walterdavid 0 Posted February 22, 2015 Posted February 22, 2015 Hello, i've been using MBC for years with nothing to complain at all.I've formatted my hd recently and installed Windows 8.1 WMC. After installing MB server properly like i always did, and never got any problems with it, i'm having this issue with MBC and i don't know what to do. It simply doesnt open. This message is what shows: I'm sure i'm on the latest version of MBS and MBC, as i downloaded them yesterday from the official MB website. MBC 3.0.254MBS 3.0.5518.7 The log generated by MBC is the same whenever i try to open it. The txt file is attached.The log generated by Media Center is also attached. There are no errors apparently. Any help is appreciated. MBClassic-222201592a2d74a18ec4b5f846e93fd25a1b059.log media center log.txt
Solution ebr 16334 Posted February 22, 2015 Solution Posted February 22, 2015 Install the Release version of MBC and bring it up. Then update to the new beta. This is a bug in the new beta for first time installs. I'll have it fixed in the next beta but the above will get you going right away. 1
walterdavid 0 Posted February 22, 2015 Author Posted February 22, 2015 hahaha i can't believe something this ordinary and i haven't thought of ittnx a lot man
ebr 16334 Posted February 22, 2015 Posted February 22, 2015 Well, I don't know how ordinary it was. There was definitely a bug in the beta. I've just put up a new Beta though so future folks shouldn't have this issue.
mariors44 18 Posted February 22, 2015 Posted February 22, 2015 ebr, when you try to download release version it downloads the latest beta version instead.
ebr 16334 Posted February 22, 2015 Posted February 22, 2015 ebr, when you try to download release version it downloads the latest beta version instead. I just now did it and got 243...
