brossow 1 Posted February 18, 2015 Posted February 18, 2015 Running version 3.0.5518.3 and whenever I go into the web interface I get the following error in the middle of the screen: "Could not resolve host 'MacPro'." It goes away after a couple seconds until I go to another screen. Aside from being an irritant that appears every time I click to a new screen in the web interface, it doesn't seem to affect actual function. 'MacPro' is my local hostname and I can access the web interface just fine using whatever address I like -- MacPro.local, 127.0.0.1, localhost, the IP address, etc. If I use 'scutil' at the CLI to check the various flavors of the computer/host name, they all return MacPro: XXXXXX$ sudo scutil --get ComputerName MacPro XXXXXX$ sudo scutil --get LocalHostName MacPro XXXXXX$ sudo scutil --get HostName MacPro A sample entry from the log is below. Any thoughts? 2015-02-18 16:36:28.6268 Error - Connect: Error registering with Connect *** Error Report *** Version: 3.0.5518.3 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 14.1.0.0 Processor count: 12 64-Bit OS: False 64-Bit Process: False Program data path: /Users/XXXXXXX/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe Could not resolve host 'MacPro' System.Net.Sockets.SocketException at System.Net.Dns.Error_11001 (System.String hostName) [0x00000] in <filename unknown>:0 at System.Net.Dns.hostent_to_IPHostEntry (System.String originalHostName, System.String h_name, System.String[] h_aliases, System.String[] h_addrlist) [0x00000] in <filename unknown>:0 at System.Net.Dns.GetHostByName (System.String hostName) [0x00000] in <filename unknown>:0 at System.Net.Dns.GetHostEntry (System.String hostNameOrAddress) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Networking.BaseNetworkManager.GetLocalIpAddressesFallback () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Networking.BaseNetworkManager.GetLocalIpAddressesInternal () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Networking.BaseNetworkManager.GetLocalIpAddresses () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Mac.NetworkManager.MediaBrowser.Common.Net.INetworkManager.GetLocalIpAddresses () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost.get_HttpServerIpAddresses () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost.get_LocalIpAddress () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost.get_LocalApiUrl () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Connect.ConnectManager+<UpdateConnectInfoInternal>c__async1.MoveNext () [0x00000] in <filename unknown>:0
Luke 42237 Posted February 19, 2015 Posted February 19, 2015 this will be resolved when the current beta goes stable.
