Alpheratz13 0 Posted February 22, 2015 Posted February 22, 2015 Hi, I have Windows 8.1 Pro I have probleme with Media Browser Classic, after installed this software and open it, WMC go open and fews seconds later i see this message error. What can i do or what do i wrong. ? Even Media Browser Classic Configurator is empty. Media Browser Server is installed on my server. With Media Browser Theater works fine. Thank you for your help Irving
ebr 16334 Posted February 22, 2015 Posted February 22, 2015 Please post the log. Thx. How to Report a Problem
ebr 16334 Posted February 22, 2015 Posted February 22, 2015 Never mind. I think you can fix this by first installing the Release version of MBC, and then upgrading it to the Beta.
Alpheratz13 0 Posted February 22, 2015 Author Posted February 22, 2015 Hi, Thank you for your help. ok, i install the beta version right now. I let you know if it's work or not. Thank you
ebr 16334 Posted February 22, 2015 Posted February 22, 2015 No, you need to install the Release version first...
Alpheratz13 0 Posted February 27, 2015 Author Posted February 27, 2015 Hi ebr, Sorry for late reply. I have clean install of Windows. And it's works great now, i have installed only Release version. Thank you for your help. Irving PS I installed Media Browse Server on my server Ve-hotech. VM on Windows 7
ebr 16334 Posted February 27, 2015 Posted February 27, 2015 Okay, the beta version should be fine now too as I fixed this issue.
