Airbender 128 Posted February 24, 2015 Posted February 24, 2015 Hello is it possible to get Auto-Organize script for single movies ? box set can be done manually by user but for single movie that should be automated Thanks in advance 1
ginjaninja 605 Posted February 24, 2015 Posted February 24, 2015 Bit more complex i guess The user would have to specify a default location..unlike tv the location is pre -determined The naming scheme would need to be a folder structure and a filename..unlike tv which is just a filename
chef 3811 Posted February 24, 2015 Posted February 24, 2015 I was thinking about adding movie sorting to my auto organize helper program. But it would be standalone, so it is probably not worth pursuing.
Airbender 128 Posted February 25, 2015 Author Posted February 25, 2015 guys, all I am saying is select a folder where movies are then select a folder where single movie will go and let mb3 do its magic. this won't work for boxset but at lest help automate some work. that by it self will reduce 50% of work load thanks Sent from my iPhone using Tapatalk
