timstephens24 1 Posted February 21, 2015 Posted February 21, 2015 I'm trying to try out MediaBrowser, but it won't finish going through the Wizard. 1. Preferred display language: English - Click Next (works) 2. Your first name: timstephens24 - Click Next (works) --- Doesn't work if I try to link my MediaBrowser account 3. Add Media Folder - Click Next (works) 4. Download artwork - Click Next (Doesn't work) At that point I get a little message that says "Could not resolve 'xxx.local' where xxx is my computer's hostname. I'm using a Retina iMac and OS X 10.10.3 w/ OS X Server installed.
2hansen 0 Posted February 21, 2015 Posted February 21, 2015 I have the same. If I add information in the "Media Browser username/email:"-field I get a 400 issuing "Argument cannot be null. Parameter name: ConnectServerId". I am on a Mac Pro running 10.10.2
sambusby 0 Posted April 13, 2015 Posted April 13, 2015 Also having the same exact issue running OS X 10.10.2
grimsage 5 Posted April 16, 2015 Posted April 16, 2015 (edited) a hacky way to solve this is to edit your /etc/hosts file and add XXX.local to the lines that say 127.0.0.1 and ::1 so if you open up the terminal (use either spotlight or under utilities) you can possibly use this tutorial: http://www.makeuseof.com/tag/how-to-edit-the-mac-os-x-hosts-file-and-why-you-might-want-to/ or follow my instructions if you are a bit more familiar. then at the prompt (I thin it starts with a $) (I have changed mine) type the following: sudo vim /etc/hosts it will ask you for a password, the password will not show up as you type. after hitting enter after your password you should see something that looks like the following: ## # Host Database # # localhost is used to configure the loopback interface # when the system is booting. Do not change this entry. ## 127.0.0.1 localhost OtherMini OtherMini.local 255.255.255.255 broadcasthost ::1 localhost OtherMini OtherMini.local Edited April 30, 2015 by grimsage
Guest CubexDE Posted April 26, 2015 Posted April 26, 2015 (edited) This sounds like a good solution except I have no idea what XXX is. EDIT: Also I can't figure out how to give myself access to edit the file. Mine is the only account on the computer and therefore I have admin access. Edited April 26, 2015 by CubexDE
grimsage 5 Posted April 27, 2015 Posted April 27, 2015 in terminal type hostname that will give you the XXX part of XXX.local the sudo (super user do) command should be all you need to give yourself access to the file, if it is not working there might be something else with your machine
ironpepsi 1 Posted May 8, 2015 Posted May 8, 2015 I am using Freenas' plugin to host and I am having the same issue as listed above. I attempted to solve using the method listed but i am still getting the error and it won't allow me to link my account.
Luke 42237 Posted May 8, 2015 Posted May 8, 2015 I am using Freenas' plugin to host and I am having the same issue as listed above. I attempted to solve using the method listed but i am still getting the error and it won't allow me to link my account. It's best to provide a server log because up until this point this discussion has all been specific to OSX. So it may or may not be the same thing.
abney01 0 Posted May 14, 2015 Posted May 14, 2015 In Terminal done what you said and it does not work. Can you please say again what to do?
