Cazten 1 Posted November 6, 2013 Posted November 6, 2013 So I don't know if this is something of interest... But considering this is an all inclusive HTPC app what would be really killer is if there was some way to route external audio sources through the Theater interface. ex. If using HTPC as the main connection device Be able to router the stereo in connection through MBT. So if you have a external stereo system. Or even if you have a SPDIF input, be able to route the audio through the MBT app. Idea being that you can use programs for audio filtering or room connection on anything leaving the PC, but at the same time be able to control via remote what audio input is playing. Swap to stereo, or if you have a cable box via spdif, ect. Just a thought
