GaryDZ 2 Posted March 3, 2015 Posted March 3, 2015 I am not sure where it went wrong. I had it up and running for a while. I traveled this weekend and was able to stream recorded TV without a problem. Today, I am unable to access it at all. I rebooted the computer and Server WMC. No Luck. I THINK my ports are wrong---even though I did not change them and they worked 2 days ago. I have attached PICS. ++ Media Browsers Settings shows the following: "Running on Port 8096, and https port 8920 Local access http://192.168.1.23:8096 Remote access http://xx.xxx.xx.xxx:8096 ServerWMC General Tab shows: "Port number for client connection:9080 I CAN access it on my LOCAL network http://app.mediabrowser.tv/index.html I can't access it from remote access: http://xx.xxx.xx.xxx:8096 Any help/advice would be greatly appreciated. I had a hard time setting it up the 1st time--- and never really figured out what I did to make it work. I can upload my log if it is needed. GaryDZ
GaryDZ 2 Posted March 4, 2015 Author Posted March 4, 2015 Should I make sure all of the ports are the same for the server WMC, and the browser remote access? No idea why it just stopped working.
GaryDZ 2 Posted March 4, 2015 Author Posted March 4, 2015 I am not sure where it went wrong. I had it up and running for a while. I traveled this weekend and was able to stream recorded TV without a problem. Worked perfectly. Today, I am unable to access it at all. I rebooted the computer, router and Server WMC. No Luck. I THINK my ports are wrong---even though I did not change them and they worked 2 days ago. Media Browsers Settings shows the following: "Running on Port 8096, and https port 8920 Local access http://192.168.1.23:8096 Remote access http://xx.xxx.xx.xxx:8096 ServerWMC General Tab shows: "Port number for client connection:9080 I CAN access it on my LOCAL network http://app.mediabrowser.tv/index.html I can't access it from remote access: http://xx.xxx.xx.xxx:8096 Any help/advice would be greatly appreciated. I had a hard time setting it up the 1st time--- and never really figured out what I did to make it work. I can upload my log if it is needed. GaryDZ
bigjohn 754 Posted March 4, 2015 Posted March 4, 2015 I edited your post(s) to remove your external IP address, and merged your topics that you posted in multiple forums. You might check to see if the issue is firewall-related. Some users have reported a need to re-create their firewall rules for media browser after a server update.
GaryDZ 2 Posted March 4, 2015 Author Posted March 4, 2015 bigjohn, Thanks... for removing the IP. Should the Ports be the same for the server WMC, and the browser remote access--or keep them different? I will check the firewall when I am home.
bigjohn 754 Posted March 4, 2015 Posted March 4, 2015 Different ports are required, I think. Your problem appears to be accessing Media Browser Server at all from outside your network, not just live tv using the Server WMC plugin.
mediacowboy 438 Posted March 4, 2015 Posted March 4, 2015 Something else to check would be your router. Make sure you are still port forwarding the ports. Make the router crashed or something funky.
ebr 16307 Posted March 4, 2015 Posted March 4, 2015 Or maybe the IP address of either the router (the external address) or the MB server machine changed...
GaryDZ 2 Posted March 5, 2015 Author Posted March 5, 2015 Something else to check would be your router. Make sure you are still port forwarding the ports. Make the router crashed or something funky. I logged into the router.... what should I port forward? Do I list the local IP the Remote IP or both? What about the Server WMc? I have a port---but not the IP. This is the settings in the software. Local access http://192.168.1.23:8096 Remote access http://xx.xxx.xx.xxx:8096 ServerWMC General Tab shows: "Port number for client connection:9080
mediacowboy 438 Posted March 5, 2015 Posted March 5, 2015 You will need to tell it the port you will hit on the outside. 8096 for example and then the internal port as well as the internal ip.
GaryDZ 2 Posted March 5, 2015 Author Posted March 5, 2015 Or maybe the IP address of either the router (the external address) or the MB server machine changed... How would I check this?
mediacowboy 438 Posted March 5, 2015 Posted March 5, 2015 You can use a website like what's my ip or ipchicken
GaryDZ 2 Posted March 5, 2015 Author Posted March 5, 2015 I checked the firewall... There were two MediaCenter Extension listed. One was only Private, the other was Public. I made both Private and Public
GaryDZ 2 Posted March 5, 2015 Author Posted March 5, 2015 You can use a website like what's my ip or ipchicken I ran IPCHICKEN and my IP address is the same as the Remote IP address This is the settings in the software. Local access http://192.168.1.23:8096 Remote access http://xx.xxx.xx.xxx:8096 ServerWMC General Tab shows: "Port number for client connection:9080
GaryDZ 2 Posted March 5, 2015 Author Posted March 5, 2015 What type router do you have? Verizon FiOS Can I private message you?
mediacowboy 438 Posted March 5, 2015 Posted March 5, 2015 Verizon FiOS Can I private message you? Sure
mediacowboy 438 Posted March 5, 2015 Posted March 5, 2015 From your settings, I am not seeing anything wrong. You might try remotely and report back.
