tp546 41 Posted February 25, 2015 Posted February 25, 2015 i just grouped my TV and movies together, but since they show up separately in metadata manager, I'm not sure how I can adjust the order in which they appear - is there a way to do so?
Luke 42184 Posted February 25, 2015 Posted February 25, 2015 you want to change the order in the metadata manager? no, it just shows the folders
tp546 41 Posted February 25, 2015 Author Posted February 25, 2015 no sorry i don't think i explained correctly - now that my movies are grouped, when i enter MBC or the web client, they are at the end of my list - after things like playlists, video bookmarks channel, etc - how can i move them so they are listed first?
Solution Happy2Play 9799 Posted February 25, 2015 Solution Posted February 25, 2015 Not sure about MBC but are you referring to View Order? My Preferences 1
tp546 41 Posted February 25, 2015 Author Posted February 25, 2015 Not sure about MBC but are you referring to View Order? My Preferences yes - that is it. thanks!
