BrettDioson 4 Posted June 12, 2016 Posted June 12, 2016 can you elaborate a little bit more by spelling out the sequence of screens that you see? thanks. 1) start URLLoader 2) go to tv.emby.media url 3) "Please Sign In" scream appears and shows accounts. 4) select an account that is password protected and hit OK 5) nothing happens. No prompt for password comes up 6) select an account that is NOT password protected and hit OK 7) Emby main menu comes up starting in TV shows.
BrettDioson 4 Posted June 12, 2016 Posted June 12, 2016 Thanks, I know what the playback issue is. Should hopefully have it fixed by tomorrow. For now can you concentrate on some of the other basics, like for example, are you generally able to browse around without any issues. stuff like that. thanks! Actually browsing around is pretty fluid. Some menu and text alignment issues (will need to take pictures and post) but I can get around without issues and browse movies and shows.
Luke 42243 Posted June 17, 2016 Posted June 17, 2016 Please try again and let me know your results, thanks.
BrettDioson 4 Posted June 18, 2016 Posted June 18, 2016 (edited) Sorry for dropping off, had something come up. Tried again today (6/18/2016@8:44am ET). Was able to login with registered account now that has password. Password dialogue box now comes up when you select user and can get to menu. Am able to browse menu and go to different areas (TV, Movies, Collections, etc.) When I select a show to play, the background picture for the media still comes to the foreground and blocks everything. Also the media does not play (or at least I assume it does not play as I hear no sound and only see the background image). When I press stop or back, I would assume it would go back to the menu, but the background image obscures everything. EDIT: sorry, should have added... Also tested manual login and that works too. Dialogue box for username/password comes up and am able to successfully login. Edited June 18, 2016 by BrettDioson
BrettDioson 4 Posted June 18, 2016 Posted June 18, 2016 Bad news for TiVo owners... There is no URLLoader in the OperaTV store. At least not on the Romio. Will need to hope TiVo updates their App Store interface I guess.
Luke 42243 Posted June 18, 2016 Posted June 18, 2016 Sorry for dropping off, had something come up. Tried again today (6/18/2016@8:44am ET). Was able to login with registered account now that has password. Password dialogue box now comes up when you select user and can get to menu. Am able to browse menu and go to different areas (TV, Movies, Collections, etc.) When I select a show to play, the background picture for the media still comes to the foreground and blocks everything. Also the media does not play (or at least I assume it does not play as I hear no sound and only see the background image). When I press stop or back, I would assume it would go back to the menu, but the background image obscures everything. EDIT: sorry, should have added... Also tested manual login and that works too. Dialogue box for username/password comes up and am able to successfully login. Does the server create a transcoding log when this happens?
1ntroduc3 4 Posted June 19, 2016 Posted June 19, 2016 I'm having the same issue. Login works, but playing a video file doesn't. Here's my log (no transcoding log, still there's something about Fast 5 (that I'm trying to play from the TV): The log is a lot larger, pm me if you want the full log. *** Error Report *** Version: 3.1.29.0 Command line: C:\Users\Media\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Media\AppData\Roaming\Emby-Server Application Path: C:\Users\Media\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe ImageMagickSharp.WandException at ImageMagickSharp.WandCore`1.CheckError(Boolean status) at Emby.Drawing.ImageMagick.ImageMagickEncoder.EncodeImage(String inputPath, String outputPath, Boolean autoOrient, Int32 width, Int32 height, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) at Emby.Drawing.ImageProcessor.<ProcessImage>d__7.MoveNext() 2016-06-19 13:45:12.7546 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 1045ms (slow). http://77.160.132.22:8096/emby/Items/1f28f7680761ea230be23216936f7e62/Images/Primary?maxWidth=243&tag=e3c6dc6be297f9d2b168b7f420a19880&quality=80 2016-06-19 13:45:13.2694 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:13.4098 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 140ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c 2016-06-19 13:45:14.0806 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Logo?tag=02111341b4949f4549292462ad621c22&quality=90. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:14.1430 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 62ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Logo?tag=02111341b4949f4549292462ad621c22&quality=90 2016-06-19 13:45:14.6110 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 6bd67f7892b14af7ac7f03ca8797ed38 2016-06-19 13:45:14.6110 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/7b352bea3f1667132336b8ee65b79074. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:14.6266 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 16ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/7b352bea3f1667132336b8ee65b79074 2016-06-19 13:45:14.6266 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/7b352bea3f1667132336b8ee65b79074. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:14.6578 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 31ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/7b352bea3f1667132336b8ee65b79074 2016-06-19 13:45:15.3286 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/7b352bea3f1667132336b8ee65b79074/Images/Logo?tag=39f5fdbe6f3495ca0190c003553be04b&quality=90. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:15.3754 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 47ms. http://77.160.132.22:8096/emby/Items/7b352bea3f1667132336b8ee65b79074/Images/Logo?tag=39f5fdbe6f3495ca0190c003553be04b&quality=90 2016-06-19 13:45:15.5470 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:15.5470 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 921f99d2d7b140218afbef44f4c11151 2016-06-19 13:45:15.5470 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:15.5470 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039 2016-06-19 13:45:15.5938 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 47ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c 2016-06-19 13:45:15.7186 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:15.7186 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039 2016-06-19 13:45:15.9838 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: c65b22836a2f4307a014be6ebc87589b 2016-06-19 13:45:15.9994 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/ThemeMedia?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&InheritFromParent=true. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:15.9994 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/ThemeMedia?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&InheritFromParent=true 2016-06-19 13:45:15.9994 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/ThemeMedia?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&InheritFromParent=true. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:16.0150 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 16ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/ThemeMedia?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&InheritFromParent=true 2016-06-19 13:45:16.0306 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:16.0462 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop/0?tag=a07ea99bdd47ade3989587ff3ce21c09&maxWidth=1920&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:16.0774 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 47ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c 2016-06-19 13:45:16.1398 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Primary?width=800&tag=12377e761531d18892194ecb4376ad11&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:16.2802 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 140ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Primary?width=800&tag=12377e761531d18892194ecb4376ad11&quality=80 2016-06-19 13:45:16.3738 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 328ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop/0?tag=a07ea99bdd47ade3989587ff3ce21c09&maxWidth=1920&quality=80 2016-06-19 13:45:16.5766 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 7be555bee4bb4173ba5338e3d3a59041 2016-06-19 13:45:17.1070 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Similar?Limit=12&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=a8ceeacad4ea4bceb9f8381a2d8cd039. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:17.1070 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Similar?Limit=12&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=a8ceeacad4ea4bceb9f8381a2d8cd039 2016-06-19 13:45:17.5438 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Similar?Limit=12&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=a8ceeacad4ea4bceb9f8381a2d8cd039. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:17.5906 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 47ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Similar?Limit=12&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=a8ceeacad4ea4bceb9f8381a2d8cd039 2016-06-19 13:45:17.9650 Debug NetworkManager: Querying interface: Local Area Connection 2. Type: Ethernet. Status: Up 2016-06-19 13:45:17.9650 Debug NetworkManager: Querying interface: Local Area Connection. Type: Ethernet. Status: Up 2016-06-19 13:45:17.9650 Debug NetworkManager: Querying interface: Loopback Pseudo-Interface 1. Type: Loopback. Status: Up 2016-06-19 13:45:17.9650 Debug NetworkManager: Querying interface: isatap.{67542B3B-6993-462D-B380-01B4C497F6A1}. Type: Tunnel. Status: Down 2016-06-19 13:45:17.9650 Debug NetworkManager: Querying interface: isatap.{74924866-E352-4169-8B81-9DB30CD52F81}. Type: Tunnel. Status: Down 2016-06-19 13:45:19.4314 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/a3ae1cfe154a52f1a50640cece266651/Images/Primary?maxWidth=260&tag=2f4e4b76196c13ad10bda521c04ddf76&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.4470 Debug App: ConvertImageToLocal item a3ae1cfe-154a-52f1-a506-40cece266651 - image url: https://www.thetvdb.com/banners/actors/349010.jpg 2016-06-19 13:45:19.4470 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/349010.jpg 2016-06-19 13:45:19.4782 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/983dafbba733dfe1c712aa175ee352ea/Images/Primary?maxWidth=260&tag=cc25ca3a9e85b722d3da305f30827aea&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.4782 Debug App: ConvertImageToLocal item 983dafbb-a733-dfe1-c712-aa175ee352ea - image url: https://www.thetvdb.com/banners/actors/40742.jpg 2016-06-19 13:45:19.4782 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/9fb2c4143cc24c11dd402382cefe54af/Images/Primary?maxWidth=260&tag=a7132a5dacb2104608bd95042238f2ed&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.4782 Debug App: ConvertImageToLocal item 9fb2c414-3cc2-4c11-dd40-2382cefe54af - image url: https://www.thetvdb.com/banners/actors/383491.jpg 2016-06-19 13:45:19.4782 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/c03b59488014397626c63ac0e46a7816/Images/Primary?maxHeight=510&maxWidth=340&tag=a1b87d87546c067b26af48be38d6732c&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.5094 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:19.5406 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:19.5406 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 31ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:45:19.5406 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: fb1bf692205a4837b41c66dd8601c2d4 2016-06-19 13:45:19.5406 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:19.5406 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:45:19.5406 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: af0d700cf77441aa87d1eb2441019023 2016-06-19 13:45:19.5562 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:19.5562 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:45:19.5562 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: f373e01e76c442c08d3766985bb6c4fb 2016-06-19 13:45:19.5718 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:19.6030 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 125ms. http://77.160.132.22:8096/emby/Items/c03b59488014397626c63ac0e46a7816/Images/Primary?maxHeight=510&maxWidth=340&tag=a1b87d87546c067b26af48be38d6732c&quality=80 2016-06-19 13:45:19.6030 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/4401be6bfef561d292fa382fce33f42f/Images/Primary?maxHeight=510&maxWidth=340&tag=248279e8ff0d7d4186f931ac771a4692&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.6810 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 78ms. http://77.160.132.22:8096/emby/Items/4401be6bfef561d292fa382fce33f42f/Images/Primary?maxHeight=510&maxWidth=340&tag=248279e8ff0d7d4186f931ac771a4692&quality=80 2016-06-19 13:45:19.7122 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/c3ed470fa2172b466ea7acd221f1bcc8/Images/Primary?maxHeight=510&maxWidth=340&tag=c7ca5ae5a6666a85549d37c81d479e98&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.7902 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:19.7902 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:45:19.7902 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:19.7902 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 20119c6608974169a3958d3e3ea72c83 2016-06-19 13:45:19.7902 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:19.8214 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 109ms. http://77.160.132.22:8096/emby/Items/c3ed470fa2172b466ea7acd221f1bcc8/Images/Primary?maxHeight=510&maxWidth=340&tag=c7ca5ae5a6666a85549d37c81d479e98&quality=80 2016-06-19 13:45:19.8370 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/d2e866d855e3a5430f8241973d506ed0/Images/Primary?maxHeight=510&maxWidth=340&tag=7e09e5ba5bc099b48ab84596da60d668&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:19.8838 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/40742.jpg 2016-06-19 13:45:19.8994 Debug ProviderManager: Saving image to C:\Users\Media\AppData\Roaming\Emby-Server\metadata\People\A\Alimi Ballard\poster.jpg 2016-06-19 13:45:19.8994 Debug App: Saving C:\Users\Media\AppData\Roaming\Emby-Server\metadata\People\A\Alimi Ballard to database. 2016-06-19 13:45:19.8994 Debug ProviderManager: Saving D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).avi to Nfo. 2016-06-19 13:45:19.9462 Debug LibraryMonitor: Changed detected of type Changed to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:19.9462 Debug LibraryMonitor: Ignoring change to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:19.9462 Debug LibraryMonitor: Changed detected of type Changed to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:19.9462 Debug LibraryMonitor: Ignoring change to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:19.9462 Debug ProviderManager: Saving E:\Complete\Series\The Catch to Nfo. 2016-06-19 13:45:19.9774 Debug LibraryMonitor: Changed detected of type Changed to E:\Complete\Series\The Catch\tvshow.nfo 2016-06-19 13:45:19.9774 Debug LibraryMonitor: Ignoring change to E:\Complete\Series\The Catch\tvshow.nfo 2016-06-19 13:45:19.9774 Debug LibraryMonitor: Changed detected of type Changed to E:\Complete\Series\The Catch\tvshow.nfo 2016-06-19 13:45:19.9774 Debug LibraryMonitor: Ignoring change to E:\Complete\Series\The Catch\tvshow.nfo 2016-06-19 13:45:19.9774 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 140ms. http://77.160.132.22:8096/emby/Items/d2e866d855e3a5430f8241973d506ed0/Images/Primary?maxHeight=510&maxWidth=340&tag=7e09e5ba5bc099b48ab84596da60d668&quality=80 2016-06-19 13:45:19.9930 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 562ms. http://77.160.132.22:8096/emby/Items/a3ae1cfe154a52f1a50640cece266651/Images/Primary?maxWidth=260&tag=2f4e4b76196c13ad10bda521c04ddf76&quality=80 2016-06-19 13:45:19.9930 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/63789c3c2fa70f52db30df29577d074a/Images/Primary?maxHeight=510&maxWidth=340&tag=8b7e1d18ff4779a12a6915714e4c758a&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:20.0086 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/b32da1ecef2f8419236e42839c6b107e/Images/Primary?maxHeight=510&maxWidth=340&tag=0e5b1d51362176b88eee2c6075a1cd12&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:20.0086 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:20.0086 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:45:20.0086 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:20.0086 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: edaea6023591431f95cb94865e052319 2016-06-19 13:45:20.0086 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:20.0554 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 62ms. http://77.160.132.22:8096/emby/Items/63789c3c2fa70f52db30df29577d074a/Images/Primary?maxHeight=510&maxWidth=340&tag=8b7e1d18ff4779a12a6915714e4c758a&quality=80 2016-06-19 13:45:20.1646 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 156ms. http://77.160.132.22:8096/emby/Items/b32da1ecef2f8419236e42839c6b107e/Images/Primary?maxHeight=510&maxWidth=340&tag=0e5b1d51362176b88eee2c6075a1cd12&quality=80 2016-06-19 13:45:20.1958 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 3c7f644c28c1455582943dd62fbf2681 2016-06-19 13:45:20.2270 Debug PortMapper: Calling Nat.Handle on uuid:30809696-405a-3721-e8b8-ec8a4c9e1c4e::urn:dslforum-org:service:WANPPPConnection:1 2016-06-19 13:45:20.2426 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:20.2426 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:45:20.2426 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:45:20.2426 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 349126481ae74e8283b02ae7c1ad4b3d 2016-06-19 13:45:20.2582 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:20.2894 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:20.2894 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 31ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:45:20.2894 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 3782addb69584118bc73db5d94ecf10c 2016-06-19 13:45:20.2894 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:20.2894 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:45:20.2894 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 44c4789acef84faebfe8965159b5f94f 2016-06-19 13:45:20.3050 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:20.3050 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:45:20.3050 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 214448900f194e1dbe7a7da9fe8a3221 2016-06-19 13:45:20.3050 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:20.5390 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:20.5390 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:45:20.5390 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:20.5390 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 65ce303f93db426aa9a1e5a9d58f9094 2016-06-19 13:45:20.5390 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:20.5858 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/383491.jpg 2016-06-19 13:45:20.5858 Debug ProviderManager: Saving image to C:\Users\Media\AppData\Roaming\Emby-Server\metadata\People\M\Michael Irby\poster.jpg 2016-06-19 13:45:20.5858 Debug App: Saving C:\Users\Media\AppData\Roaming\Emby-Server\metadata\People\M\Michael Irby to database. 2016-06-19 13:45:20.5858 Debug ProviderManager: Saving E:\Complete\Series\The Unit to Nfo. 2016-06-19 13:45:20.6014 Debug ProviderManager: Saving image to C:\Users\Media\AppData\Roaming\Emby-Server\metadata\People\F\Fernando Chien\poster.jpg 2016-06-19 13:45:20.6014 Debug App: Saving C:\Users\Media\AppData\Roaming\Emby-Server\metadata\People\F\Fernando Chien to database. 2016-06-19 13:45:20.6014 Debug ProviderManager: Saving D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).avi to Nfo. 2016-06-19 13:45:20.6170 Debug LibraryMonitor: Changed detected of type Changed to E:\Complete\Series\The Unit\tvshow.nfo 2016-06-19 13:45:20.6170 Debug LibraryMonitor: Ignoring change to E:\Complete\Series\The Unit\tvshow.nfo 2016-06-19 13:45:20.6170 Debug ProviderManager: Saving D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).avi to Nfo. 2016-06-19 13:45:20.6170 Debug LibraryMonitor: Changed detected of type Changed to E:\Complete\Series\The Unit\tvshow.nfo 2016-06-19 13:45:20.6170 Debug LibraryMonitor: Ignoring change to E:\Complete\Series\The Unit\tvshow.nfo 2016-06-19 13:45:20.6482 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 1170ms (slow). http://77.160.132.22:8096/emby/Items/983dafbba733dfe1c712aa175ee352ea/Images/Primary?maxWidth=260&tag=cc25ca3a9e85b722d3da305f30827aea&quality=80 2016-06-19 13:45:20.6482 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/d2e866d855e3a5430f8241973d506ed0/Images/Primary?maxHeight=510&maxWidth=340&tag=7e09e5ba5bc099b48ab84596da60d668&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:20.6482 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Items/d2e866d855e3a5430f8241973d506ed0/Images/Primary?maxHeight=510&maxWidth=340&tag=7e09e5ba5bc099b48ab84596da60d668&quality=80 2016-06-19 13:45:20.6638 Debug LibraryMonitor: Changed detected of type Changed to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.6638 Debug LibraryMonitor: Ignoring change to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.6638 Debug LibraryMonitor: Changed detected of type Changed to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.6638 Debug ProviderManager: Saving E:\Complete\Series\The Last Ship to Nfo. 2016-06-19 13:45:20.6638 Debug LibraryMonitor: Ignoring change to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.6794 Debug LibraryMonitor: Changed detected of type Changed to E:\Complete\Series\The Last Ship\tvshow.nfo 2016-06-19 13:45:20.6794 Debug LibraryMonitor: Ignoring change to E:\Complete\Series\The Last Ship\tvshow.nfo 2016-06-19 13:45:20.6794 Debug LibraryMonitor: Changed detected of type Changed to E:\Complete\Series\The Last Ship\tvshow.nfo 2016-06-19 13:45:20.6794 Debug LibraryMonitor: Ignoring change to E:\Complete\Series\The Last Ship\tvshow.nfo 2016-06-19 13:45:20.6950 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 1217ms (slow). http://77.160.132.22:8096/emby/Items/9fb2c4143cc24c11dd402382cefe54af/Images/Primary?maxWidth=260&tag=a7132a5dacb2104608bd95042238f2ed&quality=80 2016-06-19 13:45:20.6950 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/b32da1ecef2f8419236e42839c6b107e/Images/Primary?maxHeight=510&maxWidth=340&tag=0e5b1d51362176b88eee2c6075a1cd12&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:20.6950 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Items/b32da1ecef2f8419236e42839c6b107e/Images/Primary?maxHeight=510&maxWidth=340&tag=0e5b1d51362176b88eee2c6075a1cd12&quality=80 2016-06-19 13:45:20.7106 Debug LibraryMonitor: Changed detected of type Changed to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.7106 Debug LibraryMonitor: Ignoring change to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.7106 Debug LibraryMonitor: Changed detected of type Changed to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.7106 Debug LibraryMonitor: Ignoring change to D:\Complete\Movies\Fast Five (2011)\Fast Five(2011).nfo 2016-06-19 13:45:20.7730 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:20.7730 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:45:20.7730 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:20.7730 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 4a1cd09a75ca4ba9b0424a49ad4df119 2016-06-19 13:45:20.7730 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:21.0070 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:21.0070 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:45:21.0070 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:45:21.0070 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 177bd4e412e34acdb89a8d4e7b938f7d 2016-06-19 13:45:21.1474 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 48c9ad9560994540ab6ab2a607fef0ff 2016-06-19 13:45:21.2722 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 5d90ceacff6c4f88bd8d23e91be3fe7d 2016-06-19 13:45:27.1534 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.2158 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 62ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c 2016-06-19 13:45:27.2782 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 51f909efaf984188ae59f1af1238a40b 2016-06-19 13:45:27.2782 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c/Intros. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.2782 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c/Intros 2016-06-19 13:45:27.2782 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c/Intros. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.3250 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 47ms. http://77.160.132.22:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/481fa690acc2af89c43560771507e60c/Intros 2016-06-19 13:45:27.3718 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 07ff838f944a43a9a1ef65a9a2a79d14 2016-06-19 13:45:27.3718 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.3718 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=1000000 2016-06-19 13:45:27.3874 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=1000000. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.4810 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 94ms. http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=1000000 2016-06-19 13:45:27.5278 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 21a4440360904c2c946f3ffb62cacdfe 2016-06-19 13:45:27.5278 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=2400000. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.5278 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=2400000 2016-06-19 13:45:27.5434 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=2400000. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:27.7774 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 234ms. http://77.160.132.22:8096/emby/Playback/BitrateTest?Size=2400000 2016-06-19 13:45:28.0738 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: c73744ba7a66475db46b9aa15eea8d26 2016-06-19 13:45:28.0738 Info HttpServer: HTTP OPTIONS http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/PlaybackInfo?UserId=a8ceeacad4ea4bceb9f8381a2d8cd039&StartTimeTicks=0. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:28.0738 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 0ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/PlaybackInfo?UserId=a8ceeacad4ea4bceb9f8381a2d8cd039&StartTimeTicks=0 2016-06-19 13:45:28.0894 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 71f04943fa5448c28e0401ea4d1f1fe9 2016-06-19 13:45:28.0894 Info HttpServer: HTTP POST http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/PlaybackInfo?UserId=a8ceeacad4ea4bceb9f8381a2d8cd039&StartTimeTicks=0. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:28.1362 Info App: Profile: Unknown Profile, Path: \\MEDIA-PC\Movies\Fast Five (2011)\Fast Five(2011).avi, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-06-19 13:45:28.1362 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\MEDIA-PC\Movies\Fast Five (2011)\Fast Five(2011).avi 2016-06-19 13:45:28.1362 Info App: Profile: Unknown Profile, Path: \\MEDIA-PC\Movies\Fast Five (2011)\Fast Five(2011).avi, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-06-19 13:45:28.1362 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\MEDIA-PC\Movies\Fast Five (2011)\Fast Five(2011).avi 2016-06-19 13:45:28.1362 Info App: Profile: Unknown Profile, Path: \\MEDIA-PC\Movies\Fast Five (2011)\Fast Five(2011).avi, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-06-19 13:45:28.1362 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\MEDIA-PC\Movies\Fast Five (2011)\Fast Five(2011).avi 2016-06-19 13:45:28.1674 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 78ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/PlaybackInfo?UserId=a8ceeacad4ea4bceb9f8381a2d8cd039&StartTimeTicks=0 2016-06-19 13:45:28.6354 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop?quality=100&tag=a07ea99bdd47ade3989587ff3ce21c09. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:28.8694 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 234ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop?quality=100&tag=a07ea99bdd47ade3989587ff3ce21c09 2016-06-19 13:45:36.0454 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop/1?tag=a07ea99bdd47ade3989587ff3ce21c09&maxWidth=1920&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:36.0766 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 31ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop/1?tag=a07ea99bdd47ade3989587ff3ce21c09&maxWidth=1920&quality=80 2016-06-19 13:45:49.5238 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:49.5394 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:49.5394 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 16ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:45:49.5394 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 2861ea4ffa614eec874ec03ecc2c9232 2016-06-19 13:45:49.5550 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:49.5550 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:45:49.5550 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: aa634280124e4d9baba0208a28af4258 2016-06-19 13:45:49.5550 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:49.5550 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:45:49.5550 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: b0b04a497d3e42d0af7fa2fbbf483ade 2016-06-19 13:45:49.5706 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:49.7890 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:49.7890 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:45:49.7890 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:49.7890 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: a89137cc22a54ed692f1ee8447d62b39 2016-06-19 13:45:49.7890 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:50.0230 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:50.0230 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:45:50.0230 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:50.0230 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: cec047a9a55c43e4854a821454eb7408 2016-06-19 13:45:50.0230 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:50.2570 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:50.2570 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:45:50.2570 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:45:50.2570 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 6bbcbaa4bfd5469491911a77b51f44e9 2016-06-19 13:45:50.2726 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:50.2882 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:50.2882 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 16ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:45:50.2882 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 9eeaabee2d344390900876ae63916c1f 2016-06-19 13:45:50.3038 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:50.3038 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:45:50.3038 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: ab64d0d088af4d888c3e0e016723f32d 2016-06-19 13:45:50.3038 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:45:50.3038 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:45:50.3038 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 251090900ee84515ab968466c685772d 2016-06-19 13:45:50.3194 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:50.5378 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:50.5378 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:45:50.5378 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:50.5378 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 437acee6835546b39adb4f149c90b8f3 2016-06-19 13:45:50.5378 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:50.7718 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:50.7718 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:45:50.7718 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:45:50.7718 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: dcacb54a02e34081be7893d840ae121a 2016-06-19 13:45:50.7718 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:45:50.9746 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:45:50.9746 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:45:50.9746 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 203ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:45:50.9746 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 8ca556cdacaa402b9d63a2561e714482 2016-06-19 13:45:56.0446 Info HttpServer: HTTP GET http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop/2?tag=870bf5aa4f52a5c86735ddd157f80803&maxWidth=1920&quality=80. UserAgent: Opera/9.80 (Linux armv7l; Opera TV Store/6222) Presto/2.12.407 Version/12.50 Model/Sony-KDL-40W605B SonyCEBrowser/1.0 (KDL-40W605B; CTV/PKG2.704EUA; NLD) 2016-06-19 13:45:56.2006 Info HttpServer: HTTP Response 200 to 192.168.2.254. Time: 156ms. http://77.160.132.22:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Backdrop/2?tag=870bf5aa4f52a5c86735ddd157f80803&maxWidth=1920&quality=80 2016-06-19 13:46:19.5383 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:19.5695 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:19.5695 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 31ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:46:19.5695 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 1671cc23d38044e6b1435e39ae407fab 2016-06-19 13:46:19.5695 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:19.5695 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:46:19.5695 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 6251c91fe46548f2b502904b9a877edf 2016-06-19 13:46:19.5851 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:19.5851 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:46:19.5851 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: a5d7717b45c64b82915b3df7b1ecbea9 2016-06-19 13:46:19.5851 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:19.8191 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:19.8191 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:46:19.8191 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:19.8191 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: c11cc27b453d4c6c8abab7d4f14a694d 2016-06-19 13:46:19.8191 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:20.0531 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:20.0531 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:46:20.0531 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:20.0531 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: e2711f9634d94e8e81b0f57ac2aff901 2016-06-19 13:46:20.0531 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:20.2715 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:20.2715 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:46:20.2715 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:46:20.2715 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: a6854e5212384bd6a5c1ec92fd071696 2016-06-19 13:46:20.3027 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:20.3027 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:20.3027 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:46:20.3027 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 3250007f6ad743199d21cd95769f2cf5 2016-06-19 13:46:20.3183 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:20.3183 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:46:20.3183 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: a9714af53ca04b8b8be4cb189aaff11e 2016-06-19 13:46:20.3183 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:20.3339 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 16ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:46:20.3339 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 831278a706fe4362912377b1d7fb3878 2016-06-19 13:46:20.3339 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:20.5679 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:20.5679 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:46:20.5679 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:20.5679 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 753e95adae0e46a1a6bf2404eff5e52f 2016-06-19 13:46:20.5679 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:20.7863 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:20.7863 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:46:20.7863 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:20.7863 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 7820cbfafe7d456cabcc3a8320ccd8b0 2016-06-19 13:46:20.7863 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:21.0203 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:21.0203 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:46:21.0203 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 234ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:46:21.0203 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 85047334a6184869b7bf595e078fe88a 2016-06-19 13:46:41.1578 Info HttpServer: HTTP GET http://localhost:8096/. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:41.6258 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:41.6258 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 4ms. http://localhost:8096/web/css/images/favicon.ico 2016-06-19 13:46:43.6019 Info HttpServer: HTTP GET http://localhost:8096/web/strings/en-US.json?v=1466336803597. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:43.6019 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-US.json?v=1466336803597. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:43.6019 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 1ms. http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-US.json?v=1466336803597 2016-06-19 13:46:43.6019 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 2ms. http://localhost:8096/web/strings/en-US.json?v=1466336803597 2016-06-19 13:46:44.4230 Info HttpServer: HTTP GET http://localhost:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.4500 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 27ms. http://localhost:8096/emby/system/info/public 2016-06-19 13:46:44.4950 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5290 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 34ms. http://localhost:8096/emby/System/Info 2016-06-19 13:46:44.5290 Info HttpServer: HTTP GET http://localhost:8096/emby/users/a8ceeacad4ea4bceb9f8381a2d8cd039. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5290 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 3ms. http://localhost:8096/emby/users/a8ceeacad4ea4bceb9f8381a2d8cd039 2016-06-19 13:46:44.5290 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5420 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5420 Info HttpServer: WS ws://localhost:8096/embywebsocket?api_key=c876f98e4fa04c1b86b6bfe4b09be531&deviceId=cdff50b3dea1c3e7a548b01541c6c93c. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5420 Debug HttpServer: Web socket connection allowed 2016-06-19 13:46:44.5420 Info App: App Activity: app: Emby Mobile, version: 3.1.8.0, deviceId: cdff50b3dea1c3e7a548b01541c6c93c, deviceName: Chrome 51.0.2704.84 2016-06-19 13:46:44.5420 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 8ms. http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039 2016-06-19 13:46:44.5630 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Views. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5630 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/mblogoicon.png. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:44.5630 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 7ms. http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Views 2016-06-19 13:46:44.5630 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 1ms. http://localhost:8096/web/css/images/mblogoicon.png 2016-06-19 13:46:44.5740 Info HttpServer: HTTP Response 204 to 127.0.0.1. Time: 32ms. http://localhost:8096/emby/Sessions/Capabilities/Full 2016-06-19 13:46:45.0650 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/home?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&client=webclient. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.1150 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 50ms. http://localhost:8096/emby/DisplayPreferences/home?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&client=webclient 2016-06-19 13:46:45.1200 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Views. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.1200 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items?SortBy=DatePlayed&SortOrder=Descending&MediaTypes=Video&Filters=IsResumable&Limit=8&Recursive=true&Fields=PrimaryImageAspectRatio,SyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.1200 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/Latest?Limit=20&Fields=PrimaryImageAspectRatio,SyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.1200 Info HttpServer: HTTP GET http://localhost:8096/emby/LiveTv/Recordings?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&limit=5&Fields=PrimaryImageAspectRatio,SyncInfo&IsInProgress=false. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.1200 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 4ms. http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Views 2016-06-19 13:46:45.1200 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 7ms. http://localhost:8096/emby/LiveTv/Recordings?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&limit=5&Fields=PrimaryImageAspectRatio,SyncInfo&IsInProgress=false 2016-06-19 13:46:45.1420 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.2110 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 69ms. http://localhost:8096/emby/Plugins/SecurityInfo 2016-06-19 13:46:45.2420 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 120ms. http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items?SortBy=DatePlayed&SortOrder=Descending&MediaTypes=Video&Filters=IsResumable&Limit=8&Recursive=true&Fields=PrimaryImageAspectRatio,SyncInfo&CollapseBoxSetItems=false&ExcludeLocationTypes=Virtual&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&EnableTotalRecordCount=false 2016-06-19 13:46:45.2680 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 146ms. http://localhost:8096/emby/Users/a8ceeacad4ea4bceb9f8381a2d8cd039/Items/Latest?Limit=20&Fields=PrimaryImageAspectRatio,SyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb 2016-06-19 13:46:45.3160 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/1ed09aa9af4234cf42a3ebda865203a5/Images/Primary?maxHeight=337&maxWidth=600&tag=bca3ccce62658508423915bbfc8df633&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3160 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/c74a957e46733200636f6f1f2e271e06/Images/Primary?maxHeight=337&maxWidth=600&tag=52ca40a3d48a0959880643b8388c78bd&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3160 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/3ef71fec184e38c523b1d099a232173f/Images/Thumb?maxWidth=600&tag=0922fb21b5fe6a05c351c11d68a52eb7&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3220 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/b51707d1fe1cf4c314c3b0e64572c5ce/Images/Thumb?maxWidth=600&tag=1458ad0b382d84c5c85b3a71ac208b56&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3220 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/78550198595dda9dc0c9a3a1de6c502d/Images/Thumb?maxWidth=600&tag=322776510c5cfeb1436f09cae4f8981c&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3220 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/79a2726d3c50e769a8af1e4184e4fccf/Images/Primary?maxHeight=169&maxWidth=300&tag=2b38155198bd1b447ba90ca057fb1c7a&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3220 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 7ms. http://localhost:8096/emby/Items/1ed09aa9af4234cf42a3ebda865203a5/Images/Primary?maxHeight=337&maxWidth=600&tag=bca3ccce62658508423915bbfc8df633&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.3220 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 3ms. http://localhost:8096/emby/Items/c74a957e46733200636f6f1f2e271e06/Images/Primary?maxHeight=337&maxWidth=600&tag=52ca40a3d48a0959880643b8388c78bd&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.3220 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/04f09db219b5cb5758cd88c3c7db037c/Images/Primary?maxHeight=169&maxWidth=300&tag=4574bdc92ed1bd556b9dcb3ac5bde8a9&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3220 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/6a13479d513e75039b97064f7d85f674/Images/Backdrop?maxWidth=600&tag=df4375ce7e991129033a756f8aacdc24&enableImageEnhancers=true&quality=80. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3510 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 30ms. http://localhost:8096/emby/Items/3ef71fec184e38c523b1d099a232173f/Images/Thumb?maxWidth=600&tag=0922fb21b5fe6a05c351c11d68a52eb7&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.3550 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/2b2bca16aacc8a14d53a11bb829eafa5/Images/Primary?maxHeight=191&maxWidth=300&tag=3000080fb76c4caf46a5809d12210c0b&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3550 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 45ms. http://localhost:8096/emby/Items/78550198595dda9dc0c9a3a1de6c502d/Images/Thumb?maxWidth=600&tag=322776510c5cfeb1436f09cae4f8981c&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.3550 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 46ms. http://localhost:8096/emby/Items/b51707d1fe1cf4c314c3b0e64572c5ce/Images/Thumb?maxWidth=600&tag=1458ad0b382d84c5c85b3a71ac208b56&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.3690 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/7c19aa1b80e61dc77a5d0dcfb90c162e/Images/Backdrop?maxWidth=600&tag=a72d27b775bd6d019382a7580958790e&enableImageEnhancers=true&quality=80. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3690 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 46ms. http://localhost:8096/emby/Items/6a13479d513e75039b97064f7d85f674/Images/Backdrop?maxWidth=600&tag=df4375ce7e991129033a756f8aacdc24&enableImageEnhancers=true&quality=80 2016-06-19 13:46:45.3690 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images/Primary?maxHeight=169&maxWidth=300&tag=f948debda7f9e6a91fe1e9e3c51a356b&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3690 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/767bffe4f11c93ef34b805451a696a4e/Images/Primary?maxHeight=169&maxWidth=300&tag=f94bb02076dc94ff55f34d4436e10bec&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3900 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 67ms. http://localhost:8096/emby/Items/79a2726d3c50e769a8af1e4184e4fccf/Images/Primary?maxHeight=169&maxWidth=300&tag=2b38155198bd1b447ba90ca057fb1c7a&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.3900 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/7b352bea3f1667132336b8ee65b79074/Images/Thumb?maxWidth=600&tag=66292f49ba8107164d9edb0fd825186c&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.3900 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 30ms. http://localhost:8096/emby/Items/7c19aa1b80e61dc77a5d0dcfb90c162e/Images/Backdrop?maxWidth=600&tag=a72d27b775bd6d019382a7580958790e&enableImageEnhancers=true&quality=80 2016-06-19 13:46:45.3900 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Thumb?maxWidth=600&tag=7590172730696ef86b894a7e9ea55f85&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.4060 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 51ms. http://localhost:8096/emby/Items/2b2bca16aacc8a14d53a11bb829eafa5/Images/Primary?maxHeight=191&maxWidth=300&tag=3000080fb76c4caf46a5809d12210c0b&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.4060 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/e5b11ff34d2ada5a7e1bccc961bed4bd/Images/Thumb?maxWidth=600&tag=8cec3b40e48a9218faba8395a6b7cb82&enableImageEnhancers=true&quality=90. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:45.4190 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 29ms. http://localhost:8096/emby/Items/7b352bea3f1667132336b8ee65b79074/Images/Thumb?maxWidth=600&tag=66292f49ba8107164d9edb0fd825186c&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.4190 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 19ms. http://localhost:8096/emby/Items/e5b11ff34d2ada5a7e1bccc961bed4bd/Images/Thumb?maxWidth=600&tag=8cec3b40e48a9218faba8395a6b7cb82&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.4190 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 56ms. http://localhost:8096/emby/Items/767bffe4f11c93ef34b805451a696a4e/Images/Primary?maxHeight=169&maxWidth=300&tag=f94bb02076dc94ff55f34d4436e10bec&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.4190 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 106ms. http://localhost:8096/emby/Items/04f09db219b5cb5758cd88c3c7db037c/Images/Primary?maxHeight=169&maxWidth=300&tag=4574bdc92ed1bd556b9dcb3ac5bde8a9&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.4410 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 71ms. http://localhost:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Images/Primary?maxHeight=169&maxWidth=300&tag=f948debda7f9e6a91fe1e9e3c51a356b&enableImageEnhancers=true&quality=90 2016-06-19 13:46:45.4480 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 49ms. http://localhost:8096/emby/Items/481fa690acc2af89c43560771507e60c/Images/Thumb?maxWidth=600&tag=7590172730696ef86b894a7e9ea55f85&enableImageEnhancers=true&quality=90 2016-06-19 13:46:46.1051 Info App: SessionInfoWebSocketListener Begin transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:46.1051 Info App: ScheduledTasksWebSocketListener Begin transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:46.1051 Info HttpServer: HTTP GET http://localhost:8096/emby/Notifications/a8ceeacad4ea4bceb9f8381a2d8cd039/Summary. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1051 Info HttpServer: HTTP GET http://localhost:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1051 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1051 Info App: ActivityLogWebSocketListener Begin transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:46.1051 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1051 Info HttpServer: HTTP GET http://localhost:8096/emby/News/Product?StartIndex=0&Limit=7. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1051 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 5ms. http://localhost:8096/emby/Sessions 2016-06-19 13:46:46.1051 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-06-18T11:46:46.105Z. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1191 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 4ms. http://localhost:8096/emby/News/Product?StartIndex=0&Limit=7 2016-06-19 13:46:46.1191 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/dashboard?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&client=dashboard. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1491 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 39ms. http://localhost:8096/emby/ScheduledTasks 2016-06-19 13:46:46.1491 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/supporter/supporterbadge.png. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1491 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 7ms. http://localhost:8096/web/css/images/supporter/supporterbadge.png 2016-06-19 13:46:46.1491 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 40ms. http://localhost:8096/emby/DisplayPreferences/dashboard?userId=a8ceeacad4ea4bceb9f8381a2d8cd039&client=dashboard 2016-06-19 13:46:46.1491 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 54ms. http://localhost:8096/emby/Notifications/a8ceeacad4ea4bceb9f8381a2d8cd039/Summary 2016-06-19 13:46:46.1651 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 50ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-06-18T11:46:46.105Z 2016-06-19 13:46:46.1651 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1651 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/clients/android.png. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1651 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/clients/dlna.png. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1651 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/clients/kodi.png. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.1651 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 2ms. http://localhost:8096/web/css/images/clients/android.png 2016-06-19 13:46:46.1651 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 2ms. http://localhost:8096/web/css/images/clients/kodi.png 2016-06-19 13:46:46.1651 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 3ms. http://localhost:8096/web/css/images/clients/dlna.png 2016-06-19 13:46:46.2181 Info HttpClient: HttpClientManager.GetTempFileResponse url: https://www.mb3admin.com/admin/service/MB3Packages.json 2016-06-19 13:46:46.2181 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 46ms. http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled 2016-06-19 13:46:46.2281 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 116ms. http://localhost:8096/emby/System/Info 2016-06-19 13:46:46.3361 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:46.3361 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 11ms. http://localhost:8096/emby/Packages/Updates?PackageType=System 2016-06-19 13:46:49.5552 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:49.5782 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:49.5782 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 24ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:46:49.5782 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: bb4fbdbb46814486829c1352a27c5f5c 2016-06-19 13:46:49.5863 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:49.5863 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 1ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:46:49.5863 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 358dbfd7e9cc49adad5f59eb74c2e95c 2016-06-19 13:46:49.5983 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:49.5983 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 0ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:46:49.5983 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 04676fb404bf40038288099684322e97 2016-06-19 13:46:49.5983 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:49.8263 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:49.8263 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:46:49.8263 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 222ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:49.8263 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: f8fd244589a645e08ffe6214cd775127 2016-06-19 13:46:49.8303 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:50.0413 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:50.0413 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:46:50.0413 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 212ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:50.0413 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 4556d6cb121b498c8b09e4c9020087b1 2016-06-19 13:46:50.0413 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:50.2663 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:50.2663 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:46:50.2673 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 222ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:46:50.2673 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 75ae6c890dfa45fda25ee4e16bd630ec 2016-06-19 13:46:50.2933 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:50.3143 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:50.3143 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 21ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/description.xml 2016-06-19 13:46:50.3143 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 53147fb3397e40cd8e1424530627592f 2016-06-19 13:46:50.3143 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:50.3143 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 1ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/contentdirectory.xml 2016-06-19 13:46:50.3143 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: dcb631dc9d29409eb6878ddb922191cd 2016-06-19 13:46:50.3353 Info HttpServer: HTTP GET http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 2016-06-19 13:46:50.3353 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 1ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/connectionmanager.xml 2016-06-19 13:46:50.3353 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 0bc4dad1072d48febc21ee4c03260d82 2016-06-19 13:46:50.3353 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:50.5593 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:50.5593 Debug UpnpContentDirectory: Received control request GetSortCapabilities 2016-06-19 13:46:50.5593 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 218ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:50.5593 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 2c1c512054b549b88150fdc94cd6c586 2016-06-19 13:46:50.5633 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:50.7853 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:50.7853 Debug UpnpContentDirectory: Received control request GetSearchCapabilities 2016-06-19 13:46:50.7853 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 223ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/contentdirectory/control 2016-06-19 13:46:50.7853 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: c3b88e4b91014b4994fb1d8d5fa48256 2016-06-19 13:46:50.7853 Info HttpServer: HTTP POST http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control. UserAgent: UPnP/1.0 DLNADOC/1.50 2016-06-19 13:46:51.0203 Debug Dlna: Found matching device profile: Samsung Smart TV 2016-06-19 13:46:51.0203 Debug UpnpConnectionManager: Received control request GetProtocolInfo 2016-06-19 13:46:51.0203 Info HttpServer: HTTP Response 200 to 192.168.2.7. Time: 233ms. http://192.168.2.8:8096/dlna/6be9a041e8effb367892589efeba4adb/connectionmanager/control 2016-06-19 13:46:51.0203 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: ed1f6b651dff4fd5be9290efce741df3 2016-06-19 13:46:55.1116 Info App: ActivityLogWebSocketListener stop transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:55.1116 Info App: ActivityLogWebSocketListener Begin transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:55.1116 Info App: SessionInfoWebSocketListener stop transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:55.1116 Info App: ScheduledTasksWebSocketListener stop transmitting over websocket to [::ffff:127.0.0.1]:59796 2016-06-19 13:46:56.9777 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:56.9777 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36 2016-06-19 13:46:56.9777 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 6ms. http://localhost:8096/emby/System/Configuration 2016-06-19 13:46:57.0187 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 41ms. http://localhost:8096/emby/System/Logs 2016-06-19 13:46:57.9827 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: a5c246bf1aa344fbb1a5daec1734771b 2016-06-19 13:46:57.9827 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 70b8d108541f4aa7a92bf0c89805b684
BrettDioson 4 Posted June 25, 2016 Posted June 25, 2016 Ok I tried again last night at around 12:30am ET and it played video! Fantastic progress! Regarding control scheme the only button that worked was the OK or Select button which did play/pause. The direction arrows, fast forward, rewind, even the play and pause and stop buttons do nothing, but the OK button works when playing the video. Great job so far.
Behelit 5 Posted June 26, 2016 Posted June 26, 2016 (edited) I have a Samsung BD-H5500 Player with Opera TV Store, having seen this page and reading about Emby having an app for it i wanted to try it. So i: 1) Created an account on Opera TV Store - Submission Portal 2) Successfully paired my BD-H5500 3) Downloaded Urlloader on the player 4) Typed tv.emby.media url in UrlloaderWhen i click go, it appears an off-center "Welcome to Emby" screen on TV, clicking next it appears the Emby Connect screen where i can click skip and manually connect to the server adding my local ip and http port in the next screen, but when i click connect it freezes and i can only click exit on my remote to close Opera TV Store. Edited June 26, 2016 by Behelit
Luke 42243 Posted June 26, 2016 Posted June 26, 2016 Hi, try Emby Connect and see if that makes a difference.
Behelit 5 Posted June 26, 2016 Posted June 26, 2016 Hi Luke I can't use Emby Connect, it keeps telling me: "An error occured while creating a pin code. Please click Generate New Pin to try again"
Luke 42243 Posted June 26, 2016 Posted June 26, 2016 ok so basically all http requests are failing from your device. interestingly i have seen some logs come through for other sony blu ray player models. not sure what's going on there.
Behelit 5 Posted June 27, 2016 Posted June 27, 2016 Is there something i can do on my part for testing?
ebr 16335 Posted June 27, 2016 Posted June 27, 2016 I have a Samsung BD-H5500 Player with Opera TV Store, having seen this page and reading about Emby having an app for it i wanted to try it. So i: 1) Created an account on Opera TV Store - Submission Portal 2) Successfully paired my BD-H5500 3) Downloaded Urlloader on the player 4) Typed tv.emby.media url in Urlloader When i click go, it appears an off-center "Welcome to Emby" screen on TV, clicking next it appears the Emby Connect screen where i can click skip and manually connect to the server adding my local ip and http port in the next screen, but when i click connect it freezes and i can only click exit on my remote to close Opera TV Store. Steps 1 and 2 are not necessary. Not sure if they have any impact at all but I doubt it. Not all implementations of the Opera TV Store are the same I'm afraid. Does your player have a built-in browser? If so, you can try loading it there.
Behelit 5 Posted June 27, 2016 Posted June 27, 2016 I had to do steps 1 and 2 to be able to activate Develop category tab in the Opera TV Store and download Urlloader, without doing so Urlloader was invisible in Store even doing a manual search. I can use Urlloader to view websites so i tried to put my server local ip address and http port, as you suggested. It opens my user selection emby page but showing no user to select, tried manual login but the screen freezes on TV when i click on "Sign In". It's strange cause even if i have a stuck "Sign In" page on TV, watching my server dashbord on my pc browser it lists Web Browser 11.60 in the active devices and the "my username" successfully authenticated (with the BD Player Local IP) notice in the Recent Activity.
ebr 16335 Posted June 27, 2016 Posted June 27, 2016 Luke - I see no logs from his activity. I wonder if it isn't identifying his player as an Opera TV device. Behelit - there is a UserAgent string shown at the bottom of the UrlLoader app. Can you show us what it has in it?
Cremby 0 Posted June 27, 2016 Posted June 27, 2016 The text of the sign-in screen @ tv.emby.media is about 3 characters left from where it should be with the leftmost text being off the screen. When I connect to my server (manually via IP:PORT), I get: JavaScript Alert: We were unable to connect to the selected server. Please ensure it is running and try again. I have a Sony BDP-S3200 Thanks
Behelit 5 Posted June 27, 2016 Posted June 27, 2016 Sure, it's: OPERA/9.80 (LINUX ARMV6L; OPERA TVSTORE/5580;) PRESTO/2.10.250 VERSION/11.60 MODEL/SAMSUNG-BD-H5900
Dunc27 0 Posted August 3, 2016 Posted August 3, 2016 My TV running opera tv browser hi everyone need some help 1 is there an app I can watch English TV and 2 is there app for catch up TV please
Luke 42243 Posted August 3, 2016 Posted August 3, 2016 My TV running opera tv browser hi everyone need some help 1 is there an app I can watch English TV and 2 is there app for catch up TV please See here: http://emby.media/community/index.php?/topic/18323-opera-tv-apps-for-sony-and-other-tvs/?p=335219
romaing 4 Posted August 13, 2016 Posted August 13, 2016 works fine through OPERAT - URL LOADER on SONY KDL-48W650D ! thank you !
