Chubby Arse 23 Posted November 6, 2013 Posted November 6, 2013 Hi, I'm hoping that someone here will be able to help me get MPC setup on my HTPC. I have installed; - Haali Splitter (23/06/2013)- ffdshow (tryouts rev 4500_20131006_x64)- MPC - 1.7.0.x64 I have a file that I'm trying to open that reports the following in MediaInfo: General UniqueID/String : 154290161963041079409139273994921567283 (0x7413344D53662BC4DEB0FA7DC4E3E433) CompleteName : \\Temp-Store00\TestFile.mkv Format : Matroska Format_Version : Version 2 FileSize/String : 2.02 GiB Duration/String : 43mn 22s OverallBitRate/String : 6 669 Kbps Movie : Ep1 Encoded_Application : Lavf55.8.102 Encoded_Library/String : Lavf55.8.102 Video ID/String : 1 Format : AVC Format/Info : Advanced Video Codec Format_Profile : High@L4.1 Format_Settings_CABAC/String : Yes Format_Settings_RefFrames/String : 9 frames CodecID : V_MPEG4/ISO/AVC Duration/String : 43mn 22s BitRate/String : 5 027 Kbps Width/String : 1 280 pixels Height/String : 720 pixels DisplayAspectRatio/String : 16:9 FrameRate_Mode/String : Constant FrameRate/String : 23.976 fps ColorSpace : YUV ChromaSubsampling : 4:2:0 BitDepth/String : 8 bits ScanType/String : Progressive Bits-(Pixel*Frame) : 0.227 StreamSize/String : 1.52 GiB (75%) Encoded_Library/String : x264 core 133 r2334 a3ac64b Encoded_Library_Settings : cabac=1 / ref=9 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=4 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Language/String : English Default/String : No Forced/String : No Audio ID/String : 2 Format : DTS Format/Info : Digital Theater Systems Format_Settings_Mode : 16 Format_Settings_Endianness : Big CodecID : A_DTS Duration/String : 43mn 22s BitRate_Mode/String : Constant BitRate/String : 1 509 Kbps Channel(s)/String : 6 channels ChannelPositions : Front: L C R, Side: L R, LFE SamplingRate/String : 48.0 KHz BitDepth/String : 24 bits Compression_Mode/String : Lossy StreamSize/String : 468 MiB (23%) Title : 3/2+1 Language/String : English Default/String : Yes Forced/String : No Text ID/String : 3 Format : PGS CodecID : S_HDMV/PGS CodecID/Info : The same subtitle format used on BDs/HD-DVDs Language/String : English Default/String : No Forced/String : No Menu 00:00:00.000 : :Chapter 01 00:03:10.523 : :Chapter 02 00:09:33.573 : :Chapter 03 00:17:33.635 : :Chapter 04 00:24:41.271 : :Chapter 05 00:30:40.213 : :Chapter 06 00:39:07.470 : :Chapter 07 00:42:34.176 : :Chapter 08 When I try to load it into MPC - I get the following: LAV Splitter Source (internal)::Audio LAV Audio Decoder (internal)::Output Audio Switcher::Out Media Type 0: -------------------------- Audio: IEEE Float 48000Hz 6ch 9216kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_IEEE_FLOAT {00000003-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 24 cbFormat: 40 WAVEFORMATEX: wFormatTag: 0xfffe nChannels: 6 nSamplesPerSec: 48000 nAvgBytesPerSec: 1152000 nBlockAlign: 24 wBitsPerSample: 32 cbSize: 22 (extra bytes) WAVEFORMATEXTENSIBLE: wValidBitsPerSample: 32 dwChannelMask: 0x0000003f SubFormat: {00000003-0000-0010-8000-00AA00389B71} pbFormat: 0000: fe ff 06 00 80 bb 00 00 00 94 11 00 18 00 20 00 þÿ..€»...”.... . 0010: 16 00 20 00 3f 00 00 00 03 00 00 00 00 00 10 00 .. .?........... 0020: 80 00 00 aa 00 38 9b 71 €..ª.8›q Media Type 1: -------------------------- Audio: PCM 48000Hz 6ch 4608kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_PCM {00000001-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 12 cbFormat: 40 WAVEFORMATEX: wFormatTag: 0xfffe nChannels: 6 nSamplesPerSec: 48000 nAvgBytesPerSec: 576000 nBlockAlign: 12 wBitsPerSample: 16 cbSize: 22 (extra bytes) WAVEFORMATEXTENSIBLE: wValidBitsPerSample: 16 dwChannelMask: 0x0000003f SubFormat: {00000001-0000-0010-8000-00AA00389B71} pbFormat: 0000: fe ff 06 00 80 bb 00 00 00 ca 08 00 0c 00 10 00 þÿ..€»...Ê...... 0010: 16 00 10 00 3f 00 00 00 01 00 00 00 00 00 10 00 ....?........... 0020: 80 00 00 aa 00 38 9b 71 €..ª.8›q I'm consulted the following http://codecguide.com/faq_mpc.htm and followed the advice for the ARM issue, but no change?? Would anyone be able to help me out here - I just don't understand the interoperation of ffdshow MPc / codecs etc. It's all so complicated and I've never found anything to explain - you either know it or you don't. Thanks Alex
CBers 7554 Posted November 6, 2013 Posted November 6, 2013 (edited) @ - have a read of this: http://mediabrowser.tv/community/index.php?/topic/1096-setting-up-codecs-using-ffdshow/?fromsearch=1 And/or this: http://mediabrowser.tv/community/index.php?/topic/726-windows-media-center-internal-player-mb-classic-and-lav-filters-guide/?fromsearch=1 Edited November 6, 2013 by CBers 2
Chubby Arse 23 Posted November 7, 2013 Author Posted November 7, 2013 Thanks very much for the link Cbers / Jack. I've been able to get MPC to play the files! Slight difference though that instead of installing the filters manually, I ran the MPC installer as I may use MPC as my player (if I can ever get the remote commands to work). Anyway, I'm unable to get WMC to be able to play the file I described in the original post (although MPC plays it happily). I've installed the ffdShow x64 and MPC x64 installers and configured ffdShow as per your guide. However, the tweaker dialogs looks a bit different, I that I don't have any ffdShow filters for 32-bit? Should I install ffdshow 32 bit as well as x64? Here's a snap shot of the codec dialog - you'll notice also that I have nothing on 64 bit for mpg? So I you don't mind, my questions: Why have I got no 32-bit filters and only Microsoft options? Does WMC run in 32-bir mode? Which filters should I get installed for playing mpeg files? Thanks for your help - much appreciated. Alex
gillmacca 17 Posted November 7, 2013 Posted November 7, 2013 I found shark007 codecs played all my video formats fine via WMC. You might want to look at that
CBers 7554 Posted November 7, 2013 Posted November 7, 2013 Strange. Did you just install ffdshow ? I only have 32bit OS on my HTPCs. If you have 64bit OS, you'll need 32bit & 64bit filters installing. 1
Chubby Arse 23 Posted November 11, 2013 Author Posted November 11, 2013 I found shark007 codecs played all my video formats fine via WMC. You might want to look at that Thanks for the advice, but Shark Codecs (without going into it) broke my machine and led me to believe that a more meticulous approach to codecs was preferable. Strange. Did you just install ffdshow ? I only have 32bit OS on my HTPCs. If you have 64bit OS, you'll need 32bit & 64bit filters installing. Thanks again for the response CBers. I've installed ffdShow for 32 bit and the Tweaker software now allows me to pick ffdShow for the 32-bit filter section. I do however have a couple more questions though that I'd be grateful for some help with: I can't media centre to playback mkv natively - MPC works fine though. In fact it looks like all except wtv isn't going through MC. I set the Media Foundation setting like yours, but didn't get any audio out of wtv files until I re-enable the foundation to process it. Any ideas why nothing else is picking up the audio for output? If you have a look at the screen shot I put up earlier I've not got any decoders (other than an MS one) for mpeg. Can you advise on how I can get mpeg support other than through MS codecs (I thought that the ffdshow wold cover that off). Cheers.
