Possible to add "skip to next track" to remote for playlists?
I just started using MB for music videos and it is pretty awesome. I love being able to just go into MBC and it hit play random on that library and let it run. A couple of questions in terms on doing this with the Android client:
  1. Would it be possible to add a button on the remote to skip to the next track? Right now, I just have skip back, pause/play, stop and fast forward (although it performs like a skip forward 30 seconds, not a fast forward). Would it be possible to add this?
  2. Is there a way to accomplish a play all or play random for the entire folder in the Android client? I tried long pressing on the folder but nothing happened.
Thanks!
  • 3 weeks later...
