhitmore 781 Posted November 8, 2013 Posted November 8, 2013 You using WMC? If you are, press the 'info' button, and goto 'Zoom'. Check the setting on that.
madfloyd 0 Posted November 8, 2013 Author Posted November 8, 2013 You using WMC? If you are, press the 'info' button, and goto 'Zoom'. Check the setting on that. I am using WMC (media browser 3 classic). I don't have a remote so not sure what the info button equivalent is on the pc keyboard?
swhitmore 781 Posted November 8, 2013 Posted November 8, 2013 (edited) I am using WMC (media browser 3 classic). I don't have a remote so not sure what the info button equivalent is on the pc keyboard? CTRL + i I believe. or CTRL + D... Check here: Windows Media Center keyboard shortcuts Edited November 8, 2013 by swhitmore
david3663 29 Posted November 8, 2013 Posted November 8, 2013 (edited) I think he said he was using mpc-hc if so just right click on the screen during playback and adjust the aspect ratio/ pan & scan settings.. Edited November 8, 2013 by david3663
madfloyd 0 Posted November 8, 2013 Author Posted November 8, 2013 I think he said he was using mpc-hc if so just right click on the screen during playback and adjust the aspect ratio/ pan & scan settings.. I did try that but wasn't sure what option to choose. Along with choices like 'double size' there is a 'stretch to fill screen' which seems to work but the quality of scaling looks bad (or so it was my impression). Is the right one to use? I believe I had it this way and then played a 4:3 (1.33:1) and the aspect ratio was wrong (stretched sideways). There doesn't seem to be a 'stretch to fill screen but maintain original aspect ratio' that I could see....???
ebr 16332 Posted November 8, 2013 Posted November 8, 2013 There doesn't seem to be a 'stretch to fill screen but maintain original aspect ratio' that I could see....??? I don't use MPC but if that option exists, I'm pretty sure it will be called "zoom".
madfloyd 0 Posted November 8, 2013 Author Posted November 8, 2013 I don't use MPC but if that option exists, I'm pretty sure it will be called "zoom". Yeah, I believe it was under 'zoom' actually. ebr, you don't use MPC, what do you use? I didn't even know there was another option.
ebr 16332 Posted November 8, 2013 Posted November 8, 2013 I just installed LAV and stuff plays directly in WMC.
Guest Posted December 16, 2013 Posted December 16, 2013 Hello, I had the same issue. The solution for me was : - Install Daemon tool - Set Daemon tool into MB3C Configuration (with autoplay works for me) - In the external player configuration for MPC-HC, in the list of medias, uncheck "ISO".
