TV Issues (Recorded Works, Live Doesnt)
Hey Gang,
Windows 7 x64
MB Version 3.0.5518.5
ServerWMC : 1.0.0.52, Build 1175
SiliconDust HDHomeRun Prime (Verizon FIOS CableCard)
Okay, this one has me pretty plexed. If I schedule a show, it will record, and work just fine. I can watch it, in any MB Client (Web / Kodi / MBC / MBT / Android / Ipad)
When I pull up Live TV, I ca see the guide, the show info, etc. When I hit play, it just sits there and looks at me as I am stupid (which I might be. :rolleyes:)
If I open my WMC, live tv works just fine.... and as I said, I can record, schedule recordings, and those work fine. (I tried HD/SD)  When I pull up the logs, I get TONS of these :
2015/02/19 23:28:45.100 Received client request: MediaBrowser^@AKANE@|::1|GetTimers
2015/02/19 23:28:45.115 Finished request GetTimers in 0.02s
2015/02/19 23:28:45.677 Received client request: MediaBrowser^@AKANE@|::1|GetTimers
2015/02/19 23:28:45.677 Finished request GetTimers in 0.00s
2015/02/19 23:29:05.863 Received client request: MediaBrowser^@AKANE@|::1|GetTimers
2015/02/19 23:29:05.863 Finished request GetTimers in 0.00s
2015/02/19 23:29:08.859 Received client request: MediaBrowser^@AKANE@|::1|GetTimers
2015/02/19 23:29:08.874 Finished request GetTimers in 0.02s
2015/02/19 23:29:12.587 Received client request: MediaBrowser^@AKANE@|::1|GetTimers
2015/02/19 23:29:12.587 Finished request GetTimers in 0.00s
(Yes, Akane is the name of my MB Server)
Here are the full Logs :
http://pastebin.com/BdZM15s8 <--- Ful Pastebin Logs
The Worst thing, I had it working fine 2 weeks ago, and my OS drive crashed, so I did a fresh install today, and this is where I am stuck.
Thanks for any help!
After some poking and playing (Reinstalling ServerWMC, and removing and re-adding the plugin to MB), I can get it to work on my Android client, but not the web, nor the MBT client.
Same here...
Windows 7 x64
ServerWMC : 1.0.0.52, build: 1175
Ceton InfiniTV PCIe (4 tuners, Xfinity Cable Card)
Live TV will not work, either on the MBS, on web client from several different PCs and browsers, as well as Roku3 but it will on WMCAndroid MB and Kodi Live TV . I have the Recorded TV directory shared with Everyone, full share permissions and Full Control security. Everything appears to be set up correctly in the ServerWMC settings and the plugin settings, ServerWMC Status shows all 4 tuners as available, Guide is working, and I can play recorded TV, ServerWMC plugin IP is set to 127.0.0.1 but I have also tried the server's IP which is 192.168.0.101. I have also tried with DLNA enabled and disabled. I'm at a loss...
On another note, I couldn't be happier with all the great work done by all the devs and just love MediaBrowser 3. Keep it up and thanks!
Server-ServerWMC-transcode logs.zip
Edited by jhevener
Update:
Roku client works on Roku 3, just really slow to buffer at the start.
Only noticed one lag shortly after stream start and now, Roku 3 is rolling on HD TV.  :)
. . . too many years spent waiting for this, that, and the other thing. :wacko:
Edited by jhevener
@@TedA, thanks for chipping in and helping with the upcoming fix!
Edited by jhevener
Hmm if there is a @@Teddy on the forum I wonder if I should change my display name =]
Nah, sorry mate, @ it is... Forgive me, I live near Hyannisport... :)
Thanks just the same ;)
Edited by jhevener
jhevener
For those of you scratching your head about that last one, Hyannisport is where Teddy Kennedy lived (among gobs of other Kennedys).
  • Like 1
