Remote control with reverse Proxy
I have been running into a small issue since I setup my MB3 server to be running behind a reverse proxy, here was my basic configuration :
My MB3 server is hosted on an openvz container with a private IP adress (192.168.1.3).
The 8096 port is nated to the public IP of the server, lets says it is 37.187.1.1
With this configuration, I can acess MB3 without issue with this url :http://37.187.1.1:8096/mediabrowser/dashboard/index.html
I can also remote control the server with any other device, by acessing the same URL and selecting the remote control feature.
However, I wanted to acess Mediabrowser with a more simple URL, like mb3.mydns.info
I configured my nginx reverse proxy so that acessing mb3.mydns.info redirects me to 192.168.1.3:8096.
This works really well, and I am able to acess Mediabrowser without any issues.
The only broken feature is the remote control, indeed I am now unable to see any other instance by acessing the server from the proxyed URL.
Does anyone know if there is a solution for this issue ?
