Arch Linux on Rpi2 with MBS
marlin9800
Got bored so I ran it again.
Time Elapsed 00:02:55.3529160
==> Tidying install...
  -> Purging unwanted files...
  -> Removing libtool files...
  -> Removing static library files...
  -> Compressing man and info pages...
  -> Stripping unneeded symbols from binaries and libraries...
==> Creating package "mediabrowser-server"...
  -> Generating .PKGINFO file...
  -> Adding install file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: mediabrowser-server 3.0.5518.7-1 (Sat May  9 15:10:08 UTC 2015)
[root@alarmpi mediabrowser-server]# systemctl enable mediabrowser-server.service
Failed to execute operation: No such file or directory
Same error.
Edited by marlin9800
marlin9800
Son-of-a-bitch.... I feel stupid.
Decided to look at the options for makepkg, and see a -i for Install package after successful build... no shit. She's running!
Thank you for your help DaBungalow and for this post AlwinHummel.
  • 3 weeks later...
thefirstofthe300
As long as you build the package using the instructions either on this site or on the Arch wiki, the package will only update the binaries and the configuration and data will be left alone.
thefirstofthe300
You might want to post in the android forum with version of the app are you running and the things that you have done.
